Question about NorStar T7316E Corded Phone
I dont know how to change the speed dial for the whole office. not just personal.
Can't use premier assistance plan (due to payment) so problem not solved.
Posted on Nov 05, 2008
After a series of power outages and brown outs over the weekend, our system has lost all of the predialed #'s and only one phone in the whole office (10 phone) rings.
Sounds like the system defaulted programming.
Depending on the type of prostar 616 the only ringing station would be 1(or 21) with the porstar or 4(or 24) with the prostar plus.
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
enter in 1 2 3 4 1 # (that enables programming)
enter in #62 the screen should say day ring assn
press the line you wish to program
press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
press # when finished with the line
repeat steps 2 through 5 for the remainder of the lines you wish to change
press # when finished.
To program system speed dial numbersyou need the customer programming enabled (see the first part of programing ringing)
press the ALM/SD button
dial the 2 digit speed dialcode 10-98
dial the telephone number to be stored in that speed dial bank
press ALM/SD to store the number
Jun 01, 2010 | Samsung Prostar 816 Phone
How do we change the phone numbers on the speed dial
Feb 27, 2010- Speed dial numbers 001 -255 (256-279 are personal speed dial entries) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say Terminals&Sets.
The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key 3 times(bottom right arrow).
The display should say Sys speed dial.
Press the show key (top right arrow)
The display should say speed dial#:--
enter in the speed dial number you wish to program.
Press the show key (top right arrow) .
The display should show the existing speed dial number
Press the chg key
Enter in new telephone number
press ok when finished
repeat for remaining speed dials
Press the release key when finished
Apr 16, 2010 | Nortel T7316E 2-Line Corded Phone
INSTRUCTIONS NEEDED ON HOW TO SET UP SPEED DIAL NUMBERS FOR WHOLE OFFICE SYSTEM
Speed dial numbers 001 -255 (01- 70 on older versions) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
enter in the speed dial number you wish to program(40-70) .
Press the chg key
Jan 08, 2010 | NorStar T7316E Corded Phone
How do I change the speed dial outgoing number??
For personal speed dial numbers press feature *4 , enter in speed dial bank number 71-94 (256-279, it changes with different versions), enter number, press ok
- speed dial numbers 01- 70 are system wide speed dial numbers and are changed in system programming2.gif.System programming is done on M7310,M7324 and T7316 set only.
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The 4 top line/feature keys are now used for programming2.gif.
Press the chg key
Oct 14, 2009 | NorStar M7310 Corded Phone
Programmed speed dial - internal calls
To add an Extension Key: -
DONT lift handpiece, enter [*91] then press a vacant memory key and then choose “Repdial Key” from the menu. Enter an extension or group number and press the [ü] key.
To dial an Extension Key: -
Lift handpiece.
Press the memory key you programmed.
Storing a personal speed dial number: -
Lift handpiece.
Dial [*92]
Dial memory number.
(*0 - *9 for personal numbers)
Press the [ü] key.
Dial 0 then the number to be stored.
Press the [ü] key.
Hang up.
How to dial speed dial numbers: -
Lift handpiece.
Dial [*7]
Dial memory number.
(001-999 for system numbers)
For Example: [*7*0 ü] will call the personal number stored under position *0.
[*7001 ü] will call the system speed dial number stored under position 001.
Jan 19, 2009 | Siemens optiPoint 500 Standard Corded...
I dont know how to put my fav five on my cell phone
The LG Voyager does not have a fave five option. You can have a speed dial option. To setup speed dial , open the phone, hit menu, go to contacts, speed dials, click on a number, and then go to the contact you want to select for this number. To use this feature, you just have to press the number that person is assigned to and then press send.
Hope this helped.
Dec 25, 2008 | LG VOYAGER VX10000 Cellular Phone
How do i edit my speed dials?
Redial, speed dial enter the code(60- 99) for system speed dial
(10- 49) for personal speed dial. enter the phone number or the number you want to program then press redial.
Aug 26, 2008 | Toshiba DKT-2010 Corded Phone
Entering a pause when programming personal speed dial
Press PAUSE where you want it. It will appear on the screen as "P". If the pause isn't long enough, press it more than once.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Jun 03, 2008 | Panasonic KX-T7633 Corded Phone
Speed Dialing
There are actually many ways to program them, and dialing them can be different depending on the system involved.
You can have speed numbers on each extension (up to 10) and system wide (up to 1000). In addition, you can have telephone numbers associated with buttons on the phone allowing one-touch dialing.
How it is done depends on which system you have and how it was programmed by your installer.
Mar 04, 2008 | Panasonic KX-T7633 Corded Phone
Speed dial
For System Speed dial, you can only do it from a port with Attendant Features. Typically they are ports 1 and 2.
Assuming they are still the default settings, the available System Speed Dial bins are 00 thru 79.
from one of the Attendant Ports:
Press Feature
Press Redial
Dial in the memory location bin number (00-79)
Press "9" for the Trunk Access Code (or whatever it is)
Dial in the Phone Number (24 digits max)
Press Feature
To use, get DialTone, press Redial, enter bin number (00-79)
Oct 10, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
NorStar T7316E Corded Phone Logo
94 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
