Question about HP Pavilion dv9000z Notebook
Conexant High Definition Smart Audio22-No stereo mix/line in problem
I have a Hp Pavilion dv9700 Notebook PC...AMD Turion 64x2 Mobile Technology TL-60 running 32 bit Windows Vista Home Premium. I am trying to broadcast streaming video (.avi files) to justin.tv but there is no audio. I am aware of the general problem going on with notebooks unable to get a stereo mix or line in. I have scoured the net looking for help, from installing drivers to VAC to spending hours on the phone with HP...no help. Can you please recommend a way for me to be able to sort this problem out?
Thanks very much,
  • 9 more comments
  • mattframe Nov 05, 2008
    No, it only occurs when I broadcast. I have been told that my sound card's stereo mix/line in/out capabilities have been turned off. apparently it's a big problem with new notebooks...
    Hi Drlativ,
    Thanks so much for your advice. I did as was instructed but the only thing option I get is "Microphone" and not with wave, line-in, stereo mix or anything...
    This is quite a conundrum. I spend 5 hours tonight in chat with a fixya guru with no success at all. I really am at the end of my rope on this issue and have a hard time believing that my $1200 laptop can't broadcast...I am streaming to justin.tv, by the way. Again, thanks for your advice. Maybe tomorrow...
  • Anonymous Dec 03, 2008
    NO when you show hidden devices in hp laptops.. there is NO wave out or what you hear or stereo output like in vista... im searching for an answer.. but im about sick of people telling me to go veiw disabled devices.... because its not working on my hp dv2000
  • Anonymous Dec 05, 2008
    The computer I'm on.. an HP DV2000 belonging to my best friend.. with Vista has this problem. I have an older DV6000 with the same soundcard, but with XP. And I use Waveout with Audacity all the time.. Does anyone think it could be changed by something in the registry??
  • Uncle Boo Dec 11, 2008
    Same problem. No stereo mix or wave mix for line in on toshiba laptop. Annoyingly, old HP nx600 had it. HP dv8333 works ok as do two pavilion desktops - its simply the coundcard and no wa round it without replacing the card - nothing to do with hidden devices or windows
  • marcovip51 Dec 13, 2008
    i hvae Compaq prsario C304 i had windows xp instaled with conxant sound card ,it was fine, i had miv, cd,waveout for playing sound out of sound card , i upgreaded to windows Vista Home . now i don;t have streomix or waveout ,all it shows, 2 mic , and cd ,after Enabling all hided itemes, again upgreaded to Vista Ultimate , still i don't have streomix or wave. i talked with Hp Tec's ,their answer was my sound card doesn't suport streo mix, which i diid not belive what they said, becouse why when i have Xp OS my sound card suport streo mix ,but when i change to Vista , now my sound card doesn't have streo mix function, i belive it is Vista,s problem ,
    is any body out there could find a solution ???
  • angiebaby570 Feb 11, 2009
    Exactly, every site you go to it tells you to simply right click and check show disabled devices... It doesn't show anything more when you do that. I heard Vista has it set like that to protect piracy... Well then when I pulled out over a grand to purchase this laptop,it should have had on the box or in the manual that I cannot do such a thing. It is ridiculous, that everyone has to search site after site to not even find a resolution. Not to mention when you call support they either have no idea what you are talking about or tell you to click disabled devices. RIDICULOUS
  • carl_wilhelm Mar 09, 2009
    i have the same problem
    hp artist edition with conexant, paid like 1200 dollar for it last year
    and it cant even do this simple thing?
    ffs
    luckily i have a shitty solution for just only my type of laptop, it has two headphones out jacks, i can plug one of them into the microphone jack with male male 3.5mm so i can record from mic then
    it helps somewhat but not all the way
    i am thinking of maybe i can get drivers for another soundcard, i have the latest for mine, if i got other drivers, maybe it would work?
    this is the first that come to my mind
    cuz as it is now, there is no "hidden" **** to be found in the soundtabs.
    another solution would be to install ubuntu or ubuntu studio or some other linux and use the jack audio server or maybe pulseaudio soundserver and some kind of windows emulation if you need the windows programs.
