Question about Hotpoint FFA60 Bottom Freezer Refrigerator
Ice build up in bottom freezer and whant looks like an oil leak on the floor
Hi, I woke this morning to find a dark black oil like fluid under my fridge, looks like it ran down the inside of the freezer door and pooled on the ground. Everthing seems cold enough, but there is quite a lot of ice building up in the freezer. Any idea what this could be from and if I should have someone look tat it? Thanks, Mark.
  • 175 Answers
You freezer sounds like the self defrosting function has failed. If the evaporater coil freezes up, it gets really cold, but the air in the top of the freezer gets warm, so you could have stuff towards the top of the compartment melting, while the bottom is super cold. The heating element, thermal limit switch, or the timer could be bad. I am not particularly familiar with this model, but most have a little timer motor mounted behind the toe kick somewhere that contrlos the defrost intervals. The timer sends power through the thermal limit switch, located on the inlet tube of the evaporater (coils that get cold in the freezer) and keeps the heater from over heating. This part is probably the most common failure. From the switch, power goes to the heater element, which is mounted directly to the evaporater. If the heater looks kind of like a bake element style (similar to what you'd find in the bottom of your oven) then its probably not bad. If its a glass tube style, then they fail more commonly. Hope this helps, good luck! P.S. this could all have been caused by a door left slightly ajar overnight too...if you think that may have happened, then just turn it off and leave the door open for a day or 2...it'll defrost and be fine!
Posted on Oct 08, 2006
I just fixed this problem on my refrigerator 5 minutes ago. I took the panel off the back wall of the upright freezer and poured hot water down the drain (small hole made of black rubber). That melted the built up ice. Then I had to stick a flexible piece of plastic down the drain plug and all of the sudden all the water rushed down the drain. The plastic item I used was one of those glow in the dark bracelets kids wear. My daughter heard that it will last longer if you put in the freezer. After poking fun at her for having it in the freezer I told her she is the hero because it worked perfectly to unclog the drain. I then went into the back to siphon out the water from the drain pan. It was easy to remove the cardboard covering off the bottom of the back side of the refrigerator. The drain pan is below the fan as it's secondary purpose is to evaporate the water from the drain pan. Piece of cake and save you a lot of money!
Posted on Dec 23, 2009
I fixed my problem myself on my VCBB363R.After Viking told me they were gonna charge mee 100.00 just to come to my house, I said forget it I'll figure it out myself. After speaking with Viking on the phone and told them what I did, they offered me a job. No thanks.
Anyway, You'll have to remove the back wall of the freezer to do this. Belive me it's not that difficult. Just turn down the freezer temp when doing this.
1/4" nut driver, phillips head screw driver, and some time. In addition the icemaker will have to come off. Just a plug and lift it up off 2 screws. remember to shut the the water valve off.
Once the wall is removed look down on the bottom there is a hole... That hole transfers condensation water to the drain pan below where it is disapated by the heat of the coils.
Your problem is something (usually food particals are caught and the water eventually slows the and draining and freezes.
this causes backup and forms ice on the bottom of the freezer to the point where it will oooz out of the sides and distroy your floor. Solution to remove the ice dam. get a hair dryer and remove the bottom plate of the fridge. with a flashlight watch the pan while placing heat over the hole. eventually what is caught will fall out and the water will follow. Make sure you clean all the ice out of the freezer by placing a dish towelover it and slightly tapping with a heavy objet to crack the ice. clean reall good and replace the parts. THIS REALLY works. I've done it. Just keep your frezer clean and this won't happen again.
Posted on Jun 03, 2008
4 Suggested Answers
philiptory
SOURCE: FFA 90 ICE BUILD UNDERNEATH THE BOTTOM TRAY
Symptoms:
Ice forms at the bottom of the Hotpoint FFA90 Freezer compartment, below the bottom drawer.
Cause:
The drain hole at the back of the freezer compartment is blocked with ice and sludge.
Solution:
This take about 20 minutes to complete.
1. Tools required:
- 7mm socket spinner.
- Phillips screwdriver.
- Clean damp cloth.
- Electric fan heater (optional, but it makes the job much quicker).
- A length of plastic tubing approx 3 ft (1 metre) long with 5mm bore (optional).
