Question about Mitsubishi VS-45607 45" Rear Projection Television
Picture has greenish tint that I can't adjust out
Techman, I replace the red convergence chip in my Mitsubishi VS-45VA1 a few months ago. All was well until recently when the color started to change, getting a greenish tint that I can not correct. The image looks washed out and anything that should appear black is like a muddy green. Hope this description is accurate enough to help to identify the problem. Thanks DRA
  • Anonymous Mar 23, 2014
    The picture on the tv has a greenish tint to all colors and we cannot seem to be able to adjust the color to make this greeniwh color to go away
    President:
  • 3,130 Answers
There is a crt drive problem and you can isolate it by unpluggin g the set, removing the green crt socket, in the middle of the three tubes is the green tube by the way, remove one of the other tubes and switching the crt sockets and turn it on. If the set is still greenish, then the green crt is bad and needs replacement, if another color is primart, then it is going to be the green crt drive circuit and is going to need to be serviced. Good Luck
Posted on Oct 08, 2006
Hello I have a mitsubishi vs-45603 with what appears to be a convergence problem.
You may have bought bad chips or your soldering...
This is a common problem on many brands of Projection Tv sets. Its usually a convergence issue. You can get more details and a solution here on fixya using this link http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
Mar 22, 2012 | Mitsubishi VS-45603 45" Rear Projection...
Red tinted picture
HI,
Try reseting the TV first by unpluging all the cords for 4hrs and then plug it back.
I will be posting more troubleshooting steps..
Apr 03, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50609 - Red convergence is way off, suddenly
You have a bad ground on a convergence IC. You will have to carefully pull this board out and resolder the pins. If this does not solve the problem you will have to replace the ICs. I have saved a few of these TVs with just a resolder job. Thanks for asking!
Jul 11, 2010 | Mitsubishi VS-50609 50" Rear Projection...
Hour glass cannot adjust red horizontal convergence
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 09, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Toshiba Rear Projection TV picture color is now a greenish hue
Hi, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
If you are not able to adjust the convergence using the remote you will need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Such as: Red moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from www.TvRepairKits.com
Hope this helps :)
Sep 12, 2009 | Toshiba 50H82 50" Rear Projection...
Sony KP-43T75 rear projection set does not finish flash focus. According to manual it should finish by converging to white cross. Mine ends with a pink tint and a blue ghost to the right. Is this something...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Screen looks 3D Colors don't line up One or more colors can't be adjusted when using the convergence menu. Screen is bowed or warped. Here is a quick test.... Using your original remote go-to the TV settings then go to the convergence section. Try to adjust the red and then the blue convergence. You should be able to move them up, down, left, and right. If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem. Solution #1 you need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for most models. If you don't see kits for your set send them a quick note under the contact us button please, you will get an answer within 24 hours or so.(excluding holidays Good Luck
Techman
Your TV most likely has one of two possible problems. Problem #1: Convergence Chip Failure ( common problem ) Here are some of the most common symptoms and example photos of a convergence problem Screen looks 3D Colors don't line up One or more colors can't be adjusted when using the convergence menu. Screen is bowed or warped. Here is a quick test.... Using your original remote go-to the TV settings then go to the convergence section. Try to adjust the red and then the blue convergence. You should be able to move them up, down, left, and right. If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem. Solution #1 you need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for most models. If you don't see kits for your set send them a quick note under the contact us button please, you will get an answer within 24 hours or so.(excluding holidays Good Luck
Techman
Sep 06, 2009 | Televison & Video
Blue convergence is shifted right slightly
CHECK FOR THE SUFECE MOUNT CAPACITORS AT THE SMALL CONVERGENCE CIRCUIT BOARD
Jul 13, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi tv problem
im assumiong you checked the tint in the menu options. if not go check it. other wise it sounds like you have a weak tube, or you do not know how to adjust the screen brightness. this is how i adjust the brightness (you dont need to touch the focus). turn the red up until your whole screen is tinted red, then do the same with the blue and the green. then go through each one and turn down just a little till your pic darkens a little. good luck
Sep 27, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
256 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
