Hummingbird wide one hundred, fish finder I turn the main power on, and press the power button on the unit, the unit will only go on to demo mode, none of the other buttons are working. I have to turn it off by the main power. Does any one have a solution?
  • 55 Answers
SOURCE: Non-Responsive PDA
You may have to do a hard reset. You hold one finger at the power and the other hand hold your stylus and his reset. This technique is applied to most PDA.
Posted on Aug 25, 2007
  • 101 Answers
SOURCE: Aiwa CDC-X504Mp stuck in demo mode
This recently happened to my Sony, maybe it will help u
If this cd player has a removal fascia then try..
Carefully inspect the the electrical contacts on the fasica and the cd player. If it has got dirt on them then CAREFULLY CAREFULLY clean with cotton swab dabbed in cleaning Alcohol.
Posted on Jan 09, 2009
  • 4 Answers
SOURCE: Philips HDRW 720/17 stuck in '':demo'' mode???
Okay. I found that there IS a manual release for the disc tray UNDERNEATH the unit. It is a sort of toggle lever that you have to slide to the other side and that releases the disc. The Manual does not even mention this manual release lever!
Also, it may be hidden or covered by a paper like cover.
GL
Posted on May 14, 2009
Editor925
  • 285 Answers
SOURCE: CAN I POWER MY FISH FINDER GOING DIRECTLY TO THE
Yes you can. Basically the red wire goes to the fuse box connection. The fuse box should then be wired into the positive battery terminal. The black wire is the negative ground wire and needs to go directly back to your negative battery terminal or to a common negative buss bar.
Posted on Jun 15, 2009
  • 74 Answers
SOURCE: I need a instruction manaul for a Hummingbird LCR
All Humminbird manuals can be found here.
Posted on Jul 08, 2009
Our 797 Hummingbird fish finder will not turn on any ideas why
Battery too low
Fuse blown
Corroded connections at battery, fuse, connector
Dead fish finder
Jul 09, 2017 | Hummingbird Boating
Tip
How to Turn Off Demo Mode
<span style="font-weight: bold;">Blaupunkt:</span><br /><br /> <ol> <li>Press the (PWR) to turn the unit off.</li> <li>Press the (DIS) and (1) simultaneously for more than 3 seconds to activate the demonstration mode.</li> <li>Press both buttons again from more than 2 seconds to cancel this mode.</li></ol>or<br /> <ol> <li>Try pressing and holding menu for 10 seconds to turn it off.</li></ol><span style="font-weight: bold;">Bose:</span><br /> <ol> <li>Unplug the unit and wait ten seconds.</li> <li>Plug it back it and press repeatedly on the eject button.</li> <li>The demo disc will eject.</li></ol><span style="font-weight: bold;">Clarion:</span><br /> <ol> <li>Press and hold the "D" button to enter the settings menu.</li> <li>Use the next track button until SCRN SVR is displayed, use the rotary knob to select "OFF".</li> <li>Press the "D" button to exit the settings menu. </li></ol><span style="font-weight: bold;">Garmin:</span><br /> <ol> <li>DO NOT DO THIS TO A FUNCTIONING UNIT. Hold down your MENU key, Go to your SYSTEM tab, SYSTEM INFORMATION.</li> <li>When the software version window come up, hit ENTER.</li> <li>Press RANGE UP 3 time, Range DOWN 3 times, RANGE up 1 time, RANGE down 1 time.</li> <li>The system should reset, when asked to use RETAIL mode say NO.</li></ol><span style="font-weight: bold;">JVC:</span><br /> <ol> <li>Hold down the SEL button for 2-3 seconds.</li> <li>Use the &lt;&lt; or &gt;&gt; buttons to find DEMO.</li> <li>Turn the VOLUME knob until it says OFF or DEMO OFF.</li> <li>Press SEL again.</li></ol><span style="font-weight: bold;">Kenwood:</span><br /> <ol> <li>Go into standby mode, hit menu and then press "hold". A menu should pop up.</li> <li>Use knob to select demo.</li> <li>Press in on the knob and hold until it says "demo OFF".</li></ol>or<br /> <ol> <li>Switch to Standby.</li> <li>While holding down 5, press Reset with a paperclip or similar and continue to hold down 5.</li> <li>Demo mode should now be off.</li></ol><span style="font-weight: bold;">Magnavox:</span><br /> <ol> <li>Press and hold the menu button for 5-10 seconds until the normal menu pops up and then go to the section that says demo and turn the demo mode off.<span style="font-weight: bold;"></span></li></ol><span style="font-weight: bold;">Pioneer:</span> <ol> <li>Turn the vehicle's key to the Accessory or ACC position.</li> <li>Press the "Source" button, located on the left-side of the radio, and press the "Off" button that appears on the screen to turn off the unit.</li> <li>Locate the "Volume/Mute" button, located on the left-side of the unit.</li> <li>Press and hold the "Volume/Mute" button until the demo mode turns off.