Question about Olympus Stylus 700 / 700 Digital Camera
Lens Problem While i turn on my camera, i can hear some noise of the movement of the lens and it cant turn on to shoot picture.
    Novelist:
  • 150 Answers
The lens mechanics need to be repaired by a qualified professional,
possibly just lubricated. Get an estimate first to make sure its worth it.
Martin
Posted on Nov 12, 2008
Nikon collpix l810 lens shake automatically
The Nikon Coolpix L810 is a great camera capable of taking very good and sharp pictures, even in bad light conditions. It has a Vibration reduction, that makes it even possible to shoot pictures without tripod when you zoom in very far. If normally with the same lens length you should need 1/200 of a second your camera should still be capable of taking that picture with only the same blur from shake, with 1/50 of a second. But if you ever should use a tripod. make sure you switch off that feature. Because the Vibration reduction, works with a staking lens element. that should compensate the movement of the camera, by shaking in the correct direction opposite to the movement of the camera. The element will still shake and so blur a picture, when the camera is placed on a tripod.
Don't try to shoot pictures with the zoom on full extension, in bad light conditions. That also won't work. Lots of things can be done with the camera, but to everything is a limit. Most of the time that limit comes sooner when there is less light.
Jan 06, 2014 | Nikon COOLPIX L810
I did not get any instructions with my Opteka. Have tried to take photos with it. But they came out all blank. I used a tripod. Would like to know where I can down load instructions. Certainly not as good...
You did not provide enough information to determine what your problem is. For example, were the pictures all light or all dark. Knowing this lens, I will assume that they were all dark. So...
1) This is a very, very slow manual-focus lens. It will not auto focus. It must be manually focused very precisely because it has virtually no depth of field.
2) Depending on your camera, your internal light meter may not work. On my camera (Nikon D-90), it does. If it does not on yours and I suspect that may be your problem, you're going to have to shoot everything manually, i.e. setting the shutter speed and lens opening yourself. You can use your internal light meter to help you get started by taking your light reading before you install the lens...preferably using the aperture only setting where you set the aperture at f8 which I think is the speed of the Opteka and let the camera set the shutter speed. Make a note of the shutter speed then attach the Opteka to the camera and mount the lens on a tripod with the camera attached.
Then set your camera mode to manual and set the aperture to match the lens (f8, I think). Set the shutter speed at the speed you noted earlier. Shoot a picture using a remote shutter release or the self timer. This lens is so slow that unless you're in exceptionally bright conditions you will get fuzzy pictures due to camera movement at full zoom of 1200m and above if you're using the 2X doubler. I would start shooting at minimum zoom of 650 without the 2X doubler. Shoot a picture. and check the result.
You should have an image but it may be too light or too dark.
If its too light you'll need to increase the shutter speed or stop down the aperture to, say, f11...or both. Make the adjustment and shoot another picture. Remember that if you increase the aperture, you increase your depth of field, making focus less critical. If you increase the shutter speed you make camera or subject movement less critical.
If it's too dark, you can only increase the shutter speed because you can't open the lens any wider than f8. Make the adjustment and shoot the picture.
Keep doing this until the pictures are the way you want them.
This is a decent lens for the price and worth the little money they cost if you can't afford $10,000 plus for a high quality telephoto lens of this size. I would forget about the 2X doubler because as others have said, it further reduces the speed of an already very slow lens with such a high rate of magnification that a knat landing on the lens could cause the picture to blur from movement.
Jun 26, 2011 | Opteka 650-2600mm High Definition...
Whenever its time to take photos, the camera makes a wierd noise and the focus lens do not shoot out as normal,what should i do???
When a camera makes a noise that isn't normal, usually it's a mechanical failure of the lens.
Remove the battery for a few minutes and turn the camera on and attempt to take a picture again.
If it doesn't work, I can venture to guess that the camera's lens mechanism is defective.
Mar 05, 2011 | Samsung S760 Digital Camera
When I use camera in vr option I hear when I shooting in the end of shooting a litle clikc in camera and the screen pictures a little jumping on the screener.is it a normal or not. When I switch off vr...
The Vibration reduction system does move components inside the lens. If it makes a lot of noise you are better off turning it off and using a tripod. The VR system will move lens components to counteract your motion. The steadier you hold it (camera and lens) the less noise. On small Coolpix cameras the sensor is moved to counteract the vibration while it is hand held.
Oct 01, 2017 | Nikon 105mm f/2.8G ED-IF AF-S VR...
I have nikon d80 the lens makes a funny noise and won't focus for a picture
Not sure this will help you: In AF-S mode, the camera will not shoot until it acquires focus. Look on page 29 of the D80 manual. Now, does another lens make the same noise of only this lens. Can you try the lens on another camera? What this is attempting to do is eliminate the camera or, the lens, that way you know where to go next.
Apr 25, 2010 | Nikon D80 Digital Camera with 18-135mm...
My camera makes noise when it's turned on, but not while reviewing pictures.
hi!
What you describe sounds perfectly normal! While powering on the camera, it takes out the lens and perhaps doing some mechanical self-tests. All this means moving parts using little servos inside the camera. Same happens when taking pictures - the lens moved, the shutter closes (and reopen), etc...
While watching the pictures you've taken, you're only reading digital info. from the memory cards - no moving parts, no mechanical movements - hence, no noise!
Take care,
Pelu.
Mar 17, 2010 | Kodak EasyShare Z710 Digital Camera
Lens won't open
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 07, 2009 | Canon PowerShot S2 IS Digital Camera
Nikon D50 While shooting pictures the shutter button stopped work
TURN ON CAMERA. SEE IF THERE IS A MESSAGE. NOW, TURN OFF CAMERA. TAKE OFF LENS. REPLACE LENS- MAKE SURE YOU HEAR A "CLICK" TURN ON CAMERA AND TRY AGAIN. OK?
Mar 03, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Casio camera does not focus and now the lens moves out but the screen no longer comes on, and reads lens error
Hey shelldawg,
This is a common problem with point and shoot digital cameras caused by something obstructing the movement of the lens. The first thing I would try is blowing some compressed air into the side of the lens to try and dislodge whatever might be obstructing the movement of the lens. If this doesn't work you could try putting the camera on a flat surface with the lens pointed up while holding the shutter button in, and while doing this turn on the power. What this sometimes does is force the lens to move which sometimes will force the lens back into alignment. If neither of these options work I would have the camera looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 23, 2008 | Cameras
Lens Movement (Retraction)
Sounds like you might have bumped the lens. In for repair is your best bet
Oct 25, 2007 | Canon PowerShot Pro1 Digital Camera
Olympus Stylus 700 / 700 Digital Camera Logo
37 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
