Question about Electronics - Others
I have a Gigaware 4GB flash drive. When I initially moved my files to the disk, I was prompted for a password to encrypt the drive. I didn't select one because I didn't want one or need one! I
  • 27,725 Answers
When it asks for a password try just clicking in the password box and see if it accepts it
also you could download some software http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.htmlDr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
hope this helps you
Posted on Mar 20, 2012
SOURCE:
  • 26 Answers
SOURCE: Unable to access files on the flash drive
SDHC cards are not backward compatible with normal SD cards..therefore older devices will not recognise them...your built in card reader is probably not sdhc...try downloading directly from camera or use a sdhc usb card reader
Posted on Apr 29, 2008
SOURCE: flash drive write protected can't move files
Anyone can help me to my problem with my 2GB imition USB flash drive, it has been writed-protected and there is no switch to disable it, what should i do to this kind of protection. plzzzzz help...
Posted on Nov 21, 2008
bob_computer
  • 3153 Answers
SOURCE: SanDisk Usb Flash 8GB unable to format
TRY SOME OF THESE STEPS BEFORE YOU THROW IT
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 17, 2009
SOURCE: I have a cruzer micro 16Gb flash drive with 14.9Gb
Did you reformat as NTFS instead of the default FAT32? FAT32 can only transfer files up to 4.0Gb in size. If you reformat as NTFS, you can move larger files.
Posted on Oct 09, 2009
laikexpert
  • 281 Answers
SOURCE: how do I get info to correctly use my san disk flash drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Posted on Jan 30, 2010
Decrypt files on a mac
Maybe there is a version of the software you used to encrypt that is compatible with mac ?
May 05, 2012 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Tip
What is the Windows XP Administrator Password?
<p>Windows XP, the most popular versions of Windows, was widely installed by PC users. Do you remember after you installing your first copy of Windows XP, how long did it require you to realize that you didn't know the administrator password? I vaguely remembered that it was about a week before I needed to make some changes in the file system. It suddenly came to me to be logged on as an administrator, but I do not know the password of the administrator! <br /> <p> <br /> <p><img src="windows-xp-administrator-password.jpg" /> <p><br /> Luckily, Windows XP (both Home and Professional versions) have a "hidden" administrator account which is autogenerate when install. This account usually doesn't show up on the logon screen and most people are totally unaware of its existence. Usually it is ok because we didn't need to user this account very often, only when we don't know the administrator password, need access to the Windows XP recovery console or boot into Windows XP safe mode, the default <b>Windows XP administrator password</b> would come in handy.<br /> <p><br /> What is the Default Administrator Password in Windows XP?</b><br /> <p><br /> Knowing the default password of Windows XP administrator account would be very useful.<br /> <ol> <li>Try to leave the password blank. Simply press Enter without typing anything.</li></ol> <p>The default Windows XP Administrator password is defined to blank during the initial Windows XP installation process.<br /> <ol> <li> Enter the password for your account. It often depend on how Windows XP has been installed on your computer and what part of XP is asking for an admin password, the main user account will also be configured with administrator privilege.</li></ol> <p><br /> I Forgot my Windows XP Administrator Password!</b><br /> <p><br /> Windows XP User Accounts applet in the Control Panel functions is to create a password reset disk wizard. Using this wizard, a floppy disk or USB flash drive can be used to create a specific password reset disk for specific user account on a specific Windows XP computer. The password reset disk can only be used with the computer it was created on and it can also be reused to reset the account's password multiple times. However, you need to know the password of the account you want to create the reset disk for, and you must create the reset disk before you forget the administrator password <br /> Here is how to <a href="http://recoverlostpassword.com/products/windowspasswordrecoery.html">reset XP administrator password</a> with the XP password reset disk:<br /> <ol> <li>Insert the XP password reset disk to the computer</li> <li>Click the Use your password reset disk item on the XP logon screen to start the Password Reset Wizard. Click the Next button</li> <li>Follow the instructions to create a new password. </li> <li>Logon with the new password.</li></ol> <p><br /> I Didn't Create a Password Reset Disk!</b><br /> <p><br /> OK, if you <a href="http://recoverlostpassword.com/products/windowspasswordrecoery.html">forgot Windows XP administrator password</a> and don't have a password rest disk, you won't be able to create a password reset disk anymore. Instead, there are several things you can try to get access to your windows. <b>SmartKey Windows Password Recovery</b> is your ticket. This password recovery tool not only works on Windows XP, but also on all releases of Windows NT/2000/Vista/ 7 and Windows Server 2003/2008. It works by booting from a CD/DVD or USB flash drive and reset the <a href="http://recoverlostpassword.com/products/windowspasswordrecoery.html">forgotten Windows XP administrator password</a>.<br /> <p><br /> <b>NOTE: </b>If you change the administrator password on a Windows XP or Windows Vista system with the Encrypted File System (EFS), all of the encrypted files will become inaccessible. The password for the Administrator account is used to create the EFS encryption key. Changing the Administrator account back to using the original password should restore access to the encrypted files, but I have never tried it.<br /> <p> <br /> <p>If you only need to blank the <b>Windows XP Administrator password</b>, here are the basic steps:<br /> <ol> <li> Download and install SmartKey Windows Password Recovery software.</li> <li> Burn the software to CD/DVD or USB flash drive. </li> <li> Insert newly created CD/DVD and reboot your computer from the CD/DVD or USB flash drive </li> <li> Reset the forgotten Windows XP password, remove the CD/DVD or USB flash drive and then reboot the computer</li></ol> <p>Having the capability to reset <a href="http://recoverlostpassword.com/products/windowspasswordrecoery.html">forgotten XP administrator passwords</a> and regain access to a locked computer can be a great time saver, but should only be tried by an IT professional. you may probably make things worse rather than better if you use sophisticated system or manipulation tools<br /> <p><br /> <p>Article Source:<a href="http://recoverlostpassword.com/article/windows-xp-administrator-password.html">http://recoverlostpassword.com/article/windows-xp-administrator-password.html</a><br />
on Apr 15, 2011 | Computers & Internet
I have two Iomega 1TB 2.0 USB eGo harddrives with the encyption utility. I have the Windows 7 O/S. Initially, I plugged both harddrives (eGo) into my laptop, and created the password for each of the...