- A few inches of fairly stiff but flexible, insulated wire. I used a piece of yellow/green earth wire.
- A torch or inspection lamp.
2. Switch off the fridge and pull out the mains plug.
3. Remove all the freezer drawers. If there is food in them, wrap them in a duvet or something cosy to reduce thawing.
4. Place a shallow tray under the front of the freezer compartment to catch dripping water.
5. Switch the fan heater on to low heat, and let it blow into the freezer compartment from a distance. DO NOT get it too close - a gentle heat is all you need.
6. After a few minutes, use a blunt knife to prise the sheet of ice away from the bottom of the freezer compartment. I managed to lift mine out in one piece! - but it will probably crack into smaller pieces. Mop up as you go.
7. Using the 7mm spinner, remove the 8 self-tapping, hexagonal head screws that fix the back panel inside the freezer compartment. With all the screws removed, ease the panel out gently, pulling from the bottom first. It may stick a bit where ice has stuck to foam rubber inside, so don't pull to fast.
8. Put the panel on your draining board and allow it to thaw out. There will probably be lots of ice stuck to the foam rubber backing. Don't pull the ice off by hand - you may damage the foam.
9. At the back of the freezer compartment, below the chiller tubes, there is a drain hole about 15mm diameter, and this will probably be blocked with ice. Allow the fan heater to continue to thaw the ice in here, mopping up from time to time. Gently ease off any bits of ice with the blunt knife. As the ice thaws, the drain hole will gradually clear.
10. Insert one end of the plastic tube into the drain hole, and blow long and steady through the other. The warmth of your breath will help to thaw the ice in the drainage tube. Keep going until you have cleared about 5cm down.
11. Now use the piece of wire to poke down the hole and clear any further blockage. This should go down about 8-10 cm or so.
OK, that's cleared the drain hole and the drain pipe. Now you have to clear a messy brown sludge from the evaporation tray underneath, at the back.
12. Switch off the fan heater, and pull the fridge freezer away from the wall, so that you have clear access to the back.
13. Vacuum the dust and cobwebs out of the way - you need to see what you're doing!
14. Above the motor is the evaporation tray. Remove the two Phillips screws that fix it to the back of the fridge.
15. You'll need the torch for the next bit. Look between the top of the evaporation tray and the underneath of the freezer compartment. You will see a black, soft plastic tube about 18mm diameter that links the drainage hole with the tray. Use the screwdriver to prise the tube gently upwards and out of the tray. This could be messy with brown sludge.
16. Taking care not to damage or bend the metal pipes, gently remove the evaporation tray. This will probably have a messy brown sludge in parts.
17. Wash the tray clean; it will need a jet of water and a small washing up brush to get this clean.
18. Wipe the black plastic tube clean.
19. Replace the tray. The fiddly bit is getting the black tube back into the corresponding tubular hole in the tray. I had to remove the screw from the bottom left corner of the coolant pipework in order to get my hand in. Bend the black tube double so that the fold is towards you, and ease the end into the tubular hole in the tray; then push the tube down into place.
20. Re-fix the tray and fixing screw for the coolant pipes; then move the fridge freezer back into place.
21. The inner panel should have thawed somewhat. Gently remove any remaining ice and mop it dry. Press the aluminium foil and foam back into place. Wipe both sides clean.
22. Inside the freezer compartment, mop the coolant tubing gently. Mop the circular foam seal around the fan, and press it back into place.
23. Replace the inner panel. DO NOT over tighten the screws, as they are self-tapping into the plastic walls of the freezer compartment, and you might strip the thread.
24. Replace the freezer drawers, and switch on.
You should now be up and running.
I hope this is easy to understand! Good luck.
www.authorgraphic.co.uk
Posted on Nov 12, 2008
stephanos18
  • 144 Answers
SOURCE: Ice in my fridge
Without seeing this I can't tell you a price or exact fault but the first free thing to try that could likely fix it. unplug the unit from the power and leave both the doors open for 48hrs so the unit is 100% defrosted then try again. cheers.
Posted on May 31, 2009
SOURCE: got water leaking from bottom of fridge/freezer on
If you take all the drawers out of the freezer - you will find 8 screws with 'bolt type' heads - 2 top, 4 at sides and 2 to the bottom.
