Question about Kitchen Ranges
We have a problem with our woodburning stove we get a lot of downdraft and not enough draw . Carole
  • bichonfrise Nov 05, 2008
    Hi Robotek
    It`s a heater hope you can help as I can tast the wood smoke a lot of the time.
    Regards bichonfrise
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hi bichonfrise
    i have an interest in wood fired ovens, what exactly do you have there. Is it a heater, or a cooking stove?
    regards
    robotek
  • 1,512 Answers
Hehehe i can know what that is like....
Is it a slow combustion heater? What sort of wood are you burning
Posted on Nov 05, 2008
How do I stop downdrafting? Is there a damper that could be installed? We live off grid and power consumption is a consideration for us.
Downdraft will extinguish the pilot light flame too. there are flue fans that run off solar. You might want to look into one
Mar 09, 2016 | Water Water Heaters
Why do I have tar running down pipe to woodburning stove when the fire has been burning for a couple of hours?
if you are burning pine it has a lot of sap in it keep chimney clean or you will get a fire in the chimney
Oct 13, 2014 | Finlandia HAR20ST Harvia Stove Sauna Room...
Smoke and soot from my pleasant hearth stove
Your chimney must be properly installed above the roof line to prevent downdraft. The soot issue may be cause by burning wood that is too green, not dry enough to burn clean.
Safety is a concern when using a wood stove in your house. Be informed about the dangers of Carbon Monoxide Poisoning.
http://carbonmonoxidedetectoralarms.com/
Carbon Monoxide Detectors are mandatory by law in some states. Protect yourself and your family.
Amazon com carbon monoxide detector Electronics
Mar 23, 2014 | Pleasant Hearth Home
Need users manuel for firefox 8 woodburning stove
For more detailed information about this product including down loadable technical user & installation instructions, simply click on the link directly to their website www.galleryfireplaces.co.uk or www.tiger-stoves.com.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day
Dec 19, 2011 | Kitchen Ranges
We have just had a wood burner stove fitted at some cost and we seem to have rather a lot of smoke smell in the room we thought with a stove this wood eliminate this . .
You won't be able to eliminate all smoke odors with any woodburning system that I am aware of. On a new installation it's possible that part of the smell is coming from light oil coatimg on stove from manufacturer burning off. I would also check setting on damper,and make sure chimney is clean. On manual damper I set them at full open at start. Then when I have a good hot fire going I shut mine down to 3/4. I would do some trial and error to find what works the best for you. I hope this helps. Thanks
Nov 24, 2010 | Heating & Cooling
I purchased an aqua star 1600h-lp to be installed in a cottage. Question is, the cottage is heated with a large wood stove/fireplace. The water heater is located in a bathroom at the other end of the...
I would say that the wood fire/stove must have a heck of a draw to affect the bathroom heater. Maybe a separate air supply from outside via a pipe,to the stove meshed off against vermin would decrease the problem. Plus it could stop cold air being sucked across the room from an outside door.
Downdraft through the heater could happen with either vertical or horizontal vent. More important is the direction of the prevailing wind [horizontal] ingress of water/snow etc [vertical]
We often use the separate air supply in the UK and if the pipe bore is large enough 4" plus it seems to work ok.
Mar 20, 2010 | Bosch & Tankless LP Hot Water Heater
What causs downdraft on a stove?
Purchase a extension pipe along with a cap. These caps allow the exhaust to escape but discourage reverse air flow they look like and upside down funnel.
Dec 08, 2009 | Blue Rhino Outdoor Wood Burning Fireplace...
Distant needed around a woodburner stove in a fire place.
This type of outdoor fireplace is only designed for outdoor use. If you are thinking of using it indoors, I would not suggest it. The exhaust flume if not made to be used on the inside of a house. It should only be used outdoors with ample space around it to avoid touching patio furniture, grills, etc.
Oct 18, 2009 | Blue Rhino Outdoor Wood Burning Fireplace...
Does stove-top need downdraft if microwave has oven-hood combo?
We have a stove with no downdraft, and a microwave with a hood above it. It works just fine. I expect you could keep your downdraft and put a microwave without a hood above it, and that would also work. I don't think, however, you can buy an above the range mocrowave oven, that slides in on brackets, which will not have a hood.
Jan 08, 2009 | Microwave Ovens
What is the minimum distance you need at the back of woodburning stove
thats gonna depend a few different factors, your stove manufacture will give you their minimum requirement, and then i would ck with the local town codes.
Oct 26, 2008 | Stoves Kitchen Ranges
Kitchen Ranges Logo
129 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
