Question about Acer PD725P DLP Projector
No colors hi my projektor dont show color projections. It projection only black and white color. Please help me? Thanks
2 Suggested Answers
  • 23 Answers
SOURCE: it not bringing out color.it
HI,
I will need some clarification as to the model number of your projector to best help you but in general if you have a DLP type projector & suddenly lose all color to your image then the color wheel has failed by burning out or breaking. The color wheel sits directly in front of the projection lamp & if you take your lamp out you can use a flashlight & point it in towards the spot where the light comes out of the lamp & look at the color wheel. The color wheel has 4 to 6 different color pieces called segments like yellow, red, blue & a clear segment. You will be able to see if the color wheel is broken.
If it is you need to have the unit serviced. If you're handy you may be able to order a new color wheel. They are usually around $100. There can be other causes as well but the wheel is the first place to investigate. Please let me know if this was helpful.
Thanks & good luck,
Jim
Posted on Apr 15, 2011
Our tv the color is gone just black and white what do i do
Hi Glenn,
Just change your region into SECAM / PAL / NTSC on your TV to change the color of it.
I hope my solution may help you.
Thanks for using Fixya...;-)
May 05, 2014 | Akai PT5492S 54" Rear Projection...
Originally got blinking lights to indicate a bad bulb. Had a spare bulb that I installed. Now a very loud noise from color wheel and only a black and white picture.
Bad color wheel is cause of noise and black and white picture in tv, please replace color wheel to solve the issue.
Required color wheel is available in SamsungParts for $120
Thanks.
May 13, 2011 | Samsung HLM507W 50" Rear Projection HDTV
WE BOUGHT Philips 43PP7445 PROJECTION TELEVISION BUT THE COLOR DID NOT COME OUT WELL IT IS SHOWING BLACK AND WHITE......PLS HELP
Hi Victoria,
The problem is the system set-up. Go to Menu and scroll down until you reach the system set-up. You can see the NTSC/Pal secam/Auto selection. Select the auto to automatically detect the signal by the processor.
Hope it may help you.
Feb 07, 2011 | Philips 60PP9202 60" Rear Projection...
Color poor, essentially black & white
Hi
Thanks for using FixYa. This issue is caused by failed convergence ICs. I don’t think the issue is with the power supply of the unit as the sound is coming fine from the unit. Please also check the convergence board for cracked solder. If you want to do the repair yourself there are repair kits available which includes instructions on how to replace them. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 02, 2010 | Philips 50P8341 50" Rear Projection...
Have picture in black & white no color. audio
Hi,it definetely sounds like the color wheel.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Found your color wheel here: http://www.discount-merchant.com/MITSUBISHI-00-L3603-002-p/1162430.htm Have a bless one!
Mar 29, 2010 | Mitsubishi WD-52525 52" Rear Projection...
The color is not working. The shows are in black
Your color wheel has gone out, or your video board is defective.
I'd check your cables, then listen to see if the color wheel is humming or winding.
Feb 04, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Hitachi 50UX57B 50 inch Rear Projection smearing...
try this
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Sep 18, 2007 | Hitachi 50UX57B 50" Rear Projection...
Acer PD725P DLP Projector Logo
24 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
