Shuttle error - Office Equipment & Supplies
    Problem Solver:
  • 10 Answers
Please Explain more....
Posted on Nov 05, 2008
TAlly printer T6218 is showing shuttle fault error
may shuttle belt is lose or it is not in proper place. check the shuttle belt and clean the shuttel sensor , your problem will be solve.
good luck and do rate if helped
Nov 30, 2010 | Office Equipment & Supplies
Shuttle fault
If the printer detects the shuttle moving at the incorrect frequency, it shuts down the shuttle and attempts to restart it.
If the shuttle still operates incorrectly after three consecutive attempts, the Printer goes Offline, and the Shuttle Fault message is displayed.
Press the Clear button, then put the printer back Online. If this doesn’t work, turn the power switch off, then back on again.
If the error is still seen after performing the above actions, check there are no paper jams , labels etc or ribbon jams that may prevent the shuttle moving correctly. Also check the Patten gap to make sure it is not closed too much.
Then you may need to change shuttle components
Dec 04, 2009 | TallyGenicom 6306 Matrix Printer
Shuttle jam appear
www.oki.com.tr/binaryData/13882/OKI_UM_250011A.pdf
in this pdf u have got the problem solve the shuttle jam problem
Apr 01, 2009 | Printronix P7010 Printer
Hardware may be
first of all do one thing and that is keep your platen marked A,B,C in b or c position then start printer if it prints then it means your shuttle gets very much tight in position A, for that please switch off the printer remove paper and loose your shuttle and adjust your shuttle according to the movement of paper. also do one thing that is clean your shuttle senser also.
Feb 19, 2009 | Printronix Line Matrix P5005B Printer
Error 058 Shuttle Jam on an IBM 6400 Matrix printer
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 06, 2009 | IBM 6400 Matrix Printer
My Tally T6218 gives the following error message shuttle fault
Nov 30, 2008 | Tally T6218 Matrix Printer
058 SHUTTLE JAM "ERROR"
See this post:
http://www.fixya.com/support/t746596-shuttle_jam_see_manual_problem
Jul 09, 2008 | Printronix Line Matrix P5210 Printer
"Shuttle jam" see manual problem on Printronix line matrix P 500E printer
Verify that there is nothing clamped between the platen and the shuttle.
Last time I had this fault, it turned out to be a broken wire in the harness that connects the CMX board to the shuttle module.
Other possibilities include a failed shuttle or CMX board.
Steve W
LazerTek LLC
Jul 06, 2008 | Printronix Line Matrix P5005B Printer
SHUTTLE ERROR
check shuttle sensor (during trasmission it will show 5v and when it does not reflect it will show 0.4v) and see where there is ant teer in shuttle belt..
May 12, 2008 | Tally Line Matrix T6050 Printer
22 people viewed this question
jasbo
jasbo
