Question about Canon BubbleJet i560 InkJet Printer
I 560--photo printing on 4"x6" paper
HOW DO I SET UP THE I560 SO THAT IT PRINTS ONTO 4X6 PHOTO PAPER. ALSO, WHERE DO I OBTAIN AN OPERATING MANUAL FOR i560, mine has been lost.. thanks HOWARD SMITH
11/05/08
  • 417 Answers
You should be able to do this in print preferences. Open up your general printer box by clicking on Print. Select print preferences then page setup then select page size and a list of sizes will appear just select 4x6 and then paper type, press print and you have done it.
You might be able to get a manual from the Canon website or 'google' for the one you want.
Please remember to rate this solution.
Posted on Nov 05, 2008
When I use my Brother MFC-465 CN printer to print 4X6 photos with the photo paper bypass tray in proper position, it jams sending the photo paper through. Printer is set to 4x6; software set to photo as...
Hi there!
The compatibility of the paper may affect the issue that you are having. I have a brother printer also and prints on 4x6 size what i can suggest is to try turn the photo paper upside down, so facing the tray, 2 sheets at the bottom should have the glossy side up. and the sheet where you need to print the photo should be facing down. So when the paper roller grabbed the photo paper at the top it will smoothly pass thru,
Hope this helps! Vikroks
Mar 06, 2011 | Brother MFC-465CN InkJet Printer
My 4x6 prints are not centered on paper
That printer can't print borderless on 4x6 photo paper, you should use A4 size paper, print and cut the pictures.
Nov 04, 2009 | HP DeskJet 940c InkJet Printer
I have a photosmart 8250 using iphoto, how do I print 3x5 using 3x5 tray?
Set the default printer driver settings to print 10 x 15 cm (4 x 6 inch) photos
  1. Make sure 10 x 15 cm (4 x 6 inch) photo paper is loaded into the photo tray. NOTE: The Photo Tray light on the printer does not have to be lit when printing from a computer.
  2. Click Start and then click Control Panel .
  3. Click Printers and Faxes .
  4. Right-click the icon for the HP Photosmart 8200 Series and select Printing Preferences .
  5. On the Paper/Quality tab, select 4x6 or 4x6 with tab from the Size is drop-down menu (under Paper Options).
  6. Make sure that the Source is box is set to Photo tray .
  7. Click the Borderless Printing box if borderless prints are desired.
  8. Click Apply and then click OK .
  9. Open the software program you wish to use and set up the pictures you want to print. Make sure to select a 4x6 inch layout for the photos within the software program before you print from the software program.
Oct 11, 2009 | HP Photosmart 8250 InkJet Printer
I have 4 x6 printer paper and the printer only shows standard 81/2 by 11
If you use windows photo gallery to print, it will allow you to set the paper size and type, otherwise in your control panel/printers and printing preferences you can set the 4x6 paper size.
Oct 02, 2009 | Canon i860 InkJet Photo Printer
Canon i960 prints perfectly on plain paper but not on photo paper
Hello sir; Before you print, you have set up in you computer then press print. check print preview first, if not satisfy then go to adjust it.
May 05, 2009 | Canon I960 InkJet Photo Printer
I am trying to print 4 x 6 photos, and have set all of the settings to 4 x6, but I the printer keeps printing part of the photo on the entire 4 x 6 area of the paper. Could you help please!!! Thank you.
I belive you are saying the printer is trying to print say an 8X10 picture on you 4x6 paper. If this is the case, the software is not being set correctly for the size of paper.
Mar 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
My HP Photosmart C6200 All IN ONE serial # MY7AJH63BB, will not print photos coming from my Mini Mac computer on to the photo paper in the photo paper tray. It will only print onto 8x11 paper sheet. I...
None of the buttons on my 3 in 1 photosmart c6280 work but I can use to HP solution to get prints ,scan , and copy. Can not turn off or clear '! "button with out unpluging
THANKS
Nov 29, 2008 | HP Office Equipment & Supplies
How do I print pictures onto 4 x 6 photo paper?
you have to change the printer settings within the pc side. Chosse the papersize of 4x6 (photo1 as far as I remember).
Apr 27, 2008 | Brother MultiFunction Center MFC-440CN...
Reprinting photos
try using a ruler to check if you have the correct paper size.
open up HP Solution Center verify the printer settings..
use borderless printing, paper size 4 x 6.
Dec 27, 2007 | HP Photosmart C6180 All-In-One InkJet...
Canon BubbleJet i560 InkJet Printer Logo
66 people viewed this question
old marine
old marine
