Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Clean Light Flashes
The problem I have is the LED Clean Light Flashes constantly. I turned the circuit breaker off and then on after a 15 minute delay. I would like to know the exact reset sequence for this KitchenAid dishwasher model KUDI0FLSS6. After the reset, are there any special sequences to get it running again? Randy
  • 9 more comments
  • AlexVersluis Mar 22, 2008
    I have a sililar problem. The green light next to the "Clean" button blinks 7 times. Resetting the breaker does not work. I can't find a reset button. Does anybody know a reset sequence?? Please help.
    Thanks
    apversluis@gmail.com
  • AlPal Mar 23, 2008
    Same problem. There is supposed to be a tech sheet behind the kickplate with diagnositc codes and a reset, but I have none. Help!
  • lisa_oli Mar 26, 2008
    AlPal solution worked for us!!!
    Thank you so much!
  • BN1336 Aug 31, 2008
    This was wonderful, and it worked. I had a Kitchen Aid model KUDS01DLSS6 and this solution worked on it. Thank you everyone.
  • 1cassie1 Sep 01, 2008
    I have a Kitchen Aid dishwasher, model KUDR02FSSS3. The "Cancel" light continues to blink or the "Normal" and "Light China" lights flash back and forth. The other restets for the KUDI series do not work.
    Any ideas?
    Thanks
  • Garuda 1 Sep 26, 2008
    i think i have a similar problem my kitchen aid KUDP02FRSS1
    (this is built in)
    the normal and cancel LED green lights are blinking contiueously. I cant cancel or stop it. and i cant use my dishwasher.
    is there a reset or someway i can fix this without spending money to call over a kitchen aid rep. to look at it.
    thanks
  • tavareschris Oct 28, 2008
    The clean light blinks seven times and than starts over. Nothing appears to be working. I have reset the diagnostics to see if it made a difference, but it has not. the clean light is no longer on, but now it fills up with water, but doesn't start. Not sure what the problem is.
  • khcpharmd Nov 02, 2008
    My kitchen aid dishwasher (KUDI01ILBT6) stopped working. The normal light is flashing and the cancel light continues to flash, but it does not start. Does anyone know the reset sequence code for this model?
  • RIC-RAC Mar 03, 2009
    Do you know the reset button pressing sequence for a kitchenaid dishwasher KUDI01TJWH0?
    The reset button pushing seq worked for my kitchenaid dishwasher KUDI01TJWH0. Yah!!
  • Anonymous Mar 26, 2014
    Tried turning off circuit breaker, still will not reset. Control buttons on inside of door. Clean LED light blinking in 4 series.
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Posted on Mar 24, 2008
  • 5 more comments
  • Lesl Dec 05, 2010
    Unbelievable! You are the best for posting this! Saved me a ton of money on a service call. I had tried the button pushing sequence already, based on another website's recommendations, but I had not know to close the door first then crack it open and press the buttons, then close it again, then press cancel. The closing and opening of the door in that sequence did the trick, while just pushing the buttons did not. Thanks so much!
  • stealth003 Jun 30, 2011
    Thank you AlPal, I have a different model but was able to figure out which two buttons to use to get the reset to work on mine.
  • sandslund Jul 26, 2011
    worked for me too - great advice and great site. I was about ready to buy a new dishwasher, any brand other than a Kitchen-Aid
  • Debi Jones
    Debi Jones Nov 02, 2011
    Thank you SOOOOOO MUCH!!!! It worked on our Whirlpool Gold model DU1048XTPQ0 too!! Our display panel also gave a little differant choice (high temp wash, heated dry, high temp wash, heated dry) Using your open the door along with that sequence and then the closing the door and pushing cancel, it worked! We were also ready to order a heater element circuit as the trouble shooter area in the book advised, but decided to give your idea a try first. You saved us a bunch of time and money, THANK YOU!!! The Jones Family in Oregon
  • Aubrey Thompson
    Aubrey Thompson Apr 15, 2014
    Thanks for this post! I have a tankless water heater and the wimpy small bore valves in this dishwasher don't allow enough flow to trigger the water heater reliably. The Thompson family in Wilmington, NC
  • Sarah Voelkel
    Sarah Voelkel Apr 21, 2014
    What if you can reach the cancel button while the door is closed? Trying this sequence to hopefully clear the error code on our DW.
  • Anonymous Oct 16, 2015
    Thank you for this post ... our Kitchen-Aid came with the house we bought 8 years ago ... never had any problems until now ... wasn't ready to purchase a new one ... I notice most of the new models (different brands) don't give you enough space for your dishes etc. ... will be keeping this one for a little while longer thanks to you.
