Question about Lexmark Optra E310 Laser Printer
Sides of paper blackened
The paper ppprinted shows black on both sides
    Problem Solver:
  • 9 Answers
This is usually a toner Cartridge problem
Posted on Jan 09, 2009
My oven takes too long to heat up. I think the bottom element is not working properly. Is there some way I can test it?
If the bottom element is accesable take a piece of thermal printing paper and lay it on the element, then switch on. If the element is working the paper will turn black where it is in contact with the element, if you are daring, test it as you would your cloths iron, with a wetted finger, if it sizzles, the element is hot. You are not touching the electrical wiring, only the cover, but be fast with the touch test, you do not want to burn yourself. If the element is not directly accesable, try the thhermal paper test over the cover of the element, leaving the door open, it should turn black where the slots are in the cover, and then blacken all over. (Check to see if the oven switch does not have a position where the bottom element is isolated).
Jan 10, 2011 | Whirlpool RBS275PD Electric Single Oven
Artia 6100 machine showing err out of paper.
hi,
ur machines paper sensing sensor have some problem. did u used the paper with black mark on the side.
remove the paper cover . u can see a black square sensor near the side of thermal printer. clean the sensor with an ear bud. do not use any solutions. then check again.
remember use good quality paper. if the black mark on the side of the paper is not perfect this problem can occur (black mark on the paper is for page count and paper sensing)
ok
Dec 23, 2010 | RTO Quinton Cardiology Atria 6100 Ecg...
BLACK STRIP ON THE LEFT SIDE ON MY PAPER??? I HAVE A HP LASERJET 1022NW....WE HAVE CLEANED AND BLEW OUT THE PRINTER....STILL NO IMPROVEMENT....WHAT TO DO NEXT....
Run the 1/2 print test.
Put paper in the manual feed tray. Print a few pages of anything. As the paper gets about 3/4 of the way into the printer, open the cartridge door. Pull out the cartridge and look down at the paper. If it has the black stripe on the left side, replace the toner. In fact at this point, pick up the toner cartridge and gently swing the shutter open and look at the drum. You should be able to see a black stripe on it.
By the way, the toner hasn't been fused to the paper at this point. It will rub off on hands and clothes.
If the 1/2 test shows no stripe on the paper...replace the fuser.
Dec 01, 2010 | HP Office Equipment & Supplies
Not sure how long we've had the PCR-T265, but trying to set it up. Acts like it is printing but nothing shows up on the thermal paper. Thoughts?
You may have the paper loaded back to front. If you scratch the paper quickly with a finger nail, you should see a black line appear. if not, try the other side of the paper. The side which turns black should be facing you while you are in front of the machine. --------------------------------------------------------------------------------
For those of you who need / looking for a Casio PCR-T265 manual, http://the-checkout-tech.com/manuals/cashregisters/Casio3.php
Aug 09, 2010 | Casio Parts Cash Register PC Desktop
SHARP AR5516 PAPER JAM ERROR MESSAGE
when you open side door in the up you see a black unit check if sesor not broken. also open cassete and see inside no paper jam there
May 27, 2010 | Sharp AR-5316 Advanced Digital Imager...
My pixma mp 150 shows me E 2
Error E2.
Action : Reload the paper correctly and press [Black] or [Color].
Loading Paper
Follow this procedure:
1) Open the Paper Support, then pull out the Paper Support Extension.
2) Place a stack of paper (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
- Set the Paper Thickness Lever to the correct position for the paper.
Important : Make sure the stack does not exceed the Load Limit Mark.
Hope this helps.
Have a good day.
Dec 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I have a Brother MFC 8440..the paper has vertical black lines
Try changing the toner, if it's generic that's your problem, and if it's either an old brother drum or a generic you may need a new one. There is also a glass to clean, it's right above where the drum sits inside, 1/2 inch wide across the top. Wipe with a dry cloth.
Sep 14, 2009 | Brother MFC-8440 All-In-One Laser Printer
System halts while pulling the paper
Could be the problem of Exposure lamp .If the lamp end is blackened,it need replacement to get rid of this error(E 803)
Jul 16, 2009 | Canon ImageRUNNER 330s Copier
Paper jam but no paper at all
all sencer of printer clean care fully.
May 18, 2008 | HP Officejet 4355 All-In-One InkJet...
Blackened Screen
thsi indicate the fault in video section of circuit. and if you are not technical you really cannot do anything but take technical assistance. thanks Sangita
Jul 08, 2007 | Bushnell 11-0013 Digital Camera
Lexmark Optra E310 Laser Printer Logo
74 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
