Question about ASUS Computers & Internet
Make comp run at 2.6 but need to make 4 fields of jumpers to run
We just moved jumpers around if we were sober would remember sorry dont no how but its boots up to 2.6
Posted on Nov 05, 2008
I have the Sony explode 1200 2/1 channel amp and 2 comp series lighting audio 10s 8ohm 900 watt max best way to hook up for loudest bass
You will have to wire subs together for a 4 ohm load. Then bridge amp (1 channel). Look on amp speaker outs to see what leads to use to bridge. Run positive and negative to one speaker then use a jumper wire from that positive and negative to the next speakers positive and negative
Sep 28, 2016 | Sony Car Audio & Video
My dash reads refrigeration low/ no ac. My mechanic added 2 pounds of freon and installed a new relay switch. The ac still will not come on and the compressor still will not turn. Please help!
the compressor may be locked up, make sure that you are getting power and ground to the plug on the comp. and if you are not then the problem may be in the high or low preassure switch, if ther is + and grount then try running a jumper wirefrom the comp. to a ground and one from the comp to the pos. side of the batt. and see if the clutch kicks in and out if it does then run the engine and run the same test and you will be able to tell very fast if the comp. locked up. more often then not it will be a preassure switch
May 13, 2011 | 1998 Cadillac DeVille
Does this heater need to run on 220
Electrical connections :
The heater is shipped from the factory wired for use with 240VAC, 60 Hz field power supply. To convert the
heater to 120VAC, 60 Hz operation remove the 240VAC voltage selector jumper from the ignition control board
and replace it with the 120VAC jumper. These jumpers are tie-wrapped together and are located on the fuse
board.
Feb 16, 2011 | Hayward 400FDP Universal Series Low Nox...
The motherboard not give any display !
last 2 things to do
1.remove the cmos battery
2.remove the cmos jumper.
remove power cable from power supply.
3.wait for 2 to 3 mins
4.put the jumper back to the correct position usually pin one and pin 2
5.try to start the mb if ok
ok
Nov 13, 2009 | ASUS P5N32-SLI Deluxe Motherboard
DIP SWITCH BIOS RESET POSITIONS SONY VAIO VGN-fs660
There are 2 ways you can reset your bios2_bing.gif.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in2_bing.gif your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and 3. Your reset is now complete
This is a great troubleshooting2_bing.gif step for those of you having POST issues or no POSTing at all. Like other troubleshooting steps, this will not always work but usually will depending on the problem.
Please let me know if you have any further questions or concerns.
Thanks.
Sep 30, 2009 | Sony VAIO VGN-FS660/W Notebook
WHEN COMPUTER COMES ON THE VGA ADAPTER SHOWS BREIFLY AND THE SCREEN IN BLACK AND WHITE SAYS TO ENTER A PASSWORD TO UNLOCK SYSTEM IVE REMOVED THE WATCH LOOKING BATTERY AND REPLACED IT AND IM NOT SURE IF THE...
Sounds like a "Power On Password" and you'll need it to continue. You can try pressing "Enter" with the field bland and if there was no password set, it should continue to load windows.
Please clarify if I misunderstood your issue?
Apr 08, 2009 | eMachines T3604 PC Desktop
Can't get comp to run while trying to charge
Try using a jumper wire between the two wires on the low pressure switch located on the large silver canister on the passenger side near the firewall.This should activate the compressor until the pressure comes up enough for the switch to take over.Good luck,
ChevRev
Mar 18, 2009 | 1999 Chevrolet Monte Carlo
Installation of one touch mini 4
hello, if you are adding an extra hard drive for space make sure to change the teeny jumper to the proper pins next to the connection slots on the hard drive. the jumper makes your hard drive work as a slave (extra drive) or a master (main drive). if you have a main drive allready on your comp and you dont switch the jumper the slave position the computer will not recognize it becuase of the new hard drives jumper being in the master position or pin connector.
if your installing it as a 2nd master drive you need to use your extra hard drive slot on the mother board for this to work as a secound master then you need the jumper in the master pin slot. there is a small diagram on to the hard drive info label it looks like pins and it shows you where to locate or place the jumper for either master or slave.
for a slave drive once you have placed the jumper properly then you can instal it on the same cable with the main. look at the cable it will have a main and a slave small label printon the connector or if you prefer you can use the 2nd hard drive cable on the secound slot on the mother board turn on your comp if you are going for a extra hard drive the comp should recognize it if the jumper is properly placed. when your comp is running you can check by going into (computer) and it should be there as a new drive letter
after this you may need to format the drive for use. you right click on the hard drive letter and choose format drive
hope this helps good luck with your upgrade.
