Question about Acer Aspire 5580 Notebook
Turn On Problem
Laptops battery get discharge automatecally when it shut down at night
every day in the morning i have to recharg the battery again
i think this is due to battery. so i puchase the one, but the problem is still there
plz give me the solution on this
Regards
Amol
    Master:
  • 461 Answers
Are you sure you are actually shutting down and not entering sleep mode? Sleep mode does use power while it appears to be off, it resumes instead of powering on. Have you tried removing the battery when charged and allowing it to sit over night or a full day then check the charge level. If the battery discharges regardless of being inserted, then the battery is at fault.
Posted on Dec 06, 2008
Frozen tablet.
If it does happen again I would replace the battery. They only last for about three years.
Terry
Mar 20, 2014 | Samsung Galaxy Tab 2 7.0
Tip
Brightness: how low can you go? Without any question, the fastest way to ****...
Extend your battery life on your laptop, do not leave it plugged in and charging all of the time. When a laptop is constantly charging, it will deplete the cells on the battery. Two ways to combat this, charge your laptop fully and remove the battery while it is plugged in, or you can run your laptop on battery power a few times a week until the battery dies.
on Mar 08, 2010 | Computers & Internet
Tip
Tips to maximise hp laptop battery life: Brightness: how low can you go? Without...
Hi, when you purchase a laptop, or you have a laptop with good battery life, once a month unplug the mains and use the laptop until the 'battery needs recharging' warning appears, or until the laptop 'dies' then recharge the laptop as usual. You can continue to use the laptop whilst recharging is in process. This will help keep your laptop battery in good condition. It doesn't matter if its a NiCad, Lipo or Lithium Ion battery, they DO all have battery memory and benefit from this process.
Gateway 6920
The dying hdd cause some problems. Replace the hdd.
Feb 21, 2014 | Computers & Internet
Battery will charge to full then discharge without charging again
I am not an expert but I would try completely powering off my device before charging. There might be apps that are running in the background causing the battery to drain once again after fully charging it.
I hope this helps.
Sep 17, 2017 | HTC One V Android Unlocked Quad Band Gsm...
Dell 1737 laptop won't turn on (A/C or battery powered). Last night I tried for 15-20 minutes then it worked. This morning it didn't work again (from stand by mode). I held the power button to shut down...
you have a BIOS bug when hibernation , leave without battery for few days try to turn on with the charger, and if turns on go to the battery settings and disable the hibernation option, later go to dell website and update your system BIOS.
please rate me
Aug 13, 2010 | Dell Studio 1737 Laptop
My laptop doesnt start. It's not working. I was just using it last night. I was working well. I shut it down properly as I should. This morning when I turn it on. It didnt work.
Hi there, try to remove the battery, clean the terminals, then place it back, chances are the battery was dislodge. test again. hope this helps.
Aug 06, 2009 | Computers & Internet
My charger is not working since morning. it was well and good last night.
What do u mean it's not working...??
Check for any loose connections...
It's a laptop charger, and u said it was workin' fine last night, then there's bound to be a loose connection......
If nothing else [like thunderstorms, voltage fluctuations, or any other harmful incidents] hasn't occured, it's connection prob....
Try using different plug-points.... Try checking the adapter if it's correctly connected or not...... If none of this works, call a comp spec.....!!
Jul 08, 2009 | Computers & Internet
Acer Aspire 5580 Notebook Logo
107 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
