Question about Radio Communications
My transceiver yaesu ft-one can't received/monitor and transmit
Before, this product performed well. After more/less 10 years I never use, right now the transceiver can't received nor transmit but the lamp and indicators is turned on. What wrong? Tx
  • Anonymous Mar 16, 2014
    I've, by mistake of course, wrongly connected the + and - terminal the opposite way to the external power source. On correcting it rightly, the panel now shows "tx error". How do I go about rectifying it.
  • Anonymous Mar 28, 2014
    accidentally transmitted into ft 450 with power off now ft 450 will not tx put all other functions work
Thanks 4 your advice.
I left the radio w/o any batteries (the only battery is back up memory battery) in that time, and when I try the radio I used new batteries. The power supply for the radio is build in (uses 30 amperes switching power supply) and I have checked that the power supply is in a good condition. I suspect that PLL unit is not working so can't oscillation to generate frequencies.
The problem with sending the unit to the factory to be serviced is not worth (cost > benefit/ radio value).
Do you have another idea to help me? Please.. Thanks
Posted on Nov 06, 2008
  • 55 Answers
Did you leave a battery in the radio that caused errosion? Try a brand new battery...and if all else fails. Do as Chris suggests, take it to a radio shop that services that type or brand of radio.
  • 41 Answers
I understand that You have a problem with the TX/RX. The problem with your radio is one that can't be solved with out actually looking at the radio on the bench. The only thing I can tell you is to either go to your local radio shop or send the unit to the factory to be serviced. One thought that does come to mind though is that your battery may not be working most rechargable batteries are only good for about 18 months. There may not be enough charge to operate the radio.
Posted on Nov 05, 2008
I am getting a "Err" message when trying to transmit
Almost always a programming issue. Somehow, the transmit frequency is not enabled or programmed correctly. Always include all the zeros when programming these. The decimal point is critical also.
May 24, 2016 | Yaesu Radio Communications
Radio power`s on but no transmit or receive on ssb however it will transmit with full power on fm
If your receiver was operating previously but now the SSB option is not working, very likely the sideband detector has failed. I'm not directly familiar with your Yaesu unit but, in most Yaesu transceivers, the SSB chip and control circuit (including diodes) is identified in print on the main board.
May 16, 2015 | Yaesu FT-990 DC Transceiver
Need to know the capacity needed for power supply
Manual specifications: 60 VA for receive, and 470 VA for transmit @ 100 W. Radio will take 100-117 or 200-234 VAC +/- 10% 50/60 Hz.
Apr 01, 2015 | Yaesu FT-990 DC Transceiver
My Yaesu Ft-857 transmits ok on 2 meter. But the receive only work sometime?
Sounds like a bad receiver in the radio.
Have you checked the VSWR of you antenna system?
Did it ever work with the current setup?
If so has anything changed with the programming of the radio or the antenna system?
Does 70cm work OK?
Are you sure menu item 080 is set to "SQL" and not "RF-GAIN"?
Are you sure the receiver is not programmed for tone squelch?
Either of those settings could cause receive problems if not used properly.
Sep 26, 2014 | Yaesu FT-857D transceiver
How ti unlock transceiver radio Yaesu FT 1900R to transmit beetwen 136 to 174 Mhz
Here is a link to a forum that has instructions for how to make the modification: http://www.worldwidedx.com/threads/expanded-tx-mod-for-ft-1900r.37171/
Aug 19, 2014 | Yaesu Ft 1900r Vhf Mobile 55 W Two Way...
How to turn beep off when transmitting
all the beep is for is so people can tell when you are done transmitting. There should be a push knob or button or just a plain old knob that has R.B. printed next to it . Turn it off.
Apr 12, 2014 | Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile...
Any frequency over 148.000 i cant talk on, i can just listen. anyone know why?yaesuft1900r
The Yaesu FT1900R is an Amateur (Ham) Radio 2-meter Transceiver. Although the receiver covers from 136-174 MHz, will only transmit from 144-148 MHz. Please note that you do need an Amateur (Technician Class or above) License to transmit on the 2-meter Amateur Band. You no longer need to pass a Morse Code test to get an Amateur License. You still have to pass a written exam, but that isn't difficult if you are willing to study a bit. Contact your local Ham Radio Club or the American Radio Relay League (A.R.R.L.) for more information.
Dec 26, 2013 | Yaesu Ft 1900r Vhf Mobile 55 W Two Way...
How do i get expanded freqs on my ft1802 yaesu tranceiver
The FT-1802 is a 50 watt 2 meter FM transceiver. It can transmit anywhere between 144 - 148 Mhz (the FM portion) of the 2 meter ham band. It can receive anywhere between 136 - 174 Mhz without any modifications. There is a modification to enable transmit "out of band" below:
http://www.ham.dmz.ro/yaesu/ft-1802-extended-transmit-modification.php
There are few details about the results of this mod - typically these provide for transmitting on frequencies outside (above, below or both) of the 2 meter ham band. Transmitting outside of the ham band without a proper license for the frequencies in the U.S. is a violation of FCC rules.
Sep 08, 2009 | Yaesu Radio Communications
I have a FT-8900 and want to be able to open the AM side so I can use it on frequency 26.805 is there anyway it can be done
The Yaesu FT-8900 is a quad band FM transceiver only. It can not be modified to receive or transmit AM, SSB, RTTY or CW. It works on all or portions of 70 centimeter, 2 meter, 6 meter and 10 meter bands. The 26.805 Mhz frequency is 11 meters, so it is out of range of the 10 meter band in the radio, it is close. Even if able expand the transceiver, the AM / SSB mode commonly found in this band makes it impossible to use. Further, the radio is not FCC Type Accepted for use in this band.
Sep 05, 2009 | Yaesu Radio Communications
Radio Communications Logo
245 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