Dec 10, 2008 | Maxtor Hard Drive
Dell Poweredge 1800 server
Hi the Power Supply also needs to be upgraded for the additional RAM and new CPU . Please look into this aspect. My opinion a slightly Overrated PS would be better .
May 07, 2008 | Dell PowerEdge 1800 Server
Audio settings
default values of the secret E370 audio menu by inputing *#8999*8378*
Normal
MIC gain - 0
Tx PGA - 70
Side PGA - 0
Ear gain - 3
HFR gain - 9
Rx PGA - 128
Rx vol - Lv 1 - 10
Rx vol - Lv 2 - 28
Rx vol - Lv 3 - 40
Rx vol - Lv 4 - 50
Rx vol - Lv 5 - 96
Rx comp - Lv 1 - 11
Rx comp - Lv 2 - 11
Rx comp - Lv3 - 11
Rx comp - Lv 4 - 29
Rx comp - Lv 5 - 30
Key vol - Lv1 - 64
Key vol - Lv2 - 64
Key vol - Lv3 - 64
Key vol - Lv4 - 64
Key vol - Lv5 - 64
Headset
MIC gain - 0
Tx PGA - 64
Side PGA - 0
Ear gain - 13
HFR gain - 3
Rx PGA - 128
Rx vol - Lv 1 - 10
Rx vol - Lv 2 - 20
Rx vol - Lv 3 - 42
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 146
Rx comp - Lv 1 - 11
Rx comp - Lv 2 - 11
Rx comp - Lv 3 - 11
Rx comp - Lv 4 - 30
Rx comp - Lv 5 - 28
Key vol - Lv1 - 10
Key vol - Lv2 - 20
Key vol - Lv3 - 42
Key vol - Lv4 - 76
Key vol - Lv5 146
Loud SPK SUP
MIC gain - 0
Tx PGA - 160
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 120
Rx vol - Lv 1 - 16
Rx vol - Lv 2 - 27
Rx vol - Lv 3 - 45
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 128
Key vol - Lv1 - 1
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Loud SPK SDN
MIC gain - 0
Tx PGA - 160
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 120
Rx vol - Lv 1 - 16
Rx vol - Lv 2 - 27
Rx vol - Lv 3 - 45
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 128
Key vol - Lv1 - 1
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Loud SPK EXT
MIC gain - 1
Tx PGA - 226
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 92
Rx vol - Lv 1 - 16
Rx vol - Lv 2 - 27
Rx vol - Lv 3 - 45
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 128
Key vol - Lv1 - 5
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Loud SPK Out Only
Tx PGA - 160
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 120
Rx vol - Lv 1 - 10
Rx vol - Lv 2 - 28
Rx vol - Lv 3 - 40
Rx vol - Lv 4 - 50
Rx vol - Lv 5 - 96
Key vol - Lv1 - 1
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Yamaha AMP vol.
31
Yamaha MEL vol.
Normal
Lv 1 - 6
Lv 2 - 12
Lv 3 - 18
Lv 4 - 24
Lv 5 - 31
Melody key
Lv 1 - 2
Lv 2 - 4
Lv 3 - 11
Lv 4 - 18
Lv 5 - 25
Power on/off
Lv 1 - 1
Lv 2 - 10
Lv 3 - 14
Lv 4 - 18
Lv 5 - 22
ISS Normal
Ear gain - 12
HFR gain - 3
Rx vol - Lv 1 - 121
Rx vol - Lv 2 - 186
Rx vol - Lv 3 - 268
Rx vol - Lv 4 - 376
Rx vol - Lv 5 - 564
Rx vol - Lv 6 - 802
Rx vol - Lv 7 - 980
Rx vol - Lv 8 - 1560
Rx vol - Lv 9 - 2167
Rx vol - Lv 10 - 2863
ISS Headset
Ear gain - 10
HFR gain - 3
Rx vol - Lv 1 - 164
Rx vol - Lv 2 - 328
Rx vol - Lv 3 - 492
Rx vol - Lv 4 - 656
Rx vol - Lv 5 - 820
Rx vol - Lv 6 - 984
Rx vol - Lv 7 - 1148
Rx vol - Lv 8 - 1312
Rx vol - Lv 9 - 1476
Rx vol - Lv 10 - 1640
Bluetooth
Tx PGA - 255
Rx PGA - 12
Side PGA - 0
Oct 04, 2007 | Samsung SGH-E370 Cellular Phone
Computers & Internet Logo
23 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
