Question about Kitchen Appliances - Others
Hobart L-800 mixer , needs planetary oil change and tranny oil change.
CAN YOU GIVE ME THE LOCATION OF THE DRAIN PLUGS AND  FILL PLUGS FOR THE PALNETARY  AND TRANSMISSION , QUANTITY OF OIL FOR L-800 HOBART MIXER WITH MANUAL  BOWL LIFT  , THANKS
bigg t
  • 640 Answers
SOURCE: Hobart medalist L20 is it appropriate mixer for doe?
What are you going to be mixing?Pizza dough,bread dough ect.
Posted on Sep 05, 2008
bigg t
  • 640 Answers
SOURCE: I need to change gear oil in Hobart H600 mixer.
Take the top cover off,where the front screw on the cover goes in that long shft has to be unscrewed,get a funnel and add oil.
Posted on Feb 20, 2009
bigg t
  • 640 Answers
SOURCE: hobart D300T mixer oil change.
Call your local hobart branch and tell them you need grease for a d300 mixer.Yes this mixer uses grease now.If it's older they used oil but is no longer available.
Posted on Mar 16, 2009
ricardok45
  • 135 Answers
SOURCE: Need oil/grease for Hobart 20 qt. mixer
Hi. Your A200 is in need of service. The grease's lifespan has expired. There are two ways of doing this. First, the expensive way. Call for a Hobart Tech to come and service the mixer. This will take about 4-5hrs to service at a rate around $100.00usd per hour, plus the cost of parts. He/she will need to change all seals, remove old grease and oil, check all bearings and gears for excessive wear and replace as necessary, this includes the planetary gear.
Now for the affordable solution. Unplug the mixer, remove the top cover. Gently use a small screwdriver to pry off the two circular metal dust caps found on the transmission housing, use a good flashlight to determine, through these openings, the quality, quantity and condition of the grease inside the transmission case. If there's a lot of oil you can remove much of it a bit at a time by using a wire coat hanger to which you can attach bits of cloth to absorb as much oil as you can. Once oil is removed, add new grease through these same holes until full (Chevron FM ALC EP-2, food grade lube). Run the mixer for a couple of minutes to distribute the new grease. Fill to the top once again and replace dust covers. Remove planetary, clean, inspect change seal and re-grease.
OPTION (mechanically challenging) You can do a more thorough job by removing the trans. cover completely, removing the 3 gear shafts inspect all bearings and gears, change seals on mainshaft and planetary. Remove old grease and oil, clean gearshafts and gears. Parts drawings are available from www.hobartservice.com It's free to register and then locate your parts drawings. Be sure that you have the correct files for your Model #, ML# if there is one and Spec.#, all found on the info plate.
When disassembling, take a digital photo of every step and lay the removed components on a piece of cardboard in the removed sequence. These practices will become valuable during re-assembly.
If this solution has assisted you, please rate it. ricardok45
Posted on Mar 20, 2009
  • 119 Answers
SOURCE: I need diagram of gearbox for Hobart d330 mixer
Parts manuals are available for viewing and free download at www.hobartservice.com
Posted on Jul 16, 2010
Testimonial: "I know,ust can't find them. If you could explain to me how, I would appreciate it"
What kind of oil should I use in my Hobart 800 floor mixer? jdnwilk@juno.com
Hello Jdnwilk,
In a Hobart L800 you use 140 weight gear oil in the head and 90 weight gear oil in the planetary. You should start with about 160 ounces and check the sight glass and fill until in the middle of the site glass after oil settles.
Thank you for choosing FixYa.com
Mar 06, 2011 | Hobart Food Mixers
What type of gear lube should I use for my Hobart H600 mixer?
Hi, btperduell
below is a copy of an e-mail from Horartservice.com. I searched the web forhours for the correct oil and could not find any info so I e-mailed Hobart. The Planetary is a different part from the transmission andthe sight glass on a M802 is for the oil in the transmission. The answer that Hobart gave is not an NSF oil. Ineeded the oil for the planetary section on a model M802. Even the directionssay that it is normal for a drop of oil to occasionally drip from the seal.That is where the dough hook attaches. I am in the process of researching the oil and Exxon / Mobildoes make a NSF version. I just need to find somewhere I can buy less then a 55-gallondrum. The above mixer only uses 6 ounces. Take care and stay safe Thank you Mike Hobart E-mail follows ============================================================== Mike, Hobartuses "EXXON SPARTAN EP-150 (6 oz)" in the M802 planetary. Hobart part #102973-13. This IS NOT a food grade oil. If you mixer is leaking you shouldhave it serviced. Service, parts , lubricants and information canbe obtained by contacting your local Hobartoffice in Pittsburgh@ (412) 788-5380. Steve Davis Field Engineer - Food Machines Product Service - Tech Support
b>
Jan 15, 2011 | Hobart HL600 Legacy Stand Mixer
How do you change or add oil to a Hobart H600 mixer
there are two oils to change. one for the trans. and one for the planetary.the drain plug for the trans. oil should be in back of the planetary take out plug let oil drain ,remove top cover take outstand off where front screw to top cover threads into put new oil in there till you hit line in sight glass on right side of mixer.
