Question about NEC ND-3550A DVD RW Dual Layer Burner
No Session-at-Once recording
While all the online documentation I've found for the 3550A says it will burn session-at-once and disc-at-once, I've only been able to burn track-at-once, so my audio CDs have two-second gaps between tracks. I've tried this in several different programs, Nero, CDMate and CDBurnerXP Pro. Nero goes through the motions of doing a session-at-once disc but produces a blank disc, while CDMate doesn't give me the session-at-once option and CDBurnerXP gives me a message telling me my drive is incapable of burning session-at-once and disc-at-once. I got the firmware upgrade as a shot in the dark, but no dice, it didn't help. My system: Win XP Pro SP2 Athlon 64 3200+ 2GHz AsRock 939Dual-SATA2 MB 1GB Corsair DDR Sapphire Radeon X1600XT 256MB
4 Suggested Answers
Astrobyte
  • 110 Answers
SOURCE: Burning problem
Try burning at a slower speed, like 16x or less. If your burner is a CAV-type, it will burn faster as it moves toward the outside of the disk and can be more prone to errors that way.
Also, have you tried playing the burned disk in another player, and did it show the same symptoms?
Posted on Feb 17, 2008
SpotBert
  • 231 Answers
SOURCE: Works well on CDs, DVDs won't accept file into the file system in windows burning wizard
2f8 released August 24, 2008 is the latest version
=> http://www.findmysoft.com/drivers/Nec-ND-2510A-2f8-firmware-driver.html
Posted on Dec 26, 2008
SOURCE: Will not read my burned dvds
In this case need update the Firmware of DvD/Cd Rome
Posted on Apr 11, 2009
Unable to record goto meeting session in lenovo windows 7 64bit
Maybe you can have a try Leawo Music Recorder. Leawo Music Recorder is a superb but easy-to-use music recording software program that lets you record free music from any built-in input audio, computer audio and online music sources, like YouTube, Spotify, AOL Music, Last.fm, etc. and then save in MP3 or WAV format with lossless quality.
The following simple step-by-step tuturial guide shows you how to record online audio file on Windows with Leawo Mucis Recorder. The turotial for recording online audio file on Mac is the same given that the user interface of Leawo Music Recorder is the same as that of its Windows counterpart. Therefore Mac users can get know-how below as well.
Step 1: Select audio source
Leawo Music Recorder could record both built-in input audios and computer audios. As you want to record online audio file, before recording, select "Record Computer Audio" in Audio Source settings panel, which could be invoked by clicking the "Audio Source" icon on the bottom-left corner.
Step 2...
For more detail, check: https://www.leawo.org/tutorial/how-to-record-audio-from-the-internet.html
Feb 17, 2014 | Lenovo Computers & Internet
I already wrote disc but how to overwrite a disc
On a CD-R, if you don't finalize or write protect the disk, can you overwrite a file?
Or in overwriting are you simply creating a second file of the same name in the TOC/directory and deleting the name, only, of the first file
You can add more data if there is space on the DVD+R, but you can't overwrite it.
You see, when a disc is burned, little microscopic ridges are put onto the disc. This is your data.
You cannot overwrite this data.
It's kind of like trying to use a permanent marker on the same spot of paper twice.
CD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a CD-ROM.
650 megabytes (MB)
Highly compatible with most computers and devices.
CD-R
You can burn files to a CD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
650 MB and 700 MB
You must close the session to read this disc in a different computer. Highly compatible with most computers and devices.
CD-RW
You can burn files to a CD-RW more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A CD-RW can be burned and erased many times.
650 MB
Compatible with many computers and devices.
DVD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a DVD-ROM.
4.7 gigabytes (GB)
DVD-R
You can burn files to a DVD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
DVD+R
You can burn files to a DVD+R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
You must close the session to read this disc in a different computer. Compatible with many computers and devices.
DVD-RW
You can burn files to a DVD-RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RW can be burned and erased many times.
4.7 GB
You don't need to close the session to read this disc in another computer. Compatible with many computers and devices.
DVD+RW
You can burn files to a DVD+RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD+RW can be burned and erased many times.
4.7 GB
DVD-RAM
You can burn files to a DVD-RAM more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RAM can be burned and erased many times.
2.6 GB
4.7 GB
5.2 GB
9.4 GB
DVD-RAM discs can generally only be used DVD-RAM drives and might not be readable by DVD players and other devices.
hope this helps
Aug 28, 2012 | Ahead Software Nero Express 6.0 (NERO6OEM)...
My disks are DVD-RW and want tp use them over gain and don't know how. Also when do I finalise then and what for
For RW discs, you need to reformat them to reuse them. For your laptop, you should see a format option if you right click on the DVD icon when you have the File Explorer open to Computer (My Computer). (This assumes that the computer has a DVD writer.)
Finalizing the disc enables the contents of the disc to be read on other DVD players. (This isn't always an issue. For example, a disc burned with WinXP should be readable for a computer with Windows 7 without finalizing. However, if the disc was burned by a DVD player, the contents will not be accessible on any other units without being finalized.)
If the disc has been finalized, you need to take another step before reformatting the RW disc. Put the disc in the unit that initially finalized it. Then look for an Unfinalize option. Then format the disc again. (I've never used this feature on my computer. It's easily accessed on my DVD recorder in the same section of the submenu as finalizing the disc.)
