Question about Ricoh Aficio 1035 Copier
Ricoh aficio 1045 error e990 please help it
Sir please let me know the procedures for solving e990 error which comes3 times a day in ricoh aficio 1045 whats the solutions
  • moaed_alhaje Apr 08, 2009
    The emergence of the picture at the beginning of reproduction
    Problem Solver:
  • 10 Answers
Error 990 can be cuased by many things. Most of the time it is related to the Hard Drive. you could try replacing it.
Posted on Nov 05, 2008
  • lorihmm Nov 05, 2013
    clean the id sensor , may help u 2
After update aficio(firmware update) sp1100sf
showed amasage usb detected
please wait,and still fixed on screen untill
restart the machin
Posted on Oct 15, 2010
Upgrade firmware first then replace drum do not replace hdd
Posted on May 11, 2009
See you motherboad
Posted on Jan 19, 2009
    Problem Solver:
  • 5 Answers
Check the copy life of your drum maybeshe rich the copy life if you have a copy morethan 100000 then the problem 990 is apear then you have to change the drum unit
Posted on Jun 17, 2009
  • mark jacob
    mark jacob Nov 15, 2014
    ur right 990 is include to drum if ur drum rich to 100000 copies
  • mark jacob
    the best answer is change the drum :)
2 Suggested Answers
SOURCE: ricoh aficio 1045 error e990 please help it
This is a software performance error; However it is most often caused by a deteriorating drum unit. There is no exact solution, but 9 times out of 10, a new drum unit, and fresh developer will solve it.
Outside of that, it is likely a board problem -possibly BICU
Posted on May 26, 2009
Ricoh mp 1600 error 194 ricoh mp 1600 error code 194 how do I solve the problem
Having problems finding your error code. Here is a complete list of all codes for your printer: http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%20MP1600
I do find the error code for a different Ricoh model (Aficio 1018).
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%201018
Please verify your model number and error code.
Apr 21, 2015 | Ricoh Aficio Mp-1600 Copier
Ricoh 1045 error code sc 395
fix copier is a youtube channel
fixing error in videos
this is a video see you how to fix sc 395
https://www.youtube.com/watch?v=cI6o6mYOqow
Oct 07, 2012 | Ricoh Aficio 1045 Black and White Copier
RICOH AFICIO 1045. ANY BUTTON AT RIGHT OF THE ...
turn off and unplug remove two screws on top near the glass jn order to remove the control panel slide panel toward your tummy bottm side has wiring harnesses check these connectorsare tight also look fer cracked solder joints on right side for numeric keypad if you know how to soldera pcb new control panel is about 800.00
May 21, 2010 | Ricoh Aficio 1045 Black and White Copier
Hello, got an old Aficio 1045 with headcrash. I
The 900 code is the software error code.Enter in theuser and SP modes and configuration the new duplex.For more information please answer.
Sep 28, 2009 | Ricoh Aficio 450 Copier
May 26, 2009 | Ricoh Aficio 1035 Copier
Solution for "code 373 ricoh aficio color 6513"
Hello sir; the error code you display is toner senser problem, now the first thing you have to do is make a full color copy find out which color missing then pull out developer unit from missing color the senser right underneath, replace it.
May 23, 2009 | Ricoh 6513 Copier
Error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
What does troubleshooting code 326 of ricoh copier 1045 means?
2nd laser synchronization error. F gate 1 error. This is an optics issue. Try unplugging the machine and plugging it back it to see if the error goes away.
Nov 13, 2008 | Ricoh Aficio 1035 Copier
Richo 1045
Probably cleaning to the mirrors and glasses inside the laser the problem can be solved, but this is a complicated work if you are not technician I recommend to him that she asks for technical service. Also a bad connection of the flat cable can cause this problem. The detector of synchronism defective also since code SC326 is a fault of detection of synchronism.
Jan 07, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 1035 Copier Logo
770 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
