Question about Protron PLTV-4250 42 in. LCD Television
This tv work in europe?
I m moving back to turkey we have 220 w
  • 492 Answers
Well I am guessing you live in the us and are moving back to europe. So I will approach it from that end. To answer your question is yes and no. US is on a system called NTSC, europe uses a format called PAL for its signals. This is like the difference between Mac and PC formats. You will need to research first a power adapter for the tv. I would recommend a power conditioner as well. You will also need so check into is a PAL to NTSC converter.
Posted on Nov 05, 2008
Need to find a dealer in Turkey (Brother SC9500)
sorry know of none there .but if you plugged it into 220 you fried it .
Dec 17, 2015 | Brother Sewing Machines
The sound on my Digihome TV keeps going off and only returns by switching the set off then back on again. Any solution ideas please
Digihome is not a brand unto itself. It is manufactured by a Foreign Country (I believe it's in Turkey) by the name of Tesco. Very large territories for sales in Europe of the Digihome label and a half dozen others. You will probably have to find a TV shop that will look at it for you as they have no service nor even their own. website.
Oct 28, 2013 | Digihome LCD TV
Sabre 37in multisystem TV has blinking yellow light and won't turn on. Now in Europe, 220V. Should work fine.
TV's operate on 110 volts, not 220 volts. You need more than just an adaptor to plug in your TV. You need to use a voltage converter to bring the voltage down to 110 volts. But since you already connected your TV up to 220 volts, damage has already occurred to the sensitive electronic components and you need to get it repaired.
Sep 15, 2011 | Sabre LCT371BKA LCD TV
Best way to use US-Bose SA3 amp in Europe ?
Bose say you should pay to get it converted because over time the slightly different power cycles can effect it, however it will still works fine if you change the voltage with an adapter - like I did!!!
Dec 12, 2008 | Bose Lifestyle SA-3 2-Channel Amplifier
Europe-to-usa power supply problem?
Hello Sarah, I brought mine in Europe too and found out that they are rated for 220 VAC while in the US you will need a 110 VAC power adapter so if this is your case you need to buy a replacement.
Jul 30, 2008 | JBL CREATURE II Computer Speakers
Power cable problem for SHARP AQUOS TV 42 inch
The voltage rating of the cable is not a problem. For all home appliances, including TV sets, the voltage rating of the power cable is supposed to be up in the 600 Volt to 1000 Volt range depending on the particular manufacture of the cable. This is not an issue. I have never seen a home appliance that could handle more than 240 VAC.
As for the Amperage rating of cable, it is more than adequate for the appliance that the cable is sold for. The 220 Volt appliances use about 1/2 the amperage that their equivelent 120 Volt appliances use. This is because the wattage for the power consumption is normaly constant.
The power cable is not a factor here. If the power supply in the TV can take the 220 VAC, and the 50 Hz power line frequency then there are no problems from that point.
Jerry G.
May 21, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Need power cable for SHARP LCD TV to use in Turkey
It is not the power cord that makes the rating of the power supply. You can use a transformer, and not a solid state converter to lower the 220 V to 120 V.
What you will find if this is a North American TV set, it may not work in other countries due to the standards for TV broadcast.
If the set is rated for PAL, this will only work with the video inputs, and not the tuner. The tuner frequency allocation and the video and audio carriers are also different between the some of the different countries.
Jerry G.
May 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Converter needed
If your unit is from the USA, 120 volt/ 300 watts.
EU is 220-240V / 300 Watts. Best choice is to go to Bose service center in EU and have your transformer inside your box replaced with 220-240V for EU operation. That way you don't have to worry about a converter. If not, 2nd choice is buy a step-down transformer 220-240V input and 120 Volt output that can handle 300Watts.
Good Luck.
Dec 22, 2007 | Bose 3 2 1 GSX System
Protron PLTV-4250 42 in. LCD Television Logo
52 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
