Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Battery not backup
When i plug ac main no backup, its dirctly off please help
Hi Tminlun,
Please see if the battery is under warranty and get it replaced from Lenovo. I faced the similar problem last week and got the battery replaced and now it works fine.
Posted on Nov 18, 2008
Where is the backup battery located and how can I change it?
If there is a backup battery then in most cases it will be soldered to the main formatter board, which is the board that the usb or network cable plugs into. In most cases with this product that battery will be soldered to the main board. These are often rechargeable batteries and the printer needs to be connected to AC power for at least 12 hours to charge it.
Oct 01, 2015 | HP Officejet Pro L7650 Printer
Apc xs900 will work off batteries not off ac
So something happened to this apc and the first thing is to replace batteries...
I'm going to guess major circuit board failure.
go to apc site, download Power Chute software and pray there are useful diagnostics.
Mar 31, 2014 | APC Back-UPS XS900 (BX900) UPS System
Low output voltage in apc ups cs500
is that 165 Volts AC or DC? Try to reset the logic. Unplug the UPS from the wall and disconnect the batteries. Push the "On Button" The LED's may flash. This is resetting the logic. This migh help. This should be 120VAC in and 120VAC out. Please give me an update.
Oct 31, 2011 | Computers & Internet
How to make laptop work without battery - model cq50-11n5 just on AC adaptor
To make it work,,,Remove laptop battery & then plugged adaptor dirctely to the laptop...
Thanks for choosing Fixya
Sandeep
Mar 20, 2011 | Compaq Computers & Internet
My ups is switching on on battery for few seconds but without AC output, the same thing when I put AC power it switches on normally but also without AC output.What can I Do? Please help
does it have a led display for battery charge? if it is very low battery is bad,when you add a/c no output because bad battery will not provide a/c in power failure
Feb 02, 2011 | Powercom (BNT-1500AP) UPS System
How to check the frequency of AC Power
A simple, cost efficient and convenient solution would be to use a plug-in energy monitor that also offers frequency measurement, like these:
UK mains plug
German mains plug
US mains plug
Of course, you could also use a multimeter like
this or this (higher accuracy).
If you want to buy some other model, check the specifications first - not all energy monitors and multimeters do offer frequency measurement!
Mar 11, 2010 | APC Smart-UPS 1000VA UPS System
Wont boot without password
Unplug the laptop and remove the main battery. Remove the cover for the memory modules and you will also see the CMOS backup battery located there. Unplug it for 10-15 mins, then plug it back in, insert your main battery, ac adapter and boot the system. You will need to reset the system date again once the CMOS is cleared.
Jan 10, 2010 | IBM Computers & Internet
HELP ! XMAS PRESENT 569/1366 NO AC MAINS CONNECTOR PLUG
Went to my local Argos store [not where it was bought], and they replaced the complete [or rather INcomplete] box. Thanks.
Jan 07, 2010 | Olympus FE-330 Digital Camera
IPaq rx3115 working like PC not Pocket PC, need to plugin always
You need to purchase a new removable battery for your RX
The removable batts usually only last about a year (like cell phone batteries).
Although it is showing 100% charge, the battery is not storing enough power to run the ipaq
The rx series uses 2 batteries, one is the removable one u can see/access when u remove the back cover. The other batt is a small round batt which stores the basic info for your system (so you don't lose your data when u swap out the removable battery).
This small (backup) batt is similar to the cmos battery on a laptop or pc.
You cannot easily replace this, as the unit needs to be disassembled to access this batt.
If you are tech-y (and brave), the replacement button batteries are sold on ebay for $9-12
Normally, if your removable batt is bad, you could still use your unit plugged in, and could
remove from AC power without losing data. Not the case if your replaceable batt is exhausted.
When both batteries are bad, you lose everything when u remove unit from AC power.
My workaround without having to disassemble unit:
Purchase and fully charge new removable batt (They have huge capacity ones available for like $15 - better than the original !).
Load up all your programs & settings the way you like.
Perform full backup to SD card (& also on PC via active sync - to be safe)
Now the only time you should lose your data (like hard reset) is if you allow the battery
to completely drain, in which case you can restore your backup.
If you purchase 2 removable batts, you can easily swapout without losing data if you
use the usb charge cable & leave ipaq plugged in while you change battery
Hope this helps
Jun 01, 2009 | HP iPAQ RX3115 Pocket PC
Main Battery Power
It cannot switched the batteries. The backup one is a small internal battery just to keep the CMOS with data. That's it.
If you main battery is not charging or when unplugged won't power on, the is likely the main battery is defective, or the charging circuitry of it is failing.
Best regards,
Jul 01, 2008 | HP iPAQ RX3115 Pocket PC
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
53 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
