I think you can found it on amazon, here: Amazon com coleman replacement lamp .I hope this was helpful. cheers
SOURCE: coleman lanterns as collectibles
Coleman Collectors Guide 1903-1954.
Tucker & Ebebdorf
ISBN 0-9651407-0-9
This is an excellent reference with lots of pictures etc., it does not give the prices, however.
You can check Ebay for completed prices if you need an idea of value.
I have not found a book yet with accurate values on Coleman lanterns.
SOURCE: My old Coleman lantern pump failed. How to replace?
Pull the ends of the retainer clip (handle looking thing on the metal pump cover) out of the holes. The pump can be pulled out at that time. I just replaced a pump, and walmart sells replacement pumps. It was very easy.
SOURCE: How do you open the housing to change the lamp on
you need to unscrew the top nut that holds the steel top piece on and then it will all come apart
SOURCE: how to light coleman lantern
Kerosene lanterns require a little more than just lighting the mantles. Go to Coleman's website and find the directions (for free) for KEROSENE lanterns. The generator on the lantern needs to be preheated with alcohol before it will actually light. Make sure lantern is a Kerosene lantern and not a white gas (Coleman fuel) type, there is a difference even though they look similar.
SOURCE: I have a Coleman lantern
It is stuck into the holder with double sided tape on the bottom. Gently and firmly pull it up, applying more pressure on one of the narrow ends verses the other to make the tape let go.
