How to retart your router
I think I have put the worng IP address into the router. I have tried putting 198.162.2.1 into the internet browser but it doestn work now. Is there a way of clearing the router and starting again. The reset button doesnt do this.
    Sergeant:
    Champion:
  • 327 Answers
Umm ya try this ip might help you 192.168.1.1 or 192.168.100.1
this should be the router ip you can not change it
Posted on Nov 05, 2008
Setting password for wireless router
You can set the password to your wireless in the settings of your router. To get to the settings of your router you'll have to find out the IP address of your router. Usually this is 192.186.0.1 but this can change depending on the make/model of your router.
When you find out the IP address of your router just type this into the address bar of your internet browser and look up the tab that allows you to change the password.
Jan 03, 2014 | Computers & Internet
How to change wifi password?
Go into your router setting and look around until you find change password.
To get to your router settings open your internet browser and put in your IP address in the address bar.
To find out your IP address go to www.whatismyipaddress.com
Hope this helps
Dec 04, 2012 | Computers & Internet
Port forwarding for model number F7D5301
To setup port forwarding on this router your computer needs to have a static ip address. Or you can take alook at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below. Open a web browser like Internet Explorer or Firefox. Enter the internal IP address of your router in the address bar of your browser. If you do not know your routers internal IP address please read our How To Find Your Routers IP Address guide.
The address bar has http://www.fixya.com/AnswerQuestions.aspx#top in it. Just replace all of that with the internal IP address of your router. By default the IP address should be set to 10.1.1.1.
We do not currently know the default username and password for your router.
Click the NAT button near the left of the page.
You should now see a new menu. In this new menu, click Port Forwarding.
Enter the name of the program into the Description box. It doesn't really matter what you put into this box, but something that will remind you why these ports are being forwarded would be a good idea.
Enter the port to forward into the Public Port and the LAN Port boxes.
Use the Protocol Type drop down box to select the protocol type of the ports you are forwarding.
Enter the ip address to forward these ports to into the LAN IP Address box. If you are forwarding ports so you can run a program on your computer, you should enter your computer's ip address into that box.
Put a checkmark in the Enable checkbox.
When you're finished, click Save Setting near the top of the screen to save your changes.
And that's it! You're done!
Feb 05, 2011 | Belkin Basic Wireless Router
The router shows connected but will not connect to internet
u have to configure the router first u have to put the IP address in a router by the given your internet provider if there is something like that 192.168.1.2 then u have change Your router IP address default IP address is 192.168.1.1 u have to change it first u have change it 192.168.0.1 then the give sub-net marks 255.255.255.0 then after gateway address is 192.168.1.1 then after DNS server is 192.168.1.1
1) disconnect router form the internet
2) plug in it in local pc
3) open internet browser
4)type in address bar 192.168.1.1 then press go
5) u got log in screen type there user name admin and pass is admin
6) then go in internet setting do change as i say
Nov 13, 2009 | Linksys Wireless-G WRT54G Router
My problem is I cannot access my router to enter my dvr information to view my cameras on line
Get to a command prompt and type 'ipconfig' - no quotes.
You will see some ip addresses listed. The gateway ip address is the ip address of your router. Put that ip address into the address bar of your web browser and it will take you to the router config page. This is where you can do port forwarding if you want to be able to view the cameras from outside your network. Post a comment if you need any more help.
Or did you just forget your router password........or is the router not responding......let me know :)
Sep 05, 2009 | Computers & Internet
CAN NOT GET SITECOM CABLE ROUTER TO WORK
1) Open your browser
You don't care about connecting to the internet, I don't think.
In the URL line at the top of the screen, enter the aaa . bbb . ccc . ddd IP address and hit enter. You should then get the setup info your looking for.
Jan 22, 2009 | Computers & Internet
I cant reset my senao eoc3610
1 ) Check if IP address is the correct address of your Gateway.
Check if you can ping.
Be sure you have your Java enabled
Some router requires a specific Browser (IE6 or IE7) and cannot respond to different browser.
Be sure to remove any Java protection from your Browser.
Check with user manual if IP address requires also a specific port number ( 8080 or other).
Be sure to Connect Router using Lan cable
2) Change your PC IP setting to same subnet as your router
Control Panel / Network settings / properties of TCP/IP define an IP address and a subnet mask compatible with Router as gateway.
3) If you are not sure of Router IP address use reset button on router back to factory default; use this to configure router.
Dec 27, 2008 | EnGenius EOC-3220 (EOC3220)
Can't access my routers configuration panel
If you want IP address of your wan port you can go to your command portion & just type a ? mark and then enter. You can get the proper command of this oparation. If you want your internet IP Address you can get it from the Internet connection icon / Call your ISP.
Better you try this & message me about results. I think IT ned some more discussions.
Feb 10, 2008 | Computers & Internet
Router
Wijth the router CAT5 cable connected to the host computer, open internet explorer on the host computer, in the address window type http://192.168.1.1 then press the ENTER key. If 192.168..1.1 is the correct IP address of the router you will get the logon screen of the router. BPCS
Dec 28, 2007 | Dynex DX-E401 Router
How do I use the Remote Management feature on my router?
Remote Management allows the device to be configured through the WAN (Wide Area Network) port from the Internet using a web browser. Step 1 Log into the web based configuration of the router by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2 Click the Tools tab and click the Admin button. Step 3 Select the Enabled button to enable Remote Management. In the IP Address field type in the public IP address you wish to manage the router. Note: If you don´t know the IP address or wish to allow more than one IP address to manage the router then put an asterisk (*) in the IP Address field. You cannot enter an IP range. Step 4 By default the port used to Remote Manage the router is set to 8080. Change the port number by selecting the down arrow next to the Port Number drop down menu. Step 5 Click on Apply and then click Continue to save the changes. To Remote Manage the router you will need to type in the Public IP Address of the router in your web browser along with the Port Number (separated by a colon) you selected in Step 4.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
