How do a change the routers ip address - Computers & Internet
    Problem Solver:
  • 15 Answers
First you need to now the ip add of the router. the standard ip is 192.168.0.1..
good luck
Posted on Nov 05, 2008
I need to get into my nat settings
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
Linksys no longer appears on my laptop for some reason. how do i restore it. i can't go on line without it?
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 08, 2010 | Linksys WRT160N Wireless Router
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
When i try to install my Linksys wireless G, it ask for a password. I don't know it and it won't let me proceed!
Step 1:
Step 2:
NOTE
Step 3:
Nov 04, 2010 | Linksys Wireless-G Broadband Router
Someone has changed my IP address hacked into in my router
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jul 06, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to change default gateway
Default gateway is the IP address of the router.
Connect the computer to the router.
Open the setup page of the router using the current default gateway number.
On the setup page of tghe router, you will see the router local IP address.
You will find the current IP address of the router there.
If you want to change the default gateway, you can change the router Local IP address.
Make sure that it will be a private IP address only and not the public IP address.
suppose the current default gateway is 192.168.1.1.
You can change it to 192.168.x.y. X and Y will be the number between 0 to 254.
Click Here for more information about the routers and network
Jul 03, 2010 | NetGear DG834G Router
Need to change IP address for Actiontec router for verizon fios
definately you will need to change the IP address.
But you can also change the IP address of the wireless extender.
so instead of changing the IP address of the router, you can change the IP address of the extender.
For that you will need to connect the computer to the Extender.
assign a static IP to the computer 192.168.0.10 and Default gateway 192.168.0.30. that will open the set up page of the extender.
change the IP addres of the extender to 192.168.1.30.
that will help you.
For more info about networking click Here
Oct 21, 2009 | Actiontec Electronics (GT724WGR) Retail...
2 Pc's with same IP
AT either desktop or laptop:
[Start]
[Run]
[cmd]
A dark "DOS" windows will appear
At the prompt, type: ipconfig
press [ENTER]
Note the "IP Address" (probably 192.168.1.2)
type: ipconfig /renew
press [ENTER]
Note the IP Address
If it has changed, then you are ok. Type: exit and press [ENTER]
If it did not change, then try this on the other computer.
If that didn't change either, the go to the Control Panel
[Network Settings]
Find the wireless or wired network adapter and Right-Click
Choose "Prpoerties"
In the Properties window, double-click "IP Address"
See the IP Address assigned? change the last digit by one number.
Example: if the IP Address is 192.168.1.2 then change to 192.168.1.3
[OK] [OK][OK]
It should work now...
Let us know!
Sep 17, 2009 | Linksys Wireless-G WRT54G Router
Change ip
Your IP address is assigned (leased) to you from your internet service provider. With that being said, you could possibly call them and ask to release your old IP address and have them assign a new one. If you happen to have a static IP address assigned from your ISP you can call them as well and ask to have your IP address changed too. It would be up to them to change it though.
Sep 14, 2008 | 2wire (1000-400108-001) Router
Accessing router
if you have changed the ip address of the pc that is connected to the router, then the router can no longer see the pc because you have changed it manually, you need to change the router back to DHCP enabled to allocate ip addresses automatically and change the properties of your network card to obtain ip address automatically. This way all the pc's will be given ip address to share the network.
Aug 30, 2007 | Comtrend CT-507 Router
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
