Question about HP LaserJet 4250n Printer
Hp 4250N Printing multiple pages in one sheet feature not found over other pc. The printer installed at another pc via LAN and is shared.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Printing from my iPad via my laptop
You can unofficially use air print to print from your ipad to your printer. The only catch is the ipad must be on the same network as the printer is. use at your own risk
IF you are using a pc to access the printer there is a free application to allow you to do that. Found here:
  1. Make sure you have itunes 10.1 or higher
  2. Make sure the printer is setup as a shared printer on your local PC
  3. Printer and iOS device should share the same Wifi connection
  4. Make sure you have full administrator privileges to enable / disable services on your PC
  5. Download AirPrint installer (Found here: http://www.mediafire.com/?yadd9be20rkdpe5)
  6. Follow the on screen instructions for installing. And when finished Windows Firewall will prompt you allow or deny AirPrint features to be shared over networks. Click on Allow access button.
  7. I have had success with this with Canon printers but offically ony a hand ful of HP printers work with this. Still, worth a shot.
Mac options Air Print Activator found here: http://netputing.com/airprintactivator/ The only catch is it's Mac OSX 10.6.5 and above. (Snow Leopard) This is a free version.
Hope this helps
Jan 13, 2011 | Apple iPad 32 GB 3G Tablet PC
HP Color Laser Jet printer CM1312nfi: scanner no longer working; when I try to scan, receive error on printer:scanning error, cannot connect. Printer is networked. This error occures only on a networked...
Go to your network and sharing center. Choose homegroup and sharing options. Change advanced sharing settings. Under your home or work profile, scroll down to file sharing connections. Switch to enable file sharing for devices that use 40 or 56 bit encryption. If that does not work, under password protected sharing, select "turn off password protected sharing". This is not recommended if you use your computer in multiple locations (laptop). I have found that turning all of these features off, running a scan from the printer successfully and then turning them back on, Windows seems to be comfortable allowing the printer to connect to the computer.
Jul 22, 2010 | HP LaserJet CM1312 All-In-One Printer
Can't print to HP 2600n over network
The LaserJet 2600N has a built-in print server and can be connected to the local network (normal ethernet cable) directly. While printer sharing via Windows should work, I found it much more convenient to access it without the need of a hosting computer - you do not need to switch on the desktop PC for printing from the Laptop, for example, its also printing faster.
Jan 25, 2010 | HP Color LaserJet 2600n Printer
Hp laserjer p1008 printer wants to share with 10 hosts but printing not done properly by shared users so pls assist me for proper printing through network (Domain) host?
Please check your LAN settings and cross check your printer is on shared mode and check all the computers that all are having install that printer whatever the want to shared by them.
Sep 29, 2009 | HP xw4600 Workstation Linux Installer...
Can HP 1410 printer support LAN.
HP 1410 is not a network printer. If you want network printing, you must purchase a printer that features network printing.
You can designate a pc to act as network server and plug printer into that server, and then print from another computer on the same network
May 28, 2009 | HP PSC 1410v All-in-One Printer
Setting margins on printer
Well, by now you may have found the solution, however, make sure that in MS WORD under File > Page Setup > A4 is selected, and if you still this prompt (error), just click on OK and proceed with printing.
The Laserjet Printers are capable to print upto 5mms from the edge of the border.
Regards,
Nikhil
Mar 17, 2009 | HP LaserJet 4250n Printer
Laserjet 3015 is printing multiple pages on one sheet
exists special function in driver of the printer which quantifies pages of the document on one signet sheet. Sounds like "Multiple printing" you can manipulate or disactivate this function.
Mar 07, 2009 | HP LaserJet 3015 All-In-One Printer
Printing on every other sheet
try to reinstall the driver...thanks
Nov 05, 2008 | HP LaserJet 4250n Printer
Offset printing
Chect to see if this happens when printing from different programs.
try downloading and installing a current driver from the Hp website.
run test prints from the control panel to see if it's the printers fault.could be a bad formatter.
Apr 04, 2008 | HP LaserJet 4250n Printer
We have XEROX FaxCentre 123.
1. Instead of printing / copying page by page, collate the print...see the options while printing...it will look like 111,222,333 OR 123,123,123 etc.,
2. connect the machine to LAN network by using the LAN module
3. if LAN module is not available, connect a PC to it directly and make it the print controller -> share the printer -> install drivers in other pcs and ..... start printing
have a nice day
bye
I hope my solution was useful
Feb 23, 2008 | Xerox FaxCentre F110 Plain Paper Laser
HP LaserJet 4250n Printer Logo
69 people viewed this question
Ben Johnson
