Question about Sharp AL 1631 Copier
AL1644 Sharp Where can I down load free the scanner driver for the sharp Al1644? I have lost the cd that came with the copier/printer/scanner.
  • 4 more comments
  • purplemoo Nov 05, 2008
    Hi
    Thank you for the information however the scanner drive doesn't appear to be available on that link for XP only for Vista.
    I have tried that it and it appears it is only the printer driver and NOT the scanner driver
    I am not sure that it does if i am honest but when I spoke to someone about this they said that it uses Twain? Does that make any sense?
  • purplemoo Nov 06, 2008
    Thank you for your suggestions have downloaded the driver but it doesn't recognise the device when you do a search.
  • purplemoo Nov 10, 2008
    It is connected by a USB lead
    Ooooo it downloaded ok but didn't work for installing a scanner.
    Thank you for your assistance
    Brigadier General:
  • 6,966 Answers
For a Sharp AL1644, pls start here. Clicking on the Click here under "Drivers and Software Downloads" would open another window, pls enterxx in the box provided for the "Select a Product Code :" and click on "Search" button. Select driver appropriate for your Operating System.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 05, 2008
  • 3 more comments
  • Louie  Role
    Louie Role Nov 05, 2008
    Appreciate the quick reply, although I tried downloading for XP and the file exists.
  • Louie  Role
    I understand, I have had the same experience with an HP1150C. The idea is that this manufacturers get the engines of one scanner and another printer and joins them up to come up with a multi-function machine.
    If I may ask, when you boot fresh the computer with the printer/scanner on, does the PC detects "New Hardware found"? If yes, does it say what particular model? If we can determine the model of the scanner engine, then we can try it again.
    Cheers.
  • Louie  Role
    "Twain" might be the magic word. Pls start here.
    • Near bottom right, do again the Click here under Sharp Europe - Manuals and Downloads;
    • click on the "Drivers" button near the top;
    • click on Copier / MFD;
    • to limit the selection, pls select English in Languages and Windows XP in Operation System;
    • leave Emulations "All Emulations";
    • leave the Model - Search blank;
    • click on submit button;
    • the top two (2) files are Twain drivers.
    Unfortunately without a model number, I can not verify which is applicable. You are of course free to try any of the two and see which one will work.
  • Louie  Role
    Louie Role Nov 06, 2008
    Hi again,
    Is the AL-1644 connected by parallel or USB pls?
  • Louie  Role
    Louie Role Nov 10, 2008
    I understand, USB connected. Pls try here. You need to enter the shown verification code and thereafter click on the Download button. Although it says AL-1642CS, you will notice that the contents are meant for the 1600 series. What is important is that it contains both printer and scanner. I hope that this one does the trick for you.
    Regards.
No installation cd
Hope the new year started with a bang for you.Please use this to down load Sharp Ar-5320 drivers. Then on the menu, click printers or multifunction, the select on the box Sharp Electronics then select Sharp Ar-m205 and download the drivers for free. Save this file and use it to install.
Jan 07, 2011 | Sharp AR-5320 Black and White Copier
I do not have CD and I cannot find down load to make work on my lap top. Please help. Thank you, Sg
first see if ur printer is compatible with ur windows operating system the if it is compatible go to www.sharp.com for driver download and download also the instruction manual should u not have it also.
Jul 28, 2010 | Sharp AL-2080 Pegasus...
Sharp AL1644 machine does not operate as a photocopier
Do you have any status lights on? If not then you may just have a print button that needs repaired. I have seen this a few times on this series. Try pressing down firmly on the print button while wigging the button around in a circular fashion. If you work a it and all of a sudden the machine makes a copy then the solder connectioons for the print switch have worked loose and will need to be re-soldered. Pretty simple repair. You may have someone locally that can do it. The operation panel comes off pretty easy and the circuit board with the switch is right under this panel. It is a small "button" type switch with small solder contacts that break loose. 10 minute job if you know what you are doing. 20 minutes if you dont. Just need someone with a solder iron and a little skill.
Good Luck and Thank You for using Fixya.
May 06, 2010 | Sharp AL 1631 Copier
I need the scanner/copier part of the driver CD - Sharp AL-1655cs
I'm not sure where you downloaded the printer driver but the Sharp website has a download link to the printer and scanner driver according to their website.
http://www.sharpusa.com/products/TypeSoftware/0,1086,20,00.html
Aug 20, 2009 | Sharp AL-1655CS Laser Printer
Al1644
After you hit clear, density select, clear, density select, the lights showing number of copies selected should go out, they they go out, you are in the Simulation (Service) Mode. Then select 14 and hit the Start Key. You may have to re-enter the Sim. Mode then enter 15 etc.
Aug 11, 2009 | Sharp AL 1631 Copier
Sharp AL1644
The error code happens because the fusing temperature isn't getting to the right setting in time. No reset code is available for the fuser unit. It could be the thermistor that has gone bad with it but usually on this machine it's better to get the whole fuser assembly replaced.
Sep 05, 2008 | Sharp AL 1631 Copier
Looking for: AL1644 Printer Driver for WinXP I got this used fax/copy/scan machine and I download the driver for Sharp but there is no set up file / autorun file Any one have an Idea?
Have you tried to install it yet? If not, go Start>printers and faxes>add a printer. When the wizard box opens up and gets to the point about your driver, tell it to search in this location and then specify the location where you put the downloaded driver at. When it finishes your printer should be installed. If this fixes your problem please rate as fixed. If it didn't, please don't rate yet. Add a comment and tell me what happened and I'll be glad to help you further. Thanks.
Apr 19, 2008 | Computers & Internet
Sharp -AL1644 flashing L6 error
L6 is a Polygon Motor Lock
You could try to reset the machine with a simulation code 14, which to perform it:
1. Push Clear, Auto, Clear, Auto in a steady rythmic fashion. If done correctly the screen will go blank and all the lights will turn off. If done incorrectly wait 15 seconds then try again. Clear is the red "C" and auto is on the left hand side, the word auto directly above the button.
2. Once you're into this mode enter the number 14 as if you were doing 14 copies then push the green copy key.
If the L6 returns after the reset then you will need service on the machine, Sharp will fix it for a flat rate charge of $140.00 for parts and labor out of warranty. Give them a call 1800 237 4277 in this case.
Feb 29, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp AL 1631 Copier Logo
997 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