</li></ol>or<br /> <ol> <li>Turn the radio off.</li> <li>Push "Memory 5" or "Memory 6" (depending on your model) for just a second.</li> <li>When you hear a beep, demo mode is off.</li></ol><span style="font-weight: bold;">Pioneer Premier:</span><br /> <ol> <li>With the unit Off and the car ignition On and Running, press button number 5 and release that button to turn off Demo mode.</li></ol><span style="font-weight: bold;">Sharp:</span><br /> <ol> <li>When the unit is in the power stand-by mode (demonstration mode), press the X-BASS/DEMO button.</li> <li>The demonstration mode will be cancelled and the display will disappear.</li></ol><span style="font-weight: bold;">Sony:</span><br /> <ol> <li>Press display twice to turn off Demo mode.</li></ol>or<br /> <ol> <li>Press and hold the select button.</li> <li>Press the select button repeatedly until the desired item appears.</li> <li>Rotate the control dial to select the setting DEMO.</li> <li>Rotate the control dial to select the setting DEMO-OFF.</li> <li>Press and hold the select button.</li></ol><br />or<br /> <ol> <li>Press the STOP and the EJECT buttons simultaneously for 5 seconds.</li> <li>UNLOCKED should now appear in the display and you should be able to eject the disc.</li></ol>If Demo mode comes back on every time you turn off the ignition and back on, you have a wiring problem with your Constant +12 Volt Memory wire.
on Jun 22, 2011 | Audio Players & Recorders
It is stuck in demo mode how do I fix the problem
SELECTED PRODUCT: (change your search)
How to disable the demonstration (DEMO) mode.
Article ID: 42707 ' Last Updated: 03/11/2014
Sony® stereo systems will enter the DEMO mode the first time you power on the system or if you do not operate the unit shortly after turning on the power to the system.
To disable the DEMO mode, while the stereo system is powered off, press the DISPLAY button repeatedly until the demonstration display disappears.
NOTES:
  • Depending on your model, some units have a DEMO button that is used to disable the demonstration mode. If your unit has this button, with the power to the system off, press the DEMO button until the display disappears.
  • If applicable to your unit, setting the clock on your stereo system will also disable the DEMO mode.
  • Using the buttons on a supplied remote control will not disable the demonstration mode.
If model-specific information is needed to complete any of these steps, refer to the operating instructions supplied with the product. Manuals, Specifications and Warranty information for your Sony product is available online.
May 27, 2015 | Sony Audio Players & Recorders
Hummingbird matrix 12 not powering on
The Power Supply just crapped out, Sorry.....
Apr 12, 2013 | Humminbird Matrix 12 Fishing System
How do you get the Furuno FCV 295 out of demo mode?
go to the ' menu ' page -- scroll down to ' simulator ' -- and choose simulator OFF.
the unit should work fine after that.
fish on (!!!)
c...
Feb 02, 2011 | Furuno FCV 295 104" Fish Finder
STR-DE845 Stuck in Demo mode, tried the power and ...
To get the STR-DE845 ( or STR-DE945 ) out of DEMO MODE - Turn unit on and HOLD POWER BUTTON FOR A FEW SECONDS ...Turn unit off and when you turn it on again it should be reset ...It worked for me.
( Note : You may need to do this procedure before it goes into its actual demonstration of features ... Press and hold the power button immediately when it initially starts scrolling it's DEMONSTRATION MODE message . )
May 12, 2010 | Audio Players & Recorders
I need a manual for a 1997 wide 100 hummingbird fish finder
This manual is not listed so you will have to contact customer support by clicking here and filling out the form.
May 15, 2009 | Humminbird Smartcast Rf 35 Dual Display...
Depth finder comes on then goes off
It sounds like some power saver feature on the battery or in the unit. Check with hummingbird, they should have an 800#.
May 12, 2009 | Boating
How to diable demo mode on mx-kb30
Turn the stereo on, wait two minutes for the demo to start running then press the "demo/cancel" button located under the "sound mode" selector.
Mar 10, 2009 | JVC MX-KB30 CD Shelf System
Older HUMMINGBIRD DEPTH SOUNDER LCR-3D . WAS WORKING FINE WHEN I PUT IT AWAY, NOW WONT POWER UP. HAVE CHECKED THE INPUT POWER AND IT IS OKAY. I DO NOT SEE A FUSE IN THE UNIT. ITEM IS OLDER UNIT BUT IS...
We have an old Hummingbird Depth Sounder (Wide 100, 94 model) and it turns on but must be on test mode or smething cause we can not get it off. Does anyone know or have a manual to solve this problem. Please help.
Aug 07, 2008 | Hummingbird GPS
Computers & Internet Logo
484 people viewed this question
David Payne
David Payne