Iomega Utility are not Specific to the current device.
My iomega ego external hard disk was working properly but when i connected it today the encryption utility show that-Iomega Utility are not Specific to the current device and no any area shown to type password. My drive contains lots of valuable data. How can I acess into my drive. But the virtual drive is shown.
Aug 25, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
I have a transcend 4gb pendrive.Can I able to set a pasword for it. Any utility is available to protect my pendrive?
Hi Vgvimalgouta,
To protect your Pen Drive , Please follow the below steps :-
  1. Physical Security is the best security in case of Pen Drive, I would say keep the Pen Drive out of reach of anyone but you.
  2. Make sure that you keep only the data that you have already encrypted , if it's very confidential, for e.g. password protect your files and folders into one zip/rar archive , so that even if someone get's your pendrive , he would not be able to have access to your files and folders.
  3. There are many paid software for protecting files and folders, However I know of a Free application that can help you out.
  4. The free Application is Remora USB Disk Guard , You can download the application from this link -- http://bit.ly/moVnDu
Hope this helps ..:) Your feedback would be appreciated.
May 19, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
When i plug it into my computer it comes up as a cd drive with 0 bytes free of 0 bytes im running windows 7 now but when i got it i was running windows xp
Some flash-drives imitate a CD-disk (which, after being written and "closed", always show up as having "zero bytes free space"), in order to automatically run some software from the flash-drive each time that the flash-drive is connected to a computer. For example, that "auto-run" software may be a file encryption/decryption routine, requiring you to enter a password to access your files.
So, if you "lose" the flash-drive, whoever finds it cannot access your files, without having your password.
Apr 27, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I want to save the files on my gigaware flash drive that needs to be reformated. How can I save my files? I have adobe, word, and powerpoint presentations saved to the drive.
make a folder on your C: drive, name it what ever (San4) stick the San Disk in your usb port. get up my computer, find the San Disk, right click on it, on the open menu find "copy" and click on it. then get up your C: drive, find the folder you made (San4) right click on the folder and select "Paste" from the menu and every thing on the San Disk will be copied to a file called San4 on your "C" drive
Jan 11, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I want to "lock" the flash drive with a password.
    Encrypt Individual Files and Folders on a Flash Drive
  1. Step 1 Choose "Tools" from the menu bar at the top of the program, such as Microsoft Wordmag-glass_10x10.gif, and pick "Options."
  2. Step 2 Select "Security" from the many tabs displayed in the new popup window. Create a password in the "Password to Open" or "Password to Modify" section and click "OK" at the bottom of the box.
  3. Step 3 Confirm your password when prompted. Drag the password protected files to your flash drive. To open a protected file, enter password when prompted. Remember, passwords are case sensitive.
  4. Encrypt Entire Flash Drive
  5. Step 1 Download and install the freeware program "Cryptainer LE" onto your PC or laptop. Enter a meaningful password from 8 to 100 characters and define the file location and size, which you can change at a later time. Enter your password when prompted.
  6. Step 2 Install Cryptainer Mobile when the Cryptainer LE installation is complete. Select "Tools" on the menu bar at the top of your screen. Select "Install Cryptainer Mobile" and follow the prompts. The Mobile version comes with the LE download.
  7. Step 3 Close the LE version on your desktop. Select a location and meaningful password for the Mobile version. To protect important files and folders, drag and drop them into the vault, the location of the encrypted files.
Jun 24, 2010 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
My PNY 4GB Flash Drive says it is full, but I can't see that anything is in it. Is there something I can do to fix that?
may be files are hidden.go to tools menu->folder option->view tab,and select 'show hidden files & folders. 2)if nothing showing in drive formate drive.
Jan 11, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Can I password protect my Cruzer USB 2.0 Flash Drive, 4 GB for in the case I loose it?
The Cuzer has its own encryption software. Plug the Cruzer in a USB 2.0 prt on the computer. If the Cruzer LaunchPad does not execute by default, use the Windows explorer to explore My computer. You will see two icons related to your cruzer, one of them is a CD_ROM. In fact it is the LaunchPad of the U3Smart OS that come swith the Cruzer.
Click on the CD-ROM icon and an a yellow icon (U3) installs on the system tray. Click on it. A pop-up window deploys. Click the Settings button on the right side (2nd menu on the right, under explore drive). You will have to configure U3 LaunchPad Settings. Select Security and enable security.
You will be prompted for a password.
Warning: If you use the Cruzer on Macs or Linux, you will not be able to open it on these OS's if security is enabled. You will be able to open it on Windows only.
Hope it helps.
Thank you for using FixYa.
Nov 18, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Electronics - Others Logo
125 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
