Question about Cell Phones
Phone says no simcard inserted - Cell Phones
  • 6 more comments
  • zakkings Nov 21, 2008
    inserted sim card, replaced battery cover but says to insert sim card still
  • Anonymous Nov 23, 2008
    Phone was OK until recently. Then showed "Insert SIM" when switched on. Removed SIM and replaced with known good one, but phone still says "Insert SIM"
  • markking11 Nov 24, 2008
    how do u open the phone to access sim??
  • Anonymous Dec 22, 2008
    i HAVE THE SAME PROBLEM :(
  • aligenie Jan 25, 2009
    tried cleaning it, it is a new SIM that works in another phone but isn't detected. My phone also will not charge
  • Anonymous Jan 26, 2009
    phone says insert sim
  • karelmatthe Feb 18, 2009
    phone says no simcard inserted"
  • Anonymous Mar 04, 2009
    phone says insert sim card but it was working perfectly 10 minutes ago and the sim card is in.
After having a hard time just getting the SIM card out (use a pencil eraser to gently guide it out); I discovered that my daughter had put the SIM card in backwards (notch on wrong side). Hope that's all your problem is, too!
Posted on Jun 22, 2009
PUT SIM CARD IN
Posted on Nov 05, 2008
It says insert simcard
Try taking the sim card out and putting it back in. the sim card is generally located under the battery.
Apr 15, 2012 | Samsung Wave 525 Cell Phone
My flip phone displays message "insert SIM" and
Hello.
You need to have a simcard. If you already have one inserted, then remove the simcard from your mobile phone, then reinsert it back. It is usually found behind the battery. If you are still having the same error, then you might need to change your simcard.
Aug 03, 2011 | Samsung Cell Phones
My Samsung star ii phone shows 'insert simcard error' message even when simcard is inserted.
Try to look for a rubber eraser and rub it on the simcard interface. Also, I want to ask if you have dropped your phone which may cause the error. I would also suggest you to change simcard if you get the same error message so we can identify if the problem is on your phone.
Jun 16, 2011 | Cell Phones
My nokia 3200 restart when simcard inserted.but when simcard no inserted the phone no restart.just showing insert simcard
Hi
This is happening because when the Sim card is not inserted you cannot access the menu of the phone some nokia phones(including yours) are built that way.
Some nokia phones do not need a sim card for you to access the phone menu (e.g 5130,5230), while you can only view the demo of some nokia phones (e.g 1208, 1600) without a sim card
Mar 12, 2010 | Nokia 3200
Help me please... insert simcard for n-6151
try cleaning your simcard first if its still not work try to replace your simcard...or change your sim driver in your phone
Feb 04, 2009 | Nokia 6151 Cellular Phone
PUK and PIN code for a Samsung SGH-A117
Samsung D500
Switch phone on without sim and enter :-
#*7337#
if it does not work then you need a direct unlock in a shop
Samsung A300
*2767*637#
Model: Samsung A400
*2767*637#
Model: Samsung A800
*2767*637#
Model: Samsung E500
*2767*688#
In newer phones:
#*7337#
Model: Samsung E700
*2767*688#
In newer phones:
#*7337#
Model: Samsung E715
Turn off the phone. Put a non-accepted Simcard and turn it on. Type *#9998*3323#. Press Exit. Choose menu #7. After phone reboots type *0141# and hit the Call button. Turn off and insert another Simcard. Turn on. The code is 00000000.
In newer phones:
#*7337#
Model: Samsung M100
Type *#9998*627837793#. Then type *#9998*737#. Press >/[] (Play Stop) until phone shows NCK/SPCK number. Press Exit. Type #0111*CODE# (Code is the last 8 digits of the NCK/SPCK)
Model: Samsung P400
*2767*3855#
In newer phones:
*2767*927#
Model: Samsung S100
*2767*7822573738#
Model: Samsung S105
Remove Simcard. Enter *2767*7822573738# and after phone reboots, enter #0111*00000000#
Model: Samsung S300
*2767*7822573738#
Model: Samsung S307
In newer phones:
#*7337#
Model: Samsung S500
*2767*3855#
In newer phones:
*2767*927#
Model: Samsung SGH600
*2767*3855#
*2767*2878#
Model: Samsung SGH2100
*2767*3855#
*2767*2878#
Model: Samsung V200
*2767*7822573738#
Model: Samsung X100
In newer phones:
#*7337#
Model: Samsung X600
In newer phones:
#*7337#
Model: Samsung Universal
TEMPORARY UNLOCK:
Put a non-accepted Simcard and turn it on. Type *#9998*3323#. Press Exit. You will get a new menu. Select Malloc Fail.
In newer phones:
Jan 19, 2009 | Cell Phones
I phone no sim
try removing the simcard from the iphone by inserting the end of a paperclip into the small hole at the top of the i-phone, this will push out the simcard. Then clean the simcard and re-insert it into the phone, the issue should now be resolved. if it persists then it could be because you have a faulty simcard in which case take your i-phone to your nearest apple/o2 store and they should give you a replacement.
Feb 24, 2008 | Apple iPhone Smartphone
Simcard problem
free diagram
Dec 29, 2006 | Nokia 7610
Cell Phones Logo
2,781 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