    New Friend:
OMG. The reset sequence worked perfectly with my KUDP02FRSS1 KitchenAid! So happy. You rock, AlPal.
Posted on Feb 26, 2015
The problem is; it happens just about everytime I use it
Posted on May 06, 2012
Wow, thank you soo much...worked on my kitchenaid and GREATLY reduced my stress ;)
Posted on May 13, 2010
It worked for my kitchenaid dishwasher KUDI01TJWH0!!!!!!!!! Thanks
Posted on Mar 03, 2009
Thanks Al pal, it worked!
Posted on Oct 16, 2008
How do I unlock my Competence oven door?
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool.
Dec 04, 2017 | Ovens
Trying to set switch for 5 minutes , and i only get 30 seconds or 15 minutes
Which brand and model number specifically?
Leviton: 1-800-824-3005
Leviton Decora manual says:
"PR180 operates by detecting motion (such as body heat) within its field-of-view (area of coverage) and automatically switches lights ON. When motion is no longer detected, lights remain ON for a selected time and automatically switch OFF.
Adjustable light and time-delay controls are located on the front of the device."
The manual is not specific about set times.
In any case, the device has off-delay timing circuit, so once infrared heat is no longer sensed, the delay period begins, and once the delay period expires, the device is switched off.
Delay timing circuits are common for many home and industrial applications.
As a general rule, delay timers can be set for different time durations, however the Amazon page that sells PR180 product does not specify available time settings either.
Legrand RW3U occupancy sensor spec sheet says adjustable time delay 15 seconds 5 minutes, 15 minutes and 30 minutes
http://www.amazon.com/Legrand-RW3U603I-Occupancy-Vacancy-Decorator/dp/B005FMLL5G
Delay switches
Here is manual delay-time switch Tork SS20 SS13 where you can 'fine-tune' the delay circuit, but my experience is that exact 5 minutes is not easily set:
http://waterheatertimer.org/images/Paragon-ET-series-243.jpg
GE 15318 switch offers 5 minute, but there is no guarantee that you can get 5 minutes exactly:
http://waterheatertimer.org/images/GE-15318-countdown-timer.jpg
My conclusion is that there are very limited delay-time choices with this model number, or device is defective and suggest to call Leviton.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 23, 2012 | Leviton R01-PR180-1LI Decora 180 Degree...
I am wanting to energize a relay for 3 min. then off, whether the power stay's on to coil or not! what I want to do is when a door rises and hits a switch I want to energize a coil for 3 min. whether...
You want 3 minute 'off delay' timer.
When timer is energized with push button or momentary electrical signal, circuit remains ON for set amount of time, and then turns OFF.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Aug 15, 2011 Dayton/ Grainger website is offline
Most delay timers have 1 amp capacity rating, so circuit needs fast acting 1 amp fuse, and timer controls separate relay or contactor unless Load is equal to 100 watt light bulb.
3-minute off delay pin timer
Omron shows 120Volt 8-pin M-series-(minute) 3 minute delay timer
Part number H3CR-H8L 120volt M
http://waterheatertimer.org/pdf/Omron-timers.pdf
Example 240Volt timer showing timer and base.
http://www.sourcingmap.com/ah33-220v-030-minutes-delay-timer-relay-socket-p-119441.html
Wiring diagram shows on side of timer.
Aug 15, 2011 | Amperite Dayton Solid State Timer On Delay...
What are the carrier 8000ts led error codes?
They are listed inside the front panel of the main unit.
LED CODE
EACH OF THE FOLLOWING STATUS CODES IS A TWO DIGIT NUMBER WITH THE FIRST
DIGIT DETERMINED BY THE NUMBER OF SHORT FLASHES AND THE SECOND DIGIT BY
THE NUMBER OF LONG FLASHES.
STATUS
11 NO PREVIOUS CODE - Stored status code is erased automatically after 72
hours. On RED LED boards stored status codes can also be erased when power
(115 VAC or 24 VAC) to control is interrupted.
12 BLOWER ON AFTER POWER UP (115 VAC or 24 VAC) -Blower runs for 90
seconds, if unit is powered up during a call for heat (R-W closed) or R-W opens
during blower on-delay.
13 LIMIT CIRCUIT LOCKOUT - Lockout occurs if the limit or flame rollout switch is
open longer than 3 minutes.
- Control will auto reset after three hours. - Refer to #33.
