Question about Whirlpool Dryers
Whirlpool tumble dryer stopped working , took 1 load out put another load in and just stopped
    President:
  • Whirlpool Master
  • 2,651 Answers
Check your dryer door switch, common for strike actuator to break off, not recogniziong door closed the machine will not do anything. if that sgood yo may have blown a thermal fuse
Posted on Nov 05, 2008
After a few minutes of working it will just stop
Posted on Oct 13, 2009
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Siemens dryer powers on, but will not tumble.
Work on mainly Whirlpool Products did you put the belt on correctly there is probably a belt switch which is closed with a properly installed belt it is under the spring loaded idler pulley or maybe you for got to hook up the door switch hope this helps.
Mar 22, 2014 | Kenmore Elite HE3 Steam 8674 Dryer
My creda reverseair tumberledryer won';t work. my
Hi
If you can hear the motor running and have also checked the belt tension and they are O.K., then the only thing I can think of is the Motor pulley, where the belt sits on.
Check that out and make sure it is not loose on the motor shaft, so that the motor turns but the pulley slips.
Regards
Ash
Nov 09, 2009 | Creda IWD12 Front Load Washer / Dryer
There is no heat when dryer is on
you need chek :
if your apliance is gas dryer:
1-thermal fuse.
2-sensor flame.
3-ignitor.
4-gas valve.
if is electric dryer:
1-thermal fuse.
2-heater element.
Oct 05, 2009 | Dryers
Whirlpool dryer froze and wont tumble just makes noise where try
Hi, This dryser only has 1 belt. When you chacked the belt, was the belt located in the middle of the drum?
This model has an idler pulley that is no longer being used. They have went back to the roller style idler which is easier on the belt.
Raise the top and then remove the 2 screws holding the front to the cabinet. Remove the front cabinet and locate the idler next to the motor pulley. Look at the belt while you have the front off and see if there is any bad spots in it.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 02, 2009 | Whirlpool LER4634J Electric Dryer
Element heats, dryer tumbles, no heat in drum, never shuts off
Hi, If the dryer heats but will not advance in either time or auto cycles, you need to change the timer.
You can test to see if the timer is getting voltage. Remove the top rear panel and locate the two wires going to the timer motor. There should be 120V when the dryer is running in time dry.
Please let me know if this helps or if I can assist you further.
Thanks
Vic
May 27, 2009 | Whirlpool LER5636P Electric Dryer
Dryer has heat and tumbles but won't dry
your vent is stopped or the fan is not turning . most likely the vent under the house
Dec 14, 2008 | Whirlpool LER3622HQ Electric Portable...
Spins but no heat
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE;
Apr 11, 2008 | Whirlpool LGR7646E Dryer
Dryers Logo
177 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
