Question about JVC AV-27D303 27" TV
Picture problem The picture is too dark and the colors are not right. I am not able to adjust them with my remote. please can you help me.
    Sergeant:
  • 337 Answers
You will need the assistance of a servicer,I dont know the age of the set but there is a possibility the picture tube might be going bad based in the description of the symptoms,there is one other possibilty ,that is all the voltages are low because of a bad regulation in the power supply but a servicer will know as soon as he sees the set,ask for an estimate and then make a decision,Is the best We can do without seing the picture.Let Us know if you need more information.
Posted on Oct 09, 2006
Picture has too much blue, and picture is dark
Go to your TV MENU (you can find the button on the remote or on the TV itself)
Go to PICTURE SETTINGS- here you will find color settings and brightness settings
Go to COLOR SETTINGS and just adjust the bars until the picture on the screen is the right color.
Go back and click on BRIGHTNESS- here you can adjust the bar to make it brighter and easier to see your picture.
Save your settings and exit the tv menu.
May 23, 2011 | Televison & Video
My sony flat screen works but when I turned it on the colors are blue and purple. Picture not clear but sound is ok. Colors are off.
Press "Input Select" on the remote control and select "TV Mode."
Press "Menu."
Press "Enter" to select "Picture."Use the arrow buttons to select
"Picture Setting."
Press "Enter."Use the arrow buttons to select "Color."
Press "Enter."
Use the left and right arrow buttons to adjust the color settings. When you are pleased with the color setting, press the "Exit" button on your remote to exit the menu screen.
Hoped this helped
Mar 18, 2011 | Televison & Video
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
Need help adjusting the color. It is really dark.
Have you used the menu button on the remote to select the factory choices like Standard Vivid or whatever this set calls the easiest video selections?
Hit menu to see what comes on screen and use the up down or left right buttons usually in the center of the remote.
Then in the ctenter of them hit enter or select to see f the picture changes.
The same can be done for Audio and others.
Oct 19, 2010 | Vizio VA26L 26 in. LCD HDTV
Color was bad couldn't adjust it better , then last week red curvy lines showed up on the bottom om screen . opened the back and found 6 adjustment knobs slowly turned one and screen went dark. repowered...
sorry but those adjustment are not the right one , to correct the color problem u have frist , u need to hire a tv tech , tv would has to adjust the screen and focus back to normal after that , need to replace the oil on green and blue picture tube
Apr 12, 2010 | Philips Magnavox 9P6034C 60" Rear...
Dark Color on TV. Can't adjust the color correctly
Having same problem now for a second time on a 57T500. First time was a bad green bulb that was covered under warranty. Only lasted 2 years....currently debating wether to fix or buy a new set. Bulbs cost about $300. Set is only 5 years old, so very dissapointed with quality.
Feb 01, 2009 | Hitachi 57F500 57" Rear Projection...
JVC 27" TV
Adjustable Color Temp. The Adjustable Color Temperature feature lets you adjust the color balance on your TV, depending on the type of light in the room, such as direct sunlight or artificial lighting. On your remote control there should be a button that lets you change the picture mode, IE. Rich, Personnal, Cinema, Sport etc...
Feb 21, 2008 | JVC AV-27D305 27" TV
Aadjusting screen colors
They should be adjusted to set voltages. however it is best to shut the color level to the lowest setting then try t balance the screens to achieve the best black and white picture. then turn up your color level. Your brightness level should also be set to 50 % then when you adjust for the best B&W picture. You will have better color and brightness when you reset your color and brightness levels. Hope this helps.
Feb 01, 2008 | Hitachi 57F500 57" Rear Projection...
Pitcture is Wavy
Sounds like the tuner is going.
Dec 05, 2007 | Akai PT4799HD Rear Projection Television
JVC AV-27D303 27" TV Logo
66 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
