Home | IBM | ThinkPad T20 2647 PC Notebook | Ibm a31 0190 erroe
IBM ThinkPad T20 2647 PC Notebook
Problem for IBM ThinkPad T20 2647 PC Notebook
Ibm a31 0190 erroe
By imran danish on Nov 05, 2008
i have ibm thinkpad this gives 0190 error. how solve this
Solution #1
posted on Nov 04, 2009
Not Rated)
eggemanfargo
Rank: Apprentice
Rating: 0%, 0 votes
If you pull the battery out and turn it on with AC power only it should still work.
This however is not the case in my situation.
I have a t61 lenovo and it is giving the 0190 critical-low battery error and it does this even when the battery is out, and plugged into the wall with the AC adapter. I am not sure, but could it be the CMOS battery causing this problem?
I dont know for sure, but i think my motherboard is hosed.
Was this helpful?
Yes
No
Solution #2
posted on Nov 05, 2008
Not Rated)
aggrovendor
Rank: Wiz
Rating: 88%, 27 votes
Error 0190 means you need to charge your battery. Either your battery is not charging properlty or your charger is not working anymore. If the computer works while plugged in and gives no error then it would be the battery that needs replacing. If the battery is a few years old then you may want to order a replacement. The Thinkpad A31 uses the ThinkPad Ultrabay 2000 Li-Ion Battery. You can purchase a replacement battery from this website:
http://shop.lenovo.com/SEUILibrary/controller/e/web/LenovoPortal/en_US/catalog.workflow:item.detail?GroupID=38&Code=02K6646&current-category-id=4364BD0F20B94413B5AD6E684D2848E9
If the laptop doesn't work while plugged in and you dont get any lights on the battery or power indicator on the front of the laptop then you may need a replacement. Depending on which region you are in you will need a different A/C adapter. You can find a list of different A/C adapters here.The A31 uses the 72 watt power adapters on this page:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-4PJRRG#72watt
I hope this helps.
Was this helpful?
Yes
No
Popular Solutions for IBM ThinkPad T20 2647 PC
Questions and Unsolved Problems for IBM ThinkPad T20 2647 PC
Do you recommend IBM ThinkPad T20 2647 PC Notebook?
Answer
Answer
I can't open the door to insert cd. I want to install software. I pushed on the right side like I do... (More)
Answer
I just installed Ubuntu 9 in an IBM Thinkpad T20 as the single OS and none of my devices (Netgear... (More)
Answer
locked out wont let me do anything wants password black page with a lock up in the corner and a... (More)
Answer
This is the error that comes up when booting up - 0175 Bad CRC1 Stop POST task. Previous to this... (More)
Answer
my t20 thinkpad keeps restarting by itselfand every5th or 6th time it will either go on standby and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For IBM ThinkPad T20 2647 PC...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