  • Lalit Varadpande
    Lalit Varadpande May 11, 2010
    oh..am sorry that it wasnt solved..shall look around more..i still didnt understand whats justin.tv..please help me on that..thanks!
  • Lalit Varadpande
    thanks for the reply..saw something,will it help?
    But, if you try the same trick with Windows Vista, you won't see an option for Wave Out Mix. It's not that the option's been left out of Vista, Microsoft just decided to hide it. Media Center Show podcast producer Ian Dixon has the instructions for enabling Wave Out recording:
    Select sound from the control panel.
    Select the recording tab.
    Right click on the background of the tab and choose "show disabled devices."
    Right click on Wave Out Mix and click enable.
    Now it should work the same way as Wave Out Mix in Windows XP, allowing you to record any sound your computer makes
    the url is http://www.downloadsquad.com/2007/01/15/...
    uh by the way where are u trying to stream to..didnt catch that properly..
  • Lalit Varadpande
    is the audio problem occuring when u broadcast or irrespective of that?does  it happen with all .avi files?please clarify..
I have compaq cq0 and have no stereo mix or wave out,but i have fixed it,you need to get virtual audio cable,it then puts recording optiond in recording devices,my sound now is better than what it would be if i had stereo mix,you can get virtual audio cable for three on www.thepiratebay.org, also look it up on utube to see video of how to set it up,belive me it is better than stereo mix,my sound is so rich and crystal clear when i stream music over internet,hope this helps you lads
Posted on Sep 12, 2009
  • HP Master
  • 4,806 Answers
Try installing the latest video and audio codecs
Posted on Nov 13, 2008
Riiizla, could you explain the steps involved in configuring Virtual Audio Cable? Am not a Pro with such things, but I have lost the ability to stream music into a chat room since buying a new HP laptop. Any help would be much appreciated.
  • Open in Google Docs Viewer
  • Open link in new tab
  • Open link in new window
  • Download file
  • Copy link address
Thanks in advance Roy.
Posted on Mar 06, 2010
2 Suggested Answers
  • 6 Answers
SOURCE: Hp Pavillion Notebook Sound Card Problems
Try this link
http://www.pcstats.com/articleview.cfm?articleID=2238
hope it works.
Posted on Nov 05, 2008
Not able to install Conexant High Definition Audio driver
go to hp.com download your Conexant driver and fax modem driver for your model onto a flashdrive and install it on your laptop that way..another thing check your updates. microsoft has an audio conexant driver in the custom downloads...
Sep 01, 2009 | HP Compaq Presario v3000z Notebook
Hp Pavillion-Conexant High Definition Smart Audio221-No Stereo Mix-Need Driver?
I've upgraded the driver from HP sp34200 version 3.26.0.0 to 3.45.0.50 using the files from Microsoft update catalog. This driver is now 3.45.0.50 and includes STEREO MIX. You can use the setup.exe for automatic install.
Note that due to changes, the driver is obviously no longer digitally signed.
The driver matches: HDAUDIO\FUNC_01&VEN_14F1&DEV_5045&SUBSYS_103C30D9
http://www.mediafire.com/?d74hkani6q69rr3
May 29, 2009 | Compaq Presario Notebook
Full driver for xp sp2
Here is the page to download all the drivers:
TX1499US Downloads
Thanks for using Fixya.
Apr 15, 2009 | HP Pavilion TX1000Z 12.1" Touch Screen...
Hp pavilion dv6700 amd turion 64x2 mobile...need ethernet driver
by doesn't fit, do you mean gives you a microsoft verification error, such as "this driver is not verified by Microsoft."?
If that is the case, let it install anyhow. HP knows better than Microsoft whether the drivers will work.
Jan 01, 2009 | HP Pavilion DV6700Z Notebook
Windows Vista Home Premium 32 Bit-Sound Problem.
On windows, by default , the mic is muted. Go to control panel/ audio settings, and check if the microfone is muted.
If the sound is working , then it is not a driver problem, but a settings problem.
Nov 05, 2008 | Computers & Internet
Try this link
hope it works.
Nov 05, 2008 | HP Pavillion dv9740us Notebook
System specifications
Here's the HP Support link for your laptop.
Apr 23, 2008 | Computers & Internet
HP Pavilion dv9000z Notebook Logo
11,570 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