I hope this helps.
Sep 12, 2011 | Computers & Internet
Cant make a back up of my dvd's for the kids to use. with shrink and decripter. when i do now it says, when i play it, it says no menu.
Step 1
Be sure to erase all data on the disc, if media is rewriteable, by going up to the "Recorder" drop-down menu and clicking "Erase Rewriteable Disc." A box will pop up on which you need to choose the correct recorder from the top menu, quick or full erase (best option), and a maximum erase speed is fine.
Step 2
Choose your recorder drive on the top right drop-down menu on the main screen. The drive icon next to this menu allows you to set advanced options. (Not needed here.)
Step 3
Click on the "Burn" icon in the middle of the main toolbar. This opens up the "Burn Compilation" box.
Step 4
Click on the "Multi-session" tab on the "Burn Compilation" box. Choose "Start Multi-session disc", if the disc is to be added to later. Choose "No Multi-session disc," if the disc is to be completed with the current burn. The other options are good at the default settings.
Step 5
Click on the "Label" tab on the "Burn Compilation" box to give the disc a title that will be seen in the drives list, such as Windows Explorer, when the disc is loaded. Choose "Automatic Disc name" and enter the desired name without spaces. For spaces, add underscores (shift+hyphen).
Step 6
Click on the "Burn" tab on the "Burn Compilation" box to set desired burn and writing actions. "Determine maximum speed" lets Nero determine the recorder and disc speeds, if they are unknown. "Simulation" performs a test virtual test burn to see if all goes well. "Write," of course, burns the disc. "Finalize disc" means that the disc will be burned, so that no more can be burned on it. (For the example, check the boxes for "Write" and "Finalize disc," which is probably already checked.)
Step 7
Set "Writing speed," if known, "Writing method" as "Disc-at-once" and "Number of copies".
Step 8
Click the "Burn" button at the bottom on the "Burn Compilation" box to begin the actual burning process and the "Writing to disc" window will open.
Step 9
Check the "Verify written data" box on the bottom left of the "Writing to disc" window. This will have Nero read the disc, after it is done burning, to verify that all of the data has been properly burned to the disc. This is an important optional step, especially with really important data. If all goes well, a box will pop up stating that "Data verification completed successfully."
Step 10
Run the disc in a drive or DVD player to make sure it runs correctly. If it does, the original files on the hard drive may be deleted, if desired.
Dec 11, 2009 | Computers & Internet
Windows media player burned a dvd for me now when i tried to play it on my dvd player it wont work what do i do it says disc is not finalized please finalize the disc on the recorder which was used for the...
Most DVD player can't read open session discs, meaning when you burn your DVD movie there's an option there that when your disc is not full you can still add files on it, it's open session, in your case if you want to play it on dvd player you must select the finalize the disc to close the session and you can play it in any dvd player you want.
Oct 30, 2009 | Microsoft Windows Media Player
My dvd-raw ds is not reading on my inspiron 1501. I have a recorded my holiday video on a maxwell dv-raw ds (mini dvd) and I cant play it on my dell laptop. I was wondering if you could help? Many Thanks.
you will have to place the disc back in the computer you used to burn it and "close session" this is a common thing with re-writable discs or where discs ar burnt as a data disc.
the exact method of losing discs varies from burning programs to program.
You should check the options of the program you used and look for "close session" or "close disc" or "end session"
sometimes it is useful to write a very small file and then make sure tha the option is ticked before you do so.
Aug 30, 2009 | Dell Inspiron 1501 Notebook
I dubbed home movies from VHS to DVD but I can't get it to finalize
On PC or stand alone DVD burner?
On PC tell burning application to finalize because you most probably are burning multi-session DVD's now and not all DVD players old type accept unfinalized discs.
On standalone: go with remote to menu item where to finalize that multisession DVD (these units always make default because of design multi-session discs)
Apr 29, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Data are not shown
most older drives can't read multi session... you need to have a drive installed to be able to read multi session burn. there is no software tweak that can fix this... you need to replace the drive. otherwise burn the data as single session.
Jun 03, 2008 | ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM...
Samsung make TSSTcorp CD/DVDW SH-S182F
on creation or compilation of any cd/dvd regardless of disk format or capacity. the finalizing of a disk. will write a TOC ( table Of Contents ) this will inform the drive reading the disk. whats on it. even if a cd or dvd writes 1 track of music. if thats all you put on the disk, and finalise it. that will be the finished capacity. if you use rw disks. you must format the disk before re-using it.
this will completely erase all previous data on it.
If as stated you are using Nero. there are setting options, to create a multi-session cd/dvd whereby you can add additional files at a later date. however this disk will not be readable, by any other computer-cd/dvd player. until the disk has been finalised, and produced the Table-Of-Contents. ( Index )
Mike @ Compurepair.
May 10, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
Recording DVD's on Samsung DVD-VR320 Recorder
See if a shop will clean the optical assembly for you at a reasonable cost. Also, if you have the "finalization" feature turned off, this will cause a disc to show that message...accordianman
Feb 25, 2008 | Samsung DVD-VR320 DVD Recorder/VCR
NEC ND-3550A DVD RW Dual Layer Burner Logo
62 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
