Question about Texas Instruments TI-86 Calculator
Casio fx-570ES calculator inner screen cracked
I accidentally dropped my calculator onto the floor and the LCD inner screen cracked. Is there any replacement for it?
  • Anonymous Jan 31, 2009
    help the lcd screen cracked
  • 4 Answers
There is a faint metal coating on the glass where the cable attaches, you would have to find another screen with the same spacing, of the horizontal and vertical lines, and try to attach the horizontal and vertical cables to that.
Posted on Apr 24, 2009
  • 749 Answers
The difficulty of finding a replacement LCD maybe would cost more than having a new one. and even if can find a replacement, installing it would again be very difficult! circuit to LCD connector is fixed, once remove, there'll be no guarantee that it would still function normally! try to disassemble your calculator and see if you can manage to disconnect and reconnect the LCD itself!
Posted on Nov 05, 2008
Hi,how can I calculate median using fx-570es plus?
The median is the number is the middle.
Using the calculator, you can follow the Statistical Calculations (Stat) on pages 22 and 23 of the attached manual. http://support.casio.com/pdf/004/fx-570_991ES_PLUS_E.pdf
However, it might be quicker to just put the numbers is order from lowest to highest and pick out the number in the middle.
For example, take the numbers 3, 5, 4, 7, 6, 4, 9.
Putting them in order, we get 3, 4, 4, 5, 6, 7, 9
There are 7 numbers so we want the 4th number (3 numbers to the right and 3 numbers to the left). In this case, the 4th number is 5 and that is our median, as half the numbers are lower than it and half the numbers are higher than it. It the number of numbers is even, you take the average of the two middle numbers.
Good luck,
Paul
May 16, 2016 | Casio Fx-570es Scientific Calculator
I've got a casio fx 991plus calculator and I want to know how to use feet and inches in the calculation displays, like how is used meters and centimetres in the display
PDF]fx-570MS/991MS Additional Functions - Support - Casio
support.casio.com/pdf/004/fx570MS_991MS_E.pdf
Casiodisplay format (Disp) settings while the calculator is in the BASE ... Be sure to checkthe current calculation mode (SD, REG,. COMP ... Use [ and ] to display the expression 4 + 4. Press A ... want to perform scientific function calculations. COMP .
The Casio fx-991es, fx-570es and - Numericana
www.numericana.com/answer/casio.htm
The Casio fx-991ex succeeds the fx-991es (functionally identical to the ... Both are nonprogrammable nongraphing scientific calculators, with natural ... Side-by-side comparison of the fx-991EX and fx-991ES PLUS. ... Displays QR codes for smartphone use .... Work out a formula for many values of the input variables.
CASIO fx-991MS Calculator Tutorial: Lesson 5- Dealing with ...
Dec 03, 2015 | Casio Office Equipment & Supplies
Fx 570es or fx 570es plus
Get the Plus. It adds a few functions, takes nothing away, and is the same price at most vendors.
Sep 04, 2012 | Casio FX570ES Scientific Calculator
Where is antilog function in Casio fx-570ES PLUS?
A name can bring a lot of confusion. The decimal logarithm has an inverse function which is raising a number to a power of 10. It shares the same physical key as the logarithm LOG.
May 15, 2012 | Casio FX570ES Scientific Calculator
I want thousand seperator in my answer in casi sceintific calculator fx570es plus
Sorry, the fx-570ES Plus does not have the ability to insert thousands separators into numbers.
May 11, 2012 | Casio FX-115ES Scientific Calculator
Staples bd 6410 manual
Download manual for: Casio fx-115ES, fx-570ES, fx-991ES, any should do the job. Download the Appendix, too.
http://support.casio.com/en/manual/manuallist.php?cid=004
Nov 28, 2011 | Office Equipment & Supplies
I cant find my Antilog button on my Casio fx-570ES
The common antilog is the shifted function of the "log" key, marked "10^x". The natural antilog is the shifted function of the "ln" key, marked "e^x".
May 09, 2011 | Casio FX570ES Scientific Calculator
= sign how do I type it into a problem
as far as I know, FX-570ES and FX-991ES are the models where you can input this equation
Sep 16, 2008 | Casio fx-300ES Calculator
Texas Instruments TI-86 Calculator Logo
585 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
