Question about Panasonic Televison & Video
DMR-ES35V shows u99 error, have pressed the on button waited for "HELLO" then pressed on button again as suggested in the Troubleshooting part of the operating manual but it will not startup it does not display what drive it is in and the select drive button is not functioning will only display the current time on the display window?
Hello, I found a receipt for my VHS and it is still under warranty until the end of december 08.
It is now in the electronic workshop being repaired.
Thanks for your follow up
Gary
Posted on Nov 07, 2008
U99 error code on dmr-es35v panasonic recorder what is this?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Error code details to many popular devices are given.
Feb 12, 2015 | Panasonic DMR-ES35V Multisystem Code free...
Panasonic DMR-E80H "u99" error message?
It sounds like the HDD is finished, it could not recover, you could see if a computer repair store can help, they have the tools and the software to take it further, but I would consider cost for the attempt.
Apr 02, 2012 | Panasonic DMR-E80H DVD Recorder
I have a Panasonic DVD/video recorder DMR-ES35V which will currently not record or play either DVDs or videos. The message on the front screen reads "A1". I don't know what I have pressed to...
Hello Shonz!
Is there any other error code that follows A1?
Just like a U61 if there is any, just post it back here.
So we could figure out the real problem.
May 28, 2011 | Panasonic Televison & Video
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
DMR-ES35V Switched on this morning and it said hello then put U99 on the display.I followed the instructions and switched off then on again but it went into the same display. It did open the dvd so i...
To initialize ALL parameters to factory defaults: With the unit OFF, press "Skip Rev" ({<< ) and "Time Slip" and "Open/Close" for 5 seconds.After this wait 1 minute and press on/off buton...thats all..
Apr 13, 2010 | Panasonic DMR-ES35VS
Panasonic Video/dvd player DMR ES30v Fault code U99
Hi,press the power button on the dvd so it goes to standby,then press the power button again to turn the unit on.I hope this helps.Jamie
Mar 12, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
PANASONIC DMR-ES35V have error code U61
From User guide:
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
Feb 26, 2009 | Panasonic DMRES15 DVD Recorder
NO FUNCTIONS
Replace the Digital board
Feb 26, 2008 | Panasonic DMR-E50 DVD Recorder
Televison & Video Logo
386 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
