Question about HP Ruggedized DC Car Adapter for HP Deskjet 460 InkJet Printer
19v 4.7amp hp 6000 adoptors
We required picture od adoptor
    Sergeant:
  • 306 Answers
Any 19V 4.7A adapter with a plug that fits the jack will work regardless of what it looks like. Radio Shack sells adapter plugs that will fit any jack if you cannot find the exact HP replacement.
Posted on Nov 05, 2008
I have replaced my new harddisk in my dell inspiron n 4010 and then onwards in my laptop no power is getting and even the led which will blink if the power adoptor is placed even not getting if adoptor is...
Try unplugging it as well as removing the battery. Than press and hold the power button for 30 seconds. If this doesn't solve it, their is a very good chance the motherboard on the computer is fired.
Jun 28, 2011 | Computers & Internet
Does my ASUS N61JQ-X1 have a dual voltage switch for 110v to 220v and/or vice versa? I don't visibly see any.
notebooks or laptops do not have the switches it totally depends on ur adoptor ... if u are using 110 power the adoptor has to be capable of that and if 220 than too the adoptor should be capable , in the market now aday u get adoptors which handles multiple settings ... best way is call asus cust care and ask them if they have something for it or not if u want u can buy it from them or locally places like best buy and wal mart ... if u have purchsed it in US its bond to support 110... totally depending on the country wher u bought it
Dec 09, 2010 | ASUS N61JQX1 Notebook
#2701HG-B no power
make sure the adoptor is gving proper voltage .it is adoptor problem .
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 21, 2010 | 2wire (2701HG-B) Wireless Router
Monitor does not come on (screen is black) Wife turned off everything was fine now can't get back on. Is there some sort of lock on these units?
dear friend,
please do some activity to conform the problem in your laptop, veryfy while you are pressing the power button after some time, press the num lock or cap luck switch is it working means the light is blowing or not? are able to listen the windows start sound? then connect a external monitor and try to swict the vdo on it? if yes then it is the LCD problem and you need to change the LCD assembly. if no then try the following steps:
1: veryfy your adoptor light is glowing or not? if yes then go to next step, if no then replace the adoptor.
2: remove all the external connection, remove the battery from backsite. remove the power adoptor. press the power button for 2min. then connect the battery, adoptor and try... if no then follow below
3. then try to on the laptop by pressing fn+power on botton. try to refix the ram. is there any LED is glowing or not..........?if no then you need to change the mother board
Jan 19, 2010 | Dell Inspiron 6400 Notebook
Everytime i turn it on,it will authomatically shutdown.
See if this helps
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
Dec 29, 2009 | Dell Inspiron 6000 Notebook
Dell latitude d610 not charging battery, I bought a new replacement battery thinking the old battery was the problem.
See the Adoptor status in the bios, if it is not detecting it the adoptor fault otherwise you have mentioned above you have already replaced the battery then it is m/b issue
Dec 28, 2009 | Dell Latitude C640 Notebook
I am repairing purson in pakistan. and my client laptop have a problem in his charging side, when we connect the New adoptor to charge the Battery of Laptop after some time the power adoptor goeing to...
shortage you need to change the dc jack connector... because is chortage that one if did not replace the dc jact connector.. the same at all even you use the original adaptop or battery
Jun 26, 2009 | HP Compaq nc6120 Notebook PC
Lcd is black on start up only after closing lid. HP dv9000
first do a hard reset that disconnect the ac adoptor and the battery form the notebook and press the power button for 30 second and then only connect the adoptor and power on the notebook as the notebook boot up get connect to the internet to the hp.com site and do a bios update on the notebook
Mar 12, 2009 | HP Pavilion dv9005us Notebook
LI 6000 2-way charging base does not charge- no indicator light
Dear sir,
It seems that ur adoptor is not ok , u can save the money by purchasing any 9 V adoptor, It available for less than 1 USD in our country ..& cut the wires of ur budled adoptor & fix them in correct polarity with the wire connecting the charger base ..( before doing this proces check voltage output from adoptor by using a multimetre.)
Regards
Raj
Jan 12, 2009 | Cobra Li 6000-2 WX VP GMRS/FRS Two-Way...
Power problem in monitor
This type of problem generally occurs when adoptor stops working and battery goes down. Show first of all check your power adoptor, its working or not, to check-out remove battery and use power adoptor then try to boot. If there is power led on means adoptor is ok otherwise try to reconnect and also check whether the power supply is ok for adoptor. For canfirmation use another adoptor.
If above not working then you can try to these steps:
1. Remove Power connection (Adoptor connection to Laptop).
2. Remove battery.
3. Re-Connect power to laptop.
4. Make switch on.
If above does not work then after step 2 try the followings
A. Press and hold power button for abt 20-30 secs. keep holding on and insert Power connection now if power led get on leave the button. After that it should on.
If all above didn't solve your problem, then its time to take tour of service centre.
Thanks and Good Luck
Iqbal
Aug 16, 2008 | Dell Vostro 1500 Notebook
HP Ruggedized DC Car Adapter for HP Deskjet 460 InkJet Printer Logo
102 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
