Question about Hampton Bay 52 In. Cameron II Plus Ceiling Fan, Brushed Steel & Cobalt Blue Finish
Installing Fan Pull Chain
I'm trying to install a new pull chain in my fan, but i lost track of which wires go where into the chain. The wire colors are black, red, purple, and yellow. I am assuming black is L, but i still need the colors for 1, 2, and 3. If no one can provide them, would it be harmful to try different combonations?
  • jimmy baker Oct 07, 2006
    by the way, the fan is a Hampton Bay 52 in. Cameron II plus, brushed steel and cobalt blue finish.
  • sharolette Aug 30, 2008
    My husband pulled the unit down and didn't mark the wires - the colors of my wires are purple, yellow, black, and orange...I purchased a new 4 wire / 3-speed fan switch...but can't locate a wire schematic to follow. Any suggestions?
    President:
  • 3,130 Answers
Hampton Bay fans are a Home depot entity. You can contact Home Depot online and ask but im sure you never will recive an answer as I have asked several questions about replacement parts to them till I was blure in the face. You can look up a company called the fan doctor online and see if they can assist you Good Luck
Posted on Oct 08, 2006
Where can I purchase a Jin you e70469 ceiling fan switch.
ebay 14 bucks
Jin You E70469 Pull Chain Switch for 3 Speed Ceiling Fan 4 Wire 1 2 ...
https://www.ebay.com > ... > Lighting Parts & Accessories
item 2 ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire -ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire. ... item 3 OEM ZING EAR ZE-208S 3 SPEED CEILING FAN PULL CHAIN CONTROL SWITCH E-89885 DR73 -OEM ZING EAR ZE-208S 3 ...
Exhaust Ceiling Fan Switch 2 Speed Pull Chain Blower Jin You ...
https://www.ebay.com/itm/...Ceiling-Fan-Switch...Jin-You-E70469...-/132376583704 Replaces Jin You E70469, Santa, Gardner Bender GSW-33. The control module provides two speed setting for your fan. 2 Speed Pull Chain Switch. 3" (7mm) Brass Chain. Spark Electric Components LLC. Width 11/16" (18mm). ' eBay!
Jin you e70469 ceiling fan switch Google Search
Dec 12, 2017 | Dryers
Fan is stuck on high, and I'm trying to install a 3-speed pull chain.
Do you know the make/model of fan? Hopefully you have the correct switch.
Mar 27, 2016 | Dryers
I want to get my fans back to the original setting when first installed.
If you mean you put in new pull chain switches, then I'm pretty sure you have the wrong switch. What is the make/model of fan. How many wires on your capacitor & which color wire goes into which slot in the pull chain? fanman9952@aol.com
Aug 18, 2014 | Dryers
I did not make a diagram when replacing the light switch
Red from switch goes to two blacks, blue from switch goes to two blacks and the black wire goes thru top of light and attaches to blue fan light wire. If you want a good fan, look for blade pitch(13 degree or higher)Or CFM's above 5500 on high.
Oct 02, 2013 | Hampton Bay 24002 Ceiling Fan
HAVE HAMILTON bAY CEILING FAN, WORKS WELL BUT FAN WILL NOT STOP ALL THE WAY. INSTALLED NEW PULL CHAIN SWICH AND NEW TIMMER, STILL HAS CURRENT GOING THROUGH.
You don't have the correct switch. A lot of switches look alike on the outside but they are different on the inside. Call 1-800-365-4548 and tell them how many wires on your capacitor and which color wire goes into which slot on the pull chain switch.
Sep 12, 2013 | Dryers
Hunter ceiling fan pull chain for fan broke
First write down which color wire goes in which slot on switch.Turn power off! Disconnect wires from defective switch by inserting a paper clip or something a little bigger into the wire connection.Then press the spring down and release the wire to insert in new HUNTER switch. DO NOT CUT WIRES!Call 1-888-830-1326 with model # to order the correct switch.
Mar 24, 2013 | Hunter (25417) Ceiling Fan
I'm trying 2 replace the pull chain in a hunter
Do you have a new Hunter switch or did you buy one off the rack at HD?
Should always write down which color wire goes into which slot. call 1-888-830-1326 with model #.
Mar 09, 2013 | Dryers
I thought I put the wires from the old switch to the new switch correctly but now the fan does not work. The lights come on but no fan.
The pull chain for fan and the pull chain for lights are wired separately.
If you are talking about a wall switch, add a comment with clear description of old switch and new switch, screw colors on each switch, and color of each wire for possible help.
Open following link possible illustration of your pull-chain fan switch.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#fan-switch
Jul 27, 2011 | Westinghouse Electric Westinghouse...
I have a 3 way fan light switch but wires don't match the colors on my hamton bay fan what wires go where i have a black wire and a brown wire and a grey wire on the switch in the hamton bay i bought...
It takes 2 testers.
699b7e0.jpg regular tester
Continuity tester has battery and light bulb.
Use regular tester to find Hot wire that feeds old-switch.
Remove old-switch from fan
Strip back wires
Separate wires so they can be tested.
Turn on power.
Test each wire to bare copper wire -or- to green wire -or- to metal part of fan
One of the fan wires will light up tester.
This is the Hot wire.
Mark Hot wire.
Mark which color wire on old-switch went to the hot wire.
Use continuity tester on old-switch.
You know which wire is hot-on-old-switch
Pull chain and test hot-on-old-switch to both of the other wires.
When tester lights up, mark this wire.
Pull chain again and test hot-on-old-switch to both of the other wires.
At some point when you pull the chain, the tester will light up both the other wires.
This is the high speed.
Use continuity tester on new-switch.
Repeat the test for old-switch.
Identify which wire will be the Hot wire by process of elimination.
Mark this wire.
Identify high-speed wire.
Pull chain again, and tester lights up on medium speed.
Pull chain again, and tester lights up on low speed
Identify these wires and match pattern to the old-switch
If you need more help, add a comment, and I will answer
Oct 29, 2010 | Westinghouse Electric Ceiling Fan 3-way...
Which color wires connect to pull chain switch
do you have a Menards, or a Lowes in your area, if you do they can give you the answer to this question, it is a bad idea to get this information from on line unless you go to the website for the fan and see if they have the correct wireing diagram on their website......
Jun 27, 2009 | Craftmade International Craftmade Omni in...
Hampton Bay 52 In. Cameron II Plus Ceiling Fan, Brushed Steel & Cobalt Blue Finish Logo
182 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Steve Allison
Steve Allison
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
