Question about HP Office Equipment & Supplies
Installed updates, now printer does not work - HP Office Equipment & Supplies
  • 417 Answers
You probably need to update your printer driver. Try reinstalling the printer or you can get an updated driver from the HP website.
Posted on Nov 05, 2008
Fax solutions software stopped working
Uninstall the Lexmark software including the Fax Solutions. Download an updated driver online at www.lexmark.com and install the updated driver. Once you have installed the updated driver, insert the installation CD to install the OCR and Fax Solutions.
Jun 10, 2012 | Lexmark Prospect Pro205 Wireless...
I upgrade my dell lab-top to windows 7 but now I can not print anything on my canon pixma ip3000 printer.
Are you directly connected to the printer? Did you download and install the drivers? (For Win7, this will happen in Windows Update. However if Windows Update isn't set for automatic installation for drivers, you will need to start Windows Update and install the drivers. Just check for updates and install.) Was the laptop connected to the network when you installed the printer? (Windows Update needs the network - make sure your firewall didn't block the program. Wired networks are in many ways better for Windows Update since there are fewer dropped connections.)
Does the printer show up in Devices and Printers (Start > Devices and Printers)? What is its status? Try a new cable or a different port. Make sure the ports are working (check the device manager (Start > Control Panel > Hardware and Sound > Device Manager).) If these aren't working (shown by an x in a red triangle or an exclamation point (yellow triangle) then you should try to update the driver for them.)
Once it is working, you may want to download and install the add-on from here: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=117&modelid=10238#DownloadDetailAct
I hope this helps.
(to download and install device drivers automatically adjust the setting from the System part of the Control Panel (Control Panel > System and Security > System > Advanced System Settings. Choose the Hardware Tab and Device Installation Settings.)
Jun 10, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
My HP F-4180 printer was working fine yesterday...not today!
need to install updates from the HP's website. there is a critical update for your issue.
Aug 11, 2009 | HP DeskJet F4280 All In One Printer InkJet
HP C3180 printer doesn't work after Microsoft updates (vista)
Check the Windows Update history and see which updates were just installed. You can manually remove individual updates - note they will appear again. You can also use the Windows System Restore to go back in time, but the updates will still be applied again so try to determine the update that caused the issues and you can select to ignore the update using custom Windows Update settings (set it to check for updates but not automatically install.
Dec 16, 2008 | HP Photosmart C3180 All-In-One InkJet...
PDell Photo AIO Printer 962 stopped working after windows update
I had the same issue after downloading the Dell AIO 962 printer update. What worked was using the uninstall mode on the original Dell CD that came with the printer followed by a fresh install from the aforementioned CD. Be sure to uninstall all copies of the drivers before doing the new install. Good Luck!
Nov 10, 2008 | Dell 962 Photo All-In-One InkJet Printer
Installation problem
If the driver on the disk is not updated, you must download the updated software from Internet, follow instructions below,
Click here: PSC 1315 Software & Driver downloads
A web page will open, follow instructions, select model, then operative system etc.,go to next page twice, find file, and click on download .
Chose to download the file in my documents when asked.
After downloading,find the file,double click on the file with the mouse, if you get in troubles, then follow the instructions below to reset and reinstall:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download updated driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:this printer does not work on Vista you can only install it on Windows XP.
Oct 10, 2008 | HP PSC 1315 All-In-One InkJet Printer
Installation not completing
Try updating the printer's firmware. I had the same problem with my Windows XP machine and my Kodak 5500 AiO Printer. Then, I went to Kodak's website, looked for my printer, and downloaded their firmware update. The only curious thing is that when I ran the software to update the printer, it said the firmware version of the update was the same as the firmware version the printer already had. I went ahead and updated anyway, and now it works!
Just be careful when updating the firmware on your printer, follow Kodak's intructions.
Jun 14, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Minolta PagePro 1350WN Laser Printer
The driver for the PagePro 1350W does not come with the initial installation of Windows Vista. However when you run Windows Update you will find a updated driver for this printer - just download it and let Windows install the driver. I had the same problem with this printer when I installed Vista - I'm now using Windows 7 and it automatically installed the proper driver for the Konica Minolta PagePro 1350W.
Just keep at it - it should work fine after you install the updated driver.
May 27, 2008 | Minolta PagePro 1350WN Laser Printer
Fax
is this xp home or professional either way get printer driver updates for whatever version of xp you have.
and update service packs
better yet enable automatic updates on your computer then reload printer driver
Nov 17, 2007 | Dell 922 All-In-One InkJet Printer
21 people viewed this question
Seeker5211
Seeker5211
