Question about HP Photosmart C7280 Laser Printer
Default page my XEROX PCL6 print a test (XEROX, with date and timr an name of user) with every printig job? how can i stop this default page from being printed every time?
    Scholar:
  • 92 Answers
If you mention the model is easier but you can go tot he driver setup and check under options you should have a opt to disable Banner Sheet.
Posted on Aug 27, 2010
  • 24 Answers
You did not list the model number, but usually you go to Start>Settings>Printers and Faxes and right click on the Xerox Printer and choose properties. Go to the ADVANCED tab and choose Printing Defaults. Now look at the Advanced tab in this window and select Paper/Output. Look for Banner sheet and choose disable. Apply and save and exit.
Posted on Jun 25, 2009
4 Suggested Answers
SOURCE: HP Laserjet 4250 PCL6 prints only one page
I've had this problem before as well. I went into advanced printer settings and restored factory defaults.
Posted on Dec 18, 2008
chanddra2009
  • 615 Answers
SOURCE: hp psc all-in-one 1315.
Dear Sir,
Welcome back to Fixya
After changing ink cartridge,did you let the unit do an alignment? If not, you need to allow the unit to finish the alignment.If couldn't print another "alignment page" since the print queue was frozen in "pending" status ,so open the printer and remove and re-insert the ink cartridges.
Then place that "alignment page" on to the scanning bed and press the printer's scan button. The scanner startup again and 60 seconds later, then it start printing the documents remaining in the printer queue.
I think it deffinately solves your problem.If you have any problem regarding this issue leave a feedback we were happy to assist you.
Have a Nice Day!
Posted on Oct 01, 2009
Testimonial: "The information was helpful. (I had already done all suggestions. they are the solutions of choice.) Problem solved - but why?!!"
SOURCE: Using hp laserjet p3005n, when I print one page it sends blank pg
Annoying but easy to solve.
Go to the printer's ip address management page from a web browser. Look under the TCP/IP address settings. Click on the advanced selection. Disable the LPD Banner page. That should fix it, if it's not under advanced poke around until you find LPD Banner Page. ;)
Posted on Oct 08, 2010
Xerox Phaser 7800DX not printing one particular file; error code 389.601.00
Make sure your are using Postcript Driver & not the PCL6 driver and that the document page size and the paper page size in trays are the same.
Dec 26, 2013 | Xerox Phaser 7800/dx Workgroup Laser...
Printer won't print. I went to printer and it says there are 9 items to br pringted in queue but they won't print Printer says it is ready
Good Day Nanawhit!
That happens all the times when first print job encounter a problem and stops printing and it was followed by series of print jobs. Some reasons for stop printing could be a printer out of paper and printer not set as default printer.
The best way to fix it is to cancel all pending jobs. When print jobs window is cleared off pending print jobs, restart your PC and your printer. Then go to your printer and make sure it is the default printer.
After that try printing a test page. Once a test page is successful, you can now print as many as you want.
Jun 10, 2011 | Lexmark X2670 All-In-One Printer
Please help. The device prints once and then stops printing until restarted. This process continues between every print job. The message printed out from the printer is as follows: ERROR:...
This is a corrupted Postscript error.
Possible solutions are, reload up to date driver and/or firmware. Go to Xerox website address below for drivers and firmware.
http://www.support.xerox.com/support/phaser-4500/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB
This could also be a program specific problem, try printing from another software package.
Finally, you could try an NVRAM reset. Go to 'Troubleshooting', 'Service Tools', 'Reset NVRAM'. WARNING, before performing an NVRAM reset, print out a configuration page. 'Information', 'Information Pages', 'Configuration Page'. This print out will give you all the printers settings, including your network settings, which will be lost through the reset. You will need to re input them through 'Printer Setup', 'Connection Setup', 'TCPIP'.
Hope this helps.
Jan 21, 2011 | Xerox Phaser 4500 Printer
Xerox WorkCentre 5230A email print problem.