14 IGNITION LOCKOUT - Control will auto-reset after three hours. Refer to #34.
21 GAS HEATING LOCKOUT - Control will NOT auto reset.
Check for: - Mis-wired gas valve -Defective control (valve relay)
22 ABNORMAL FLAME-PROVING SIGNAL - Flame is proved while gas valve is
de-energized. Inducer will run until fault is cleared. Check for:
- Leaky gas valve - Stuck-open gas valve
23 PRESSURE SWITCH DID NOT OPEN Check for:
- Obstructed pressure tubing. - Pressure switch stuck closed.
24 SECONDARY VOLTAGE FUSE IS OPEN Check for:
- Short circuit in secondary voltage (24VAC) wiring.
31 PRESSURE SWITCH DID NOT CLOSE OR REOPENED - If open longer than
five minutes, inducer shuts off for 15 minutes before retry. Check for:
- Excessive wind - Proper vent sizing - Defective inducer motor
- Low inducer voltage (115VAC) - Defective pressure switch
- Inadequate combustion air supply - Restricted vent
- Disconnected or obstructed pressure tubing
- Low inlet gas pressure (if LGPS used)
If it opens during blower on-delay period, blower will come on for the selected
blower off-delay.
33 LIMIT CIRCUIT FAULT - Indicates a limit, or flame rollout is open. Blower will
run for 4 minutes or until open switch remakes whichever is longer. If open
longer than 3 minutes, code changes to lockout #13. If open less than 3 minutes
status code #33 continues to flash until blower shuts off. Flame rollout switch
requires manual reset. Check for: - Restricted vent
- Proper vent sizing - Loose blower wheel - Excessive wind
- Dirty filter or restricted duct system.
- Defective blower motor or capacitor. - Defective switch or connections.
- Inadequate combustion air supply (Flame Roll-out Switch open).
34 IGNITION PROVING FAILURE - Control will try three more times before lockout
#14 occurs. If flame signal lost during blower on-delay period, blower will come
on for the selected blower off-delay. Check for: - Control ground continuity
- Flame sensor must not be grounded
- Oxide buildup on flame sensor (clean with fine steel wool).
- Proper flame sense microamps (.5 microamps D.C. min., 4.0 - 6.0 nominal).
- Gas valve defective or gas valve turned off - Manual valve shut-off
- Defective Hot Surface Ignitor
- Inadequate flame carryover or rough ignition
- Green/Yellow wire MUST be connected to furnace sheet metal
45 CONTROL CIRCUITRY LOCKOUT Auto-reset after one hour lockout due to;
- Gas valve relay stuck open - Flame sense circuit failure
- Software check error
Reset power to clear lockout. Replace control if status code repeats.
If status code recall is needed, briefly remove then reconnect one main limit wire to display
stored status code. On RED LED boards do not remove power or blower door before initiating
status code recall. After one status code recall is completed component test will occur.
Thanks for Choosing FixYa.
Kelly
Oct 05, 2010 | Heating & Cooling
My pb10 subwoofer will turn on when it gets a signal but won't stay on. It just constantly flashes on and off to the beat and the sound is distorted.
2 possible causes. The power supply is failing, bad or leaky caps. Or, the cap for the timing delay on the 'turn on' circuit is bad and now there is no time delay...
Can you switch to constantly on as a test?
Mar 23, 2010 | JBL PB10 Subwoofer
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
Clean LED constantly flashes,only function is drain
If it's a Whirlpool, and flashes seven times, then you have a heater circuit problem. You would need to diagnose which component is at fault
Affordable Appliance Reapir
Lake Forest, CA. 92630
Aug 23, 2009 | Dishwashers
Dishwasher Clean light blinks constantly.
Try turning off the power to the dishwasher at the circuit breaker box. leave the power off for 5 10 mins and then turn breaker back on and try to restart dishwasher. This may reset the board and it may work
Feb 05, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Centrex a/c keeps shutting off every 15 minutes ( split system)
To start, check your condencer fan and make sure the condenser is clean.After that you will need a technician with instruments. If the switching off is constant, after approx. every 15 min.it could be switching off on high pressure.
Feb 02, 2009 | Heating & Cooling
My maytag Jet Clean EQ Plus seems to be stuck on the three minute delay
Hi 9897,
I'm Harvey the Master Plumber.
Your problem is: The red light for the three minute delay is staying on and you can't get a cycle to start
First try to reset the d/w. Turn off the power at the circuit breakers for ten minutes. This useually solves the problem. If not, you're likely looking at a bad control board.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 27, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
5,116 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
