Question about KitchenAid KSRD25FK Side by Side Refrigerator
Compressor When the compressor is running it appears to be functioning properly. However, when it stops it makes a loud "clunk-a-clunka" sound that makes me think that it's on its last legs or, perhaps, it is loose from its mounting and that the change in torque is causing it to move about. It sounds like it may be trying to self destruct.
  • Steven Valliant Oct 07, 2006
    The actual model number has been checked out to be: KSRS25Q
  • 878 Answers
Steve, there is probably a broken valve spring in the compressor. This is more annoying than anything but it should be covered under the sealed system warranty of 5 years. I would inquire to Whirlpool about having the compressor replaced. You should not have to put up with the back.
Posted on Oct 08, 2006
We have an 11 year old fisher-paykel fridge .For past 6 months several times a day it makes a loud knocking noise
If this noise happens when the compressor turns on and shuts off it is called a compressor knock. All the internal workings of the compressor are supported by springs, over time the springs wear out and become weak. When the compressor stops or starts the tourq causes the internal parts to hit aginst the casing of the compressor. Sounds like a clunk clunk clunk noise. If you can deal with the noise do not go out and replace the compressor cause it will work just fine like that.
Sep 01, 2011 | Refrigerators
There is a loud vibration noise whenever the compressor is running. Everything, including the coils on the back of the box vibrates so loudly that it can be heard in the next room. The compressor appears...
Is the evaporator coils froze up? Sounds like maybe the compressor is getting liquid back to the compressor or the compressor is running real high head pressure. Also check and see if the compressor is mounted on springs or pads.. Make sure all of the refrigeration lines are not bent and causeing vibriation.
Dec 19, 2010 | Kenmore Refrigerators
After the compressor runs it makes a loud clunking sound when it stops running. The sound comes from the compressor.
My guess is that it is running on high head probably caused by a dirty condenser. Try cleaning that. The noise itself is the actual compressor and motor bouncing around inside the hermetic can (what you call the compressor).
Good Luck
Nov 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
My Kenmore refrigerator is making a loud noise when running and when it shuts off it makes a loud clunking noise. Also, it is running about every 10 minutes. The refrigerator is 7 years old.
it sounds like the compressor insides are loose and you will be needing a new compressor, but just check and make sure the rubber mounting feet on the outer compressor base where its mounted to the refrigerator base are all tight and the rubber shocks are all good
Nov 17, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
A matallic "clunk" when compressor stops
Compressor is the sound you hear and it sound as if it is about to bite the big one. The sound is the piston hitting the top of the housing. Hope this helps Good luck on your repairs
Sep 15, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore top freezer, Refrierator shuts off with loud clunk.
It sounds like you may have a compressor that is working hard against high pressure due to a dirty condenser or a condenser fan not running or blocked. If all is well otherwise, the mounting springs inside the compressor may have broken or are weak. The only fix then is a new compressor.
Jun 22, 2009 | Kenmore 64802 Top Freezer Refrigerator
Refrigerator makes fairly loud noises of a clunking kind but runs and stays cold.
Clunking noises usually comes from the rapid stop of the compressor. It will not hurt a thing. The rubber grommets which the compressor sit on for cushioning, have most likely hardened and are transferring the noise to the frame or casing. The compressor runs at 3600 rpm's and when you tell it to stop on a dime, it can't. The result is a couple of clunks or so. Also check the drip pan for improper positioning. I have seen them make noise also.
May 04, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Freezer noise
clunk comes from the compressor - possibly dismounted or sometimes assembly inside hits casing on switch off or switch on. no cure except replace compressor
Jun 19, 2008 | Kenmore Freezers
Crash and noise
if it sounds kinda like "clunk...whir, clunk whir" or maybe "clunka clunka clunka" your hard drive is toast. There are some utilities that say they can realign the platen and heads but my experience is that if they do fix it...its just long enough for you to lose more data in two weeks. usually your data is lost...there are clean rooms like Cherry Systems that can clean room recover your data...but get your checkbook out.. Good luck
Aug 22, 2007 | Apple LaCie d2 AIT U&I (T5526LL/A) AIT...
Motor noise
You can remove the lower back cover panel and visually see the compressor and fan. Check the mounting bolts on the compressor to see if they are loose allowing the compressor to bounce around in there. You can also "stall" the fan with a wash cloth to stop the blade from turning (it's OK just try not to bend the blades). That will eliminate the fan squeaking as it coasts down to a stop. Better to stuff a wash cloth in while the fan isn't running. Turn the t-stat up to colder to force a run condition for a minute or two then turn the t-stat down and watch the compressor and listen for those sounds again.
Nov 11, 2006 | Whirlpool ET9FHTXMQ Top Freezer...
KitchenAid KSRD25FK Side by Side Refrigerator Logo
174 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