I changed my default printer to a machine which works properly
Oct 07, 2009 | Xerox Office Equipment & Supplies
Print job stops HP 4350
iPAQ hp 4300 palmtop broken screen
Jul 14, 2009 | HP Computers & Internet
Hp 2420 prints a ''job storage status page'' after each print job
If you have your software driver or print job set to save your print jobs to the printer and your printer does not support this, you will get that error and status page. Here is what the User's manual says about print job storage:
"The printer supports two distinct job-storage features that you can use to initiate printing from the printer control panel after the print job is sent from the computer:
● Proof and hold jobs
● Private jobs
Make sure that you identify your jobs in the printer driver before printing. Using default names might override previous jobs that have the same default name or cause the job to be deleted.
The job-storage features require 48 MB of RAM. For printer models that have less than 48 MB of RAM, you can add memory so that they can support the features."
Mar 17, 2009 | HP LaserJet 2420 Printer
Error code PCL6 incomplete session by time out
That is normally caused by firmware corruption. You can go to Xerox.com, click on support and drivers, then in the search box enter pe120, then go to drivers and downloads and download the newest machine firmware . There are directions on how to install the firmware , make sure you follow them step by step. It's pretty easy and should resolve your problem.
Feb 12, 2009 | Xerox WorkCentre PE120 All-In-One Laser...
Xerox M15 PCL6 error
I would go to the xerox website and try downloading the PCL5e driver. It works just as well and even better in most cases. I hope this helps.
Dec 07, 2008 | Xerox WorkCentre M15i Laser Printer
Xerox Phaser 6100 will not print
Yeah you need to replace that imaging and transfer units for it to print. That has a counter on it and once it comes up with that message it will not print anything.
NOW THE WARANING. Once you replace the unit. Everything you have sent is in the memory and will print out.
What you will want to do is once it starts printing, continue to cancel the jobs until they are all out of memory. Believe me, the jobs are there....
Oct 09, 2008 | Xerox Phaser 6100/BD Laser Printer
How to setup secured printting on a xerox workcenter pro90 copier?
Solution: Send a Secure Print Job From a Workstation bttn_print.gifMake Printable bttn_email.gifE-mail this page elem_1_spacer.gif
  1. With your document open in the application, click on [File] on the toolbar and then select [Print] from the menu. The Print window will be displayed.
  2. Select the printer in the Name field.
  3. Click on the [Properties] button.
  4. Click on the [Paper / Output] tab.
  5. Select [Secure Print] from the Job Type pull-down menu.
  6. Click on the [Setup] button (just below the Job Type menu) and enter a 4 to 10-digit code, to release the job at the printer, in the Enter a 4-10 Digit Secure Print Passcode field.
  7. Enter the code again in the Confirm 4-10 Digit Secure Print Passcode field, and then click [OK].
  8. Make any other required selections in the print driver and the click [OK] twice to send the job to the printer.
Solution: Enable Release All for Secure Print bttn_print.gifMake Printable bttn_email.gifE-mail this page elem_1_spacer.gif NOTE: This solution assumes Microsoft Internet Explorer is being used as the web browser. Other web browsers may vary. You may need to contact your System Administrator to perform this solution as it requires knowledge of the network’s Authentication environment.
The WorkCentre Pro will have to be configured for TCP/IP (IP Address, Subnet Mask, Broadcast Address, Gateway Address).Before you begin, print a Configuration Report and make sure the WorkCentre Pro has an IP address, and the HTTP protocol enabled. See the Related Items below.
From the workstation:
  1. Click on [Start], point to [Programs], and select [Internet Explorer] to open an Internet Explorer browser window.
  2. Enter the IP Address for the WorkCentre Pro followed by /diagnostics/secureReleaseAll.dhtml in the Address field, and then press [Enter] on the keyboard. For example, type: xx.xxx.xxx.xx/diagnostics/secureReleaseAll.dhtml (where x represents the IP Address). A Secure Print Release All window will be displayed.
    NOTE: The URL is case sensitive; secureReleaseAll must contain a capital R and capital A.
  3. When prompted, enter the username and password in the fields provided.
    NOTE: The default username is admin and is case senstive. The default password is 1111.
  4. Click on the check box next to [Enable release of all secure print jobs with the same user name and passcode] to insert a check mark.
  5. Click on [Apply].
  6. Click on the [X] in the upper, right corner to close the browser window.
Oct 03, 2008 | Xerox Computers & Internet
HP Photosmart C7280 Laser Printer Logo
182 people viewed this question
Ben Johnson
