I have installed a new Panasonic hard drive dvd recorder and a new(linked) Panasonic viera tv with built in freeview. Having set one channel to record, I find that I cannot switch to watch another channel - the message given says 'tuner locked'. Can you advise please. The recorder is model DMR-EX768EBK Many thanks Colin Bailey
Took advice from a work colleage and have managed to sort it
Posted on Nov 05, 2008
I have just bought a Digihome pvr320sd tv recorder with freeview, can i set it up as a tv recorder only without the freeview as i already have built in freeview on my tv.
When you set up the recorder Freeview stations will be stored. This means that you can record TV stations without watching them. So you can say watch BBC1 on your TV and record a program on Channel Four. You need the recorder set up with Freeview to recorder channels. Otherwise you would have to have your TV on and recorder set to record via the scart lead. Which would be not great quality and messy.
You should be able to loop the aerial lead so that both the TV and recorder can get the signals from your aerial, if that's what is bothering you.
Dec 22, 2012 | Televison & Video
I have an Alba 32880hdf freeview tv. I cannot record freeview programmes to my panasonic NV-FJ 780 vcr which has 2 scart sockets. I have no problem recording the teresteral channels. Can you help pls
Hi Victor,
You can't record the Freeview channels from the TV. It doesn't work that way. The reason you can still record terrestrial channels is because the VCR is still connected to your roof aerial with a co-axial cable and the VCR has its own built-in analogue tuner for recording terrestrial TV programmes.
To record the digital Freeview channels, you will either need to connect a separate Freeview set-top box to the VCR, or buy a VCR which has a built-in digital (DVB-T) tuner.
The VCR does not record programmes from the TV. It needs to be connected directly to the signal source, i.e. your aerial.
If you need any further assistance, please let me know.
Regards,
BElectric
Jan 15, 2011 | Televison & Video
I cannot get any tv channels though my panasonic
This model only has an analogue tuner so wont receive anything if the analogue signal in your area has been switched off. either buy a new new with a freeview tuner built in or just use that one in conjunction with a freeview box.
Dec 02, 2009 | Panasonic DMR-ES10 DVD Recorder
Can not get any digital progams now that I have retuned my panasonic dmr-ex75eb dvd recorder. Am not receiving any digital signals
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Sep 30, 2009 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
LG RH266 setup with freeview tv
Sorry to say no it wont not unless the Tv set manuel says it has a Duel Freeview feed , you have to get another freeview box for the recorder .
besides If you used the freview in the tv 1 , the tv would have to be on when you wanted to record ?. and 2 you couldnt watch another channel whilst recording another .. only 1 tuner ?. also you could only record the program you had on .at the time no timer facility .
People are still used to the Old system of VHs and the fact that all videos had tuners built in so you could watch and record .. It will come and indeed some more modern DVD recorder have freeview built in again sorry but thats the facts , and dont forget if you want the pay per view channels on free view your going to need a tuner with a pay card port ... Regards Vortash
May 12, 2009 | LG RH266 Recorder
Freeview not working
The tuner may be defective, or the reception is too poor for the set. A service tech who is qualified to work on your model of set can go out to your place with some field test equipment and verify the performance of the set for you.
The tuner and or IF modules, or main video processor module may be at fault. These modules can be replaced if necessary.
Before having a service call, read the instruction manual to make sure that all the user settings are correct to recieve programs from the tuner section. You can call the Panasonic tech support for assistance.
Jerry G.
Dec 18, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
Recording Problems
Hi.
Yes.
Most tv sets with freeview built in do not allow you to record it.
Check your tv instruction manual to see if it is at all possible.
http://dysonmanuals.llc.nu/
Chris..
Feb 09, 2008 | Televison & Video
Samsung Digital TV and Sony DVD Recorder
hi, did you find a solution? i have in built freeview and have bought a recorder but i cant pick up any freeview channels on it. the dvd recorder is a Wharfedale DVDRHD400 cheers tom
Feb 11, 2007 | Samsung 4 CHANNEL DIGITAL VIDEO RECORDER...
Televison & Video Logo
113 people viewed this question
Top Televison & Video Experts
