Question about Microsoft Windows Live OneCare 1.5 for PC
What do I do to fix this.
In Manage your onecare circle.Make this a hub PC. will not show up. So I have no hud PC.I have two PCs.It will not Show up on nether one
  • Anonymous May 09, 2009
    Hub OS died - can't create new hub.
    Brigadier General:
  • 10,406 Answers
Nominate one of your PCs as the "hub".
Posted on Dec 02, 2009
The HUD on my 2004 Pontiac Grand Prix GT went out. I checked the fuses and they are all okay. What eles could it be? Thank you, Lisa
The HUD may still be working but the spring has broken which holds the mirror to reflect the monitor image to the windscreen. Go outside the car and look straight down the HUD tunnel to see if the HUD is still on. If it is, then do a search on google for how to fix the hud. There are some very detailed instructions (with pics) to show you how to do this. Really pretty simple.
Jul 27, 2011 | 2004 Pontiac Grand Prix
My toshiba satellite L300, has lost sound. when i play it show the sound bars, but nothing is coming out
Check the device manager to make sure the sound drivers are installed. to do this you right click my computer then click manage. when the computer managment comes up, click Device Manager. Look to Sound, video and game controllers. Make sure your sound driver is installed and does not have a red X or yellow circle with a exclaimation point in it.
if you have sound drivers installed as above would show; you need to check your levels. here is a location to show you all this: http://www.tinyeye.com/avsetup/soundsetup_xp.html
if these are fine then you need to look at the side of your unit. some toshibas have a volume control by the headphones. Sadly enough this does not just control the headphone sound but controls the speakers as well. Turn it up if it exists.
Jun 29, 2011 | Toshiba Satellite Pro L300-EZ1501 Notebook
CSH-800 8-Port Ethernet Switch Problem When i switch the power on, only the POWER LED light up and nothing is happened, computers cant detect it
Switches arnt not detectable by the computer, a switch allows you to link multiple pcs togethers that sit on the same domain/workgroup , and also network subnet, the other lights will come one when you connect a RJ45 cable between the unit and a PC to show a port is in use.
May 10, 2011 | Cnet CSH-800 8-Port Ethernet Switch
Conflict message
if u have 2 PCs connected to the hub/router then you must specify the IP address in Network Connection wizard..../ LAN properties / TCP-IP setting Tab......set each PC different....IP address
say like this.....
192.168.1.3 for 1st PC
192.168.1.5 for 2nd PC
the rest of the settings is based on you internet service provider
this will work....
Jul 15, 2010 | NetGear EN104 Networking Hub
Dear ... I have recently purchased Seagate's Freeagent External Hard Drive (500 GB Capacity). It was working all right for about 10 Days, but now I face a peculiar Problem. This drive does not show in the...
Plug it back in and try this. Right click my computer and click "Manage"
When the window opens select "Disc Management". In the bottom of the screen you will see all the Disk drives installed on you computer. Right click on your drive and select "Properties". When the window open click the "Tools" tab and finally Run the Error Checking Tool. It will scan and fix any issues with the disk. Cheers :)
Jun 27, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
3com 8 port hub not connecting to 2nd pc
Be sure that when you say its a hub that is indeed a layer 1 device which is just passing the signal and data along to all ports. Be sure to check the cable on the second device. At this point it must a straight cable you use to connect the PCs to the Hub. PCs transmit on pins 1 & 2 and Receive on 3 & 6. Hubs are the opposite. So a crossover will not work. You need PC pin 1 & 2 Tx to Hub Pin 1 & 2 Rx and over to PC pin 3 & 6 Rx to Hub pin 3 and 6 Tx. Tx = transmit and Rx = Receive. Also assign an IP address on each machine that is in the same subnet as each other. Such as PC1 192.168.1.100 mask 255.255.255.0 and PC2 IP address as 192.168.1.101 Subnet Mask 255.255.255.0 This way the 192.168.1 is the same for 8 PCs and the only change is the last number (octet). Also keep the speeds at either 10/100/1000 what ever the product is rated for but always keep the duplex half. Half is good because on a layer 1 hub, everyone is broadcasting at the same time. So you have to have half of all the ports listening at all times.
I hope this helps. My advice is to buy a layer 2 switch.
Mar 18, 2009 | 3Com OfficeConnect TP800 8-Port Ethernet...
Unable to access Windows Live OneCare options of actions needed
Right click on the icon at the bottom right, and then click "Get help at help center".
You can look for various solutions and if nothing works,
then at the bottom right of each help topic, there is a "contact support" link which will give you further instructions.
Jan 15, 2009 | Microsoft LIVE ONECARE 2.0 XP/Vista for PC
Only showing as a network device on 2 of the 3 pcs on the network
Did u added the new network devices, or did u wait till thy popped up?
If u didn't added them manually, then go to networklocations, add network location, press next, and again next, then type in \\mybookworld\"here the name of the folder of your mybook, ex. Movies or music,.." (without " ")
Do it for every folder.
Oct 07, 2008 | Western Digital 500GB My Book World...
Manage partitions
go to device manager and uninstall the usb root hub and restart the computer if the usb still does not respond then call hp total care for the replacement of the motherboard as the usb drives has gone bad ..it will be replaced for free if u r in warrenty..or u will have to pay ..
May 05, 2008 | HP Pavillion ZV6000 Notebook
Connecting campus wide networking to hub
Check the following:
Hardware First: Is Vista confirming LAN connection onn that PC, or is it showing disconnected cable?
Is the connection properties showing at least 100Mbps?
Are the RJ45 terminals okay?
Is the driver for the network card recognized by Vista and loaded?
If that is fine, then check the following in the network properties:
1. The IP address you are using
2. The gateway address: it must be the same as the gateway address in the other PCs accessing internet. Run and check
3. The Subnet mask. Use 255.255.255.0
4. HAve you Setup the Nework using the Setup Wizard, including Access INTERNET THROUGH A HUB THROUGH ANOTHER COMPUTER ON MY NETWORK?
Check those things and let us know. Ask for help from your network administrator about correct IP addresses on that LAN
Feb 26, 2008 | Compex MicroHub TP1008C Networking Hub
Microsoft Windows Live OneCare 1.5 for PC Logo
57 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
