Question about Cameras
Canon AS590IS - flash will not fire. - Cameras
How do I use this flash as a slave?
You need to set the flash to slave and the same channel as the master. If the flash doesn't have this function it may be able to be fired optically. Set the master flash to low power and set the off camera flash to optical.
Jul 15, 2015 | Sunpak DigiFlash 3000 External Flash
Canon pc1251 flash won't fire
If it even won't fire in a manual mode, when it is dark and you did press the flash button, it could be defect. Be aware that in some Basic Zone modes the flash won't fire. If you did put it in sport and in a few other modes it won't work. So try it in dark and don't forget to switch the flash on.
Dec 10, 2014 | Canon Cameras
Canon Speedlite 580ex ii - won't work with camera
Caroline, you should try to set the camera on "M" and the flash in 2nd curtain flash sync.
Or set flash in ATG wireless IR ETTL Slave modes and pop-up the flash on Canon EOS-70D.
Truly,
atdlee@netzero.com
Feb 08, 2014 | Canon SPEEDLITE 580EX TTL Flash
Rebel T3i built-in flash does not fire
Most Canon DSLRs have a switch in the hot shoe (if you look under the spring plate in the hot shoe one one side there is usually a small white shaft sticking up from underneath the top cover). Sometimes because of spillage etc. this shaft sticks down and the camera thinks that there is an external flash installed so it won't operate the built in flash.
In your case I would be more suspicious of the flash board. Does the flash symbol in the viewfinder light up? When you fire the camera does the symbol go out but the flash doesn't fire? This is a pretty common sign of a bad flash board.
A third possibility would be a broken flash tube. Has the camera been impacted?
Put the camera's mode dial on 'P' and push the flash button on the side of the mount/front cover. Does the flash pop up? Does it fire now? On the P,A,S,M setting the flash fires all the time if it is popped up; if it is one the green rectangle or other setting it only fires if there is not enough light.
Finally reset the menu to factory default in case something is selected that is causing the flash not to fire.
Apr 30, 2013 | Canon EOS 600D Rebel T3i Digital Camera
I have been using my Canon 580ex ii with my Canon 5d mark ii. It will not fire at all now. I also tried my old 420 ex speedlite and it will not fire either. But, they both work on my Canon 40d.
You can actually set the external flash not to fire in the menu settings of your camera. Check there or try mounting the flash on your camera, turn both on and reset your camera to factory default settings through your camera menu settings.
Oct 08, 2012 | Canon Speedlite 580EX II TTL Flash
Canon 580EX II Flash is not firing??
It could be the bad bulb. You need to replace the entire bulb assembly. Canon Speedlite 580EX II MYK Camera Camcorder Repair
Apr 22, 2017 | Canon Cameras
430EX won't fire.
Can you short the pins to have the flash fired?a.l9609@gmail.com
May 27, 2009 | Canon Speedlite 430EX TTL Flash
Camera does not fire external flash
Is it in manual or auto modes (camera)Try resetting the camera back to factory defaults as a first step.
Feb 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon flash speedlite 550 ex ttl
Send the flash back to canon for Service this is not something that can be fixed in this forum. Do not use the flash the burning smell indicated a potentially dangerous problem and fire hazard.
Jan 09, 2009 | Canon Speedlite 420EX TTL Flash
Flash 550 lcd screen lighs up but will not fire the flash
$300. ? To REPAIR? Way out of line. Replace the unit with a similar flash or go for another brand. SUNPACK flash units are reasonably priced and the have models that work with Canon abd orher cameras.
Ed
May 29, 2008 | Canon Speedlite 550EX TTL Flash
Cameras Logo
42 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
