Question about Belkin Computers & Internet
Every time I switch on my computor it tells me that there is no network connection so I have to connect the ethernet cable I have tried to reset the router but this still happens
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to re-install the driver of your LAN
Posted on Nov 05, 2008
49.ff04 service error
Try changing the network cable. Connect the other end to another port of the ethernet switch.
If it doesn't work, remove the Network cable and using the printer console reset printer to factory default so that printer use DHCP.
Connect back network cable and try again.
Some people powered down and remove & cleaned the RAM edges. Removed and reset the EIO network interface.
Dec 25, 2013 | HP LaserJet 4100 Laser Printer - Plain...
There is no connection to the other pc
3 ethernet cables 1 ADSL modem and 1 hub is needed to network computers together.
1. connect telephone cable to modem and switch it on. 2. one end of an ethernet cable is connected to the modem . consider this master ethernet cable. connect the other end of this to the master hub port. 3.now connect pc and any hub port with another ethernet cable(ec) say ec1 4. likewise ec2 to another pc .
try this out to get net in both pc's
Jan 12, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Cannot connect laptop with the eithernet cord
If you cannot connect your laptop using an Ethernet cable, make sure the laptop's wireless ethernet is disabled. To disable it in window xp, click the Start button and open the Control Panel. Double-click Network Connections. Right-click Wireless Network Connection and select Disable from the drop-down list.
04e3ee0.png If you are using a laptop with Windows Vista, click the Start Button and type Network and Sharing into the Start Search box. Select Network and Sharing Center from the Programs list. Select Manage Network Connections from the left pane of the window. The Network Connections window will open. Click on Wireless Network Connection. Select Disable this Network Device at the top of the window.
9a7c8c6.png Troubleshoot the Network
After disabling the laptop's wireless connection, be sure to restart the computer before trying to connect with the Ethernet cable again. If you still cannot connect the laptop to the network with an Ethernet cable after rebooting, check to make sure there is not a problem with the network itself. If there are others nearby connected to the same network, such as in your office, dorm or another public location, ask them whether they are currently able to connect to the network. If no one else is using the network, contact the system administrator or your Internet service provider to see if there may be an outage. This step can save you plenty of time troubleshooting if there is an outage in your area!
Troubleshoot the Ethernet Cable
If there is no problem with the network itself, the reason that you cannot connect the laptop may be the ethernet cable. Make sure that the Ethernet Cable is securely connected to both the laptop and the wall outlet. If possible, try connecting the Ethernet cable into another wall jack or port on the router, and then try using a different Ethernet cable. The Ethernet cable you are using may be damaged.
8686681.png Troubleshoot Network Settings
If the Ethernet cable does not seem to be the reason why you cannot connect to the network, check the laptop's network settings. In Windows XP, open the Control Panel and select Network Connections. Open Local Area Connection and check the status of the connection.
In Windows Vista, go to the Network and Sharing Center and select Diagnose and Repair from the left pane and wait for the results.
If the Local Area Connection is listed as Disabled, right-click it and choose Enable.
If it says that the network adapter is unplugged and you have ruled out a problem with the Ethernet cable and port, the laptop's network adapter may have failed. Try using the same Ethernet cable on another computer. If you are able to connect to the network on another computer using the same Ethernet cord, contact the laptop's manufacturer, a computer repair technician or replace the network adapter yourself.
fc4831a.png If the Local Area Connection is listed as Disabled, right-click it and choose Enable.
Oct 28, 2009 | HP Pavilion dv6000z Notebook
How to connect dlink 1008v for more than 1 computer
you will have to buy a Ethernet cable and connect
if you still cant connect with both pc but with each one but not at the same time then call Dlink because ur router is assigning the same IP´s to ur PC´s
but just get the ethernet cable and that should take care of it
, July
rate me please
Mar 26, 2009 | Computers & Internet
Can't connect to the internet
TRY RESETTING THE MODEM SWITCH OFF THE MODEM FOR 5 MIN THEN TURN BACK ON THE RECEIVING WILL BLINK THEN GO TO STEADY ON WHEN YOU ARE CONNECTED ALSO YOU CAN REPAIR THE CONNECTION BY LEFT CLICKING THE CONNECTION ICON ON YOUR COMPUTOR
Jan 19, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
A network cable is unplugged
OK, in order to solve this problem, I will need more information:
1) What is your operating system (i.e. Windows XP? Windows Vista?)
2) Is this a laptop or a desktop computer?
3) If it is a laptop, is there a switch on the case that turns on and off the wireless ability? Check your user manual - it might be as simple as turning on the wireless switch.
4) If it is a desktop, what kind of wireless adapter did you install?
I'll be able to help more when I get this information. In the meantime, here are a few things you can do:
First of all, you need to delete all of the duplicate connections from Network Connections. They won't really hurt, but they're not helping either. To delete them, just right-click on them one at a time and choose "delete."
Next, you need to understand what the message "a network cable is unplugged" refers to: this has nothing to do with wireless. If there is no actual hard-wire cable connected to your computer, the port (that's the opening that you plug a network cable into) will tell Windows that it is empty. This results in the message "a network cable is unplugged." You can ignore it, or - if you plan to use this computer with a wireless connection only - you can right-click on the connection in Network Connections and choose "disable." This stops the message from appearing, and can be reversed (enable) at any time.
I look forward to hearing from you.
Jan 04, 2009 | Televison & Video
Getting wireless computor and router back on line with desk top computor
1. Disconnect power from your modem and router
2. Connect an ethernet cord from your modem's ethernet port to your router's Internet or WAN port.
3. Connect another ethernet cord from a port on your router (labeled with a "1" above it).
4. Connect power to your modem and router.
5. I'm a little unsure about how you plan to connect your wireless computer to the router. The router you selected when you created this question is not wireless-capable.
If your router is wireless-capable, go to the wireless computer. Follow the instructions for your operating system below.
Windows XP
1. Right-click on the My Network Places icon on your desktop, and select Properties.
2. Right-click on Wireless Network Connection.
3. Right-click on View Available Wireless Networks.
4. Double-click on your network from the list that appears (it should be called "linksys" if you didn't change the name).
Windows Vista
1. Click on the network icon on the lower-right of your screen (it should look like two computers with one behind another. It might have a red "X" over it.)
2. Click "Connect to a network" (it also might be labeled "Connect or disconnect")
3. Double-click on your network from the list (it should be called "linksys" if you didn't change the name.
Mac OS X
1. Click on the AirPort menu in the upper right of your screen (it looks like "("s turned on their side).
2. Click on your network in the list that appears (it should be called "linksys" if you didn't change the name).
Sep 30, 2008 | Linksys EtherFast Cable/DSL Router
No default gateway !
This usually means that your network is connected but your computer can't obtain an IP address or default gateway from the ISP (Internet Service Provider) or router. Without an IP address, your computer cannot communicate on the network.
Jan 13, 2008 | Computers & Internet
Not able to connect to the internet
Please list the model of the network hub you are using.  Also is a "hub/switch" or a routher.  Also are you using a DSL or Cable internet connection?  Please provide a little more details.
Oct 26, 2007 | NetGear (GS608UK) 8x1000 Mbps Networking...
Computers & Internet Logo
18 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
