Question about Dryers
White knight sensordry model CL432 WV only heats up slightly,hose etc seems pretty clear and red button trip does not click in so assume that is ok, regards Vic
  • Anonymous Feb 18, 2009
    does not heat up
    President:
  • 1,462 Answers
Take top off and check continuity thro heater.
Posted on Nov 05, 2008
White knight 427 not heating
Heating element is probably burned out. Or the thermal fuse / cutoff. I would check the fuse first as the heating element has 2 independent heating coils and usually both won't burn out at the same time. It would be best to have a meter tester. I am in Lake Worth, Fla. I travel within a 40 mile radius How to Replace White Knight Tumble Dryer Heating Element Heater...
Sep 12, 2014 | Dryers
The high and low temperature buttons on my White Knight sensordry tumbledryer pushed in because a screw had become loose inside. Have dismantled it but can't work out how to reassemble - there is a little...
Tiugh one. Next time take a photo of the site before you try to take it apart. Or have someone send you a parts break out of the machine. Good luck.
Oct 16, 2013 | Dryers
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
Dryer does not get hot, already changed the heating eliment
this might help
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Feb 15, 2010 | Dryers
Have just bought a new heater element for a CL432AV White Knight Duel Heat Tumble Drier it will not heat think I have wired it up wrong do not have a wiring diagram can you help.
Feb 12, 2010 | Dryers
Yesterday the trip switch for the downstairs mains sockets tripped. When i reset it and plugged switched on my White Knight 44AW drier it span as usual but now there is no heat.
Jan 19, 2010 | Abbaka White Knight 44AW Electric Dryer
My white knight 44aw often trips the reset on the back of the drier , even when only half full. ps ive checked the filter.
Howdy: On the back side there is a thermostat that shuts off the dryer if too hot. Sometimes lint will kling to it and will sense to much heat. Clean the back of the unit with a vacuum cleaner hose or a blowing device to clear that area. Good luck - Doug
Dec 09, 2009 | Dryers
White Knight sensordry tumble dryer which only works on low heat
Could be element or thermostats, element is twin giving two heats ie !00watt/ +1800watt, possible one side has gone, you bcan check with multimeter and compare readings..Good luck
Oct 01, 2009 | Dryers
White Knight tumble dryer making a clicking noise when on & has no heat
utube.png You-Tube video "XNxE9eXx2Rk" placeholder (do not delete) utube.png
May 02, 2009 | Dryers
WHITE kNIGHT tUMBLE DRIER THAT STILL TUMBLES WITH NO HEAT
there is an overheat resettable stat on the back under a small red cover. try for a start pressing the centre of the red cover and you should hear a click and dryer will then heat. this is the most common fault - get back to me if somethinbg different
Sep 05, 2008 | Dryers
Dryers Logo
297 people viewed this question
Top Dryers Experts