Jan 02, 2010 | Hobart H600 Stand Mixer
Making noise in planetary gear area. we have a l 800 hobart mixer just purchased ,has wirring noise planetary gear area ,i 'm quite sure it is common wear from use , but want to repair...
The noise you are describing sounds like the noise associated with the pinion gear meshing with the ring gear in the planetary. Depending on the age of the unit, some noise is to be expected. The lubricant used in the planetary is different than that of the main transmission and is not visible without disassembly. Again, depending on age of the mixer, your planetary may have a small amount of oil and a pump to bathe the gears or just a generous amount of grease applied to the gears. The only way to properly inspect the planetary is to remove it. Depending on your luck, this may be 20 min job or several hours. It all depends on the ease of which the planetary releases from the main center shaft. Should you decide to tackle this job yourself let me know and we'll do our best to assist you. Several knowlegeable techs monitor this area of the site.
Sep 13, 2009 | Hobart P660 Stand Mixer
Hobart D300 Mixer, Will not shift from 2nd to 1st gear without coming to full stop, Ideas as to source of problem? It also seems to be making increased noise.
Hobart mixers are NOT designed to change gears while operating. The Hobart planetary gears are like the transmission in your car but, without the clutch. Everytime you change gears while unit is running you are tearing up the brass spacers, gears & seals. Time to call a QUALIFIED service tech to come out & sell you another planetary or rebuild your old one, about $2K, Buy a Varimixer if you want to change gears while unit is running, they use belts. Another planetary premature failur cause, over loading the bowl. Batters & icings- 75% bowl capacity, Dough 65% bowl capacity.
Jul 23, 2009 | Hobart D300 Stand Mixer
LEAKING OIL SEAL ON HOBART 660 CAN'T GET PLANETARY TO COME LOOSE
Definitely need to remove the acorn nut. There should then be a few thinner nuts as well. Make sure to drain the oil from planetary first and also be careful as the entire assembly is heavy. If I recall correctly, you need to be aware of a fiber gear that follows the inner gear (sun gear) and drives the oil pump that is mounted inside the planetary.
Jul 18, 2009 | Hobart Food Mixers
Hobart D300 Mixer: Has no torque and no speed in any gear
You have a gear with broken teeth or one sliding out of place because the brass shims are eaten up. Hobarts have what is called a planetary, round head where the grease caps are, and there are no clutches for this planetary. These units are not made to change gears while unit is running (#1 problem of gear failure) (#2 is overloading the bowl) Hobarts need a really stiff GREASE, not oil. If you decide to take the planetary apart, get all the syrup out and replace with a stiff axel grease. It is a very difficult job replacing a gear & ALL the shims. The round head where the grease caps are can easily be removed to do this.
Jun 17, 2009 | Hobart D300 Stand Mixer
Oil leak from planetary
The transmission center shaft seal/chimney is bad.You need to tear the transmission down in order to repair,let me know.
Apr 29, 2009 | Hobart H600 Stand Mixer
Oil leakage
Is the oil leaking down the beater shaft?Remove the silver drip cup,3 screw's one in the midlle,one on the right and one on the left.Once you drop the drip cup if it's filled with oil then you may need the seal's in the transmission replaced.
Mar 14, 2009 | Hobart A200 Stand Mixer
Hobart 140 Qt Mixer 4 speed. needs the oil changed? what kind of oil to use?
You can use a heavy weight gear oil or call the local hobart branch for it.To remove oil----Look under the mixer where the beater shaft is in the back and you will see a three quarter inch nut,remove this nut and drain the oil then put nut back in.To fill the unit remove the top cover screws and remove the top,you will see a long hexagon nut in length,remove this and grab a funnel then add the oil---be patient it takes time to fill as the oil is heavy.
Jul 24, 2008 | Hobart H600 Stand Mixer
Kitchen Appliances - Others Logo
339 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