Turn the power off. Undo all these screws and remove the rear panel. You will notice the 'gubbins' of the freezer. At the bottom you should notice there is a shaped plate with some piping running around and then up into the cooling 'radiator'. Towards the middle left of the plate there should be a hole - this is the drain hole. Is it blocked with a 'slug' of ice! Yes is my guess. This needs defrosting as will the rear panel you took out by any guess.
I did ours this morning as the fridge freezer was making a heck of a racket. Took about 30 minutes with the wife's hairdryer - and I'm no expert.
I just enjoy the fact I'd probably saved £50 plus on a callout.
Posted on Jan 02, 2010
Have a second hand Homemaker chest freezer model hmbd155....recently noticed fluid around the floor....? Leaking..don't have a manual and noticed a dial on the bottom left hand corner .What this do..?
The dial Adjusts the temperature. If it is adjusted too cold you might have ice build up underneath the freezer thus causing the fluid that you see. As the freezer is old it can also be that the insulation underneath is a bit old causing the ice build up and fluid leakage. A broken thermostat (dial) will also cause too low temperature inside and possible ice build/fluid leakage.
Oct 04, 2017 | Refrigerators
My Lg bottom freezer refrigerator, model # LFC21770ST leaks constantly down in the bottom of the freezer and comes out onto the floor. Ice dams build up under the freezer drawer. I take out the ice, but it...
The drain for the auto defrost water is plugged up somewhere.You will need to look at the very back and bottom inside the freezer to see if you can locate it and clean it out.Also you may have to pull the refrig out from the wall and try to get to it from the back.Hope this aleast gets you looking in the right direction.
Jun 29, 2011 | LG Bottom Freezer Refrigerator w/...
Whirlpool refrigerator (top freezer) is leaking into bottom of fridge. What can it be?
Hi, read about your problem. What's happening is your drain in the freezer compartment in the back behind wall is plugged. Defrost water then builds up under freezer floor and freezes. To fix, remove back wall. Also the floor needs to be opened up. Use a blow dryer to clear ice out of drain, in the trough, and under the floor. Hope this helps
Jan 18, 2011 | Whirlpool Refrigerators
My refrigerator expelled water tonight. Whe I woke, this morning, I found the floor with water. Can you tell me what could be happening?
if the drain is blocked in the freezer water can leak out onto the floor if it's leaking out of the frezer door.open the door and check the bottom rack,if it's frozen in or ice is on the floor of the freezer then it's the drain.also if you have a water line going to the machine one of the water lines could have cracked.let me know what you find and we can go from there
Jan 08, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
Leaking water on floor.
This is typically caused by the defrost drain. I have put together some instructions on how to resolve this, follow the link below and let me know if it helps.
http://www.fixya.com/support/r4686046-water_leak_from_freezer_ice_freezer
May 10, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Ice building up in the bottom of the freezer
The water supply line is leaking.Put some paper towels down after you clean up and check real often to back track where leak is coming from,maybe your ice maker is over flowing with water.When was the last time you replaced your water filter?Could be backing up,just replaced mine,it was leaking under the fridge,mine is a Sear's Kenmore,ordered a filter from Sear's,Cost me 50 buck's,My filter is at the bottom front,your's may be inside the freezer.
Apr 13, 2017 | KitchenAid KBLC36FKS Bottom Freezer...
Freezer icing over at bottom and leaking onto floor
Hi, You will need to remove the rear panel in the freezer and then remove the ice build up in the drain pan. The drain hole will have ice down in it.Make sure all the ice is gone and then flush the drain hole out with hot water (a basting serenge works great)
This should take care of your water problem.
If I can assist you further, please let me know and please rate me response so that other as well as my self will know how I am doing.
Thanks
Vic
May 22, 2009 | Refrigerators
Ice build up on floor of freezer drawer
Check the drain tray under the evaporator its probably froze over causing water to overflow in the freezer
Mar 02, 2018 | LG LRFC25750 Refrigerator French Door
Water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Feb 23, 2008 | Kenmore 71279 Bottom Freezer Refrigerator
Hotpoint FFA60 Bottom Freezer Refrigerator Logo
1,552 people viewed this question
Top Hotpoint Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
