Brand new seagate drive, one month old, full of important data, just stopped spinning. No noise, no spinning etc. Really really need the data off, been offered service for $1000-2000AU. This will also void my warranty. Sucks. What can I do?
  • morgazmo99 Nov 06, 2008
    yeah, definately tried that one. its not the plug or the connection. all plugs work for different devices. its the drive... not happy.. :(
    Thanks tho,
    President:
  • 1,111 Answers
Try another power plug off the power supply. if you dont have a spare, swap the one off your cd or dvd rom to make sure its getting power...make sure the dvd or cd is starting also..does the light on front of the dvd blink while booting up...if so, just try that power plug off that one.
Posted on Nov 05, 2008
Cant open files in seagate drive
The first thing to do is to remove all the connections and re-insert them. Power and USB are the usual connections. You might try eSATA if you have the module. This is an old drive and even with only infrequent use, due to the lack of cooling on the drive, these will have an early failure. If you put your ear really close to the drive, do you hear a spin/stop/spin/stop sequence. Like the drive is spinning up and then stopping over an over? If so, that may indicate a crashed drive. Do you hear another noise or no noise at all?
Jul 30, 2014 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to recove Seagate external hard drive data?
Probably, the new operating system cannot recognize your Seagate external hard drive. You can connect the Seagate external hard drive to another computer to copy data to another device. If the problem still exists, you might need to perform data recovery. You can free download the data recovery software: http://www.icare-recovery.com/seagate-recovery/seagate-external-cannot-be-recognized.html
May 14, 2014 | Seagate FreeAgent Pro 500GB External USB...
I have two hard drives.. WD 320 gigs & Seagate 250 gigs. Both drives are not booting. No sounds, nothing. I tried the freezer technique but not worth it. There's no clicking sound. I think the disc inside...
looking inside was a big error, that floods the internals with dust
the heads will now crash. but its dead anyway,, so no foul.
use your ears, not looking inside. gee. whirrrrrrr, try a good drive and listen, train those ears.....!!!
if it dont spin, or you can not feel the gyro effect (try that on good drive)
then the drive is bad. (or no power, +5v and +12v are mandatory)
you only said Seatage, they make vast types of drives, so I really dont know what you have, not really.
the drive (SATA/PATA but NOT SCSI or SAS) must spin up
with power, if not
1:bad power,
2; bad drive.
end of story.
ever held a gyro, like in boy scouts or? or NAVY.
it fights you when you ,try to change directions, of the drive case.
the gyro effect. all HDD do this., spinning at full speed.
is that enough help, if confused read an A+ book, all this is covered in one book.
if not pata/sata drives, the controller or drive must be commanded
to spin up. (servers use these drives)
Sep 25, 2013 | Seagate Computers & Internet
My 500 gig freeagent go drive stopped working, it
If you have a desktop PC, take the hard drive out of the enclosure and install it as an internal drive. Boot up into the desktop and see if you can read it from there.
The audible clicking of the drive is not a good sign. It may mean the reader arm inside the hard drive is stuck or has malfunctioned.
It's not uncommon for new hard drives to fail suddenly even when only 2 months old. One option available is to take it to a data extraction facility. If you can find a local provider, that would be ideal. They will test the drive to find out if the damage is repairable or not. If not, your only option at that point, if you still want the data, would be to send the drive to a data extraction facility with a clean room where they will take the hard disc platter out of the drive, extract the data for you, and send it back to you on a CD/DVD disc. This option is expensive and can cost anywhere between $500 and $3000. If the data is that important to you, it may be worth your money.
Note: DO NOT attempt to take the platter out at home. Even the slightest amount of dust could prevent you from being able to extract the data ever again.
Aug 08, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
WD800U017 passport problem
The drive in the case is broken. You will have to take the drive to data recovery centre to recover your data.
Aug 03, 2009 | Western Digital Passport WDXML800UE...
Seagate SATA Baracuda 160 GB harddrive crashed
I've found this to just be the nature of hard drives. You never really can trust them, thats why you always need a backup. Maybe look into a fault tollerant RAID solution if it's really important (kinda expensive)
Nov 23, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Washing Machine, Simpson Brand, Esprit 750
Hi Angelina
I am having exactly the same problem. Did you replace the timer, if so did it fix the problem?
Thanks,
Sheryl
Jun 05, 2008 | Washing Machines
WD 500 MyBook stopped spinning
Your options are very poor, unfortunately. You can pull the hard drive out of the MyBook case, and check the connections, and you can try it in another USB enclosure. I don't recommend opening the hard drive itself, although it is (very) remotely possible, IF you can find an exact duplicate of the drive model and firmware version.
Your best bet, perhaps your only choice, is to call a reputable data recovery service, one that can handle a non-spinning drive, and ask them about it. I believe costs run between $500 and $1000.
May I offer a little advice: (I do understand if you are not interested in preachy advice like this, so feel free to ignore it, for now)
1. All drives fail sooner or later, cheap or expensive. You cannot name a brand or drive model for which a few drives did not fail within the first month. And most models even if cheap have probably had a few drives last 5 years or more. Better brands and models may be more reliable, with fewer early failures, but... Western Digital is a decent brand, of average quality. Seagate drives are generally considered better, but they fail too.
2. Any data that has any importance to you MUST be backed up. A backup is a second copy of an original item, physically stored in a second location. If the data item has special or critical importance, it MUST be backed up a third time at least, in a remote location, on a CD or DVD or portable drive or flash, offsite at work or home, or with friend or relative, or even in a car trunk. A better choice is to use a remote backup service/tool such as Mozy or JungleDisk. They are inexpensive, convenient, light on resource usage, and use strong encryption. Also, check out TrueCrypt (free, with strong encryption) for local encrypted storage. But never ever store only one copy of anything of importance.
Dec 03, 2007 | Western Digital My Book Essential Edition...
Seagate drive PROBLEM
I have the same problem. I've been use the HD for about one month and now, after making all my backups and copying them in the HD, it crashed! I believe there is a way to open it and recover the data directly from the SATA port. However, if done incorrectly it will void the warranty. I'll be checking here for any other possible solutions.
Oct 11, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
