Question about Lexmark Office Equipment & Supplies
Print cartridge error - Lexmark Office Equipment & Supplies
    Master:
    Sergeant:
  • 449 Answers
Hi!!
try to removed
and then placed it back properly
Posted on Nov 05, 2008
INkCartrige error 50c. Will not print. Display this note each time I try to make copy or print from computer.
Hi there
You should always mention the printer model as well as what operating system you use.
This is what i found on LEXMARK's website about your error, and it seems you have one or 2 faulty cartridges, or you are using compatible cartridges instead of Lexmark Originals:
Problem Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Hope it helps
Andre
Sep 08, 2011 | Lexmark Office Equipment & Supplies
Cartridge error 1102
Cartridge Error (1102, 1203, 1204, or 120F)
  1. Remove the print cartridges, and close the cartridge carrier lids.
  2. Disconnect the power cord from the electrical outlet.
  3. Reconnect the power cord to the electrical outlet.
  4. If the button_power_0.jpg button is not lit, press button_power_0.jpg.
  5. Reinsert the print cartridges.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to determine which cartridge is not working properly.
  5. Reinsert the black (or photo) print cartridge.
  6. If the error:
    • Reappears, replace the black (or photo) print cartridge with a new one.
    • Does not reappear, reinsert the color print cartridge.
  7. If the error reappears, replace the color print cartridge with a new one.
Jun 16, 2011 | Office Equipment & Supplies
10.1000 supply memory error
hi,
10.00X is the error code displayed when
  • Cartridge is not installed correctly
  • Use of refilled cartridges
in your case x is 0 which means that black color cartridge had a problem
problem may persist in slot holding black cartridge and /or in the cartridge
just do steps below
solution 1: check all cartridges are in right slot it is better to remove and fix it again
solution 2:
clean the surface of metal contacts with lint-free cloth
the image below will show metal contacts
solution 3: Insert the problem print cartridge into a different slot
Follow these steps to determine if the print cartridge or the slot it sits in is causing the error.
  1. Open the print cartridge door completely.
  2. Press the blue handle on the print cartridge drawer to release it, and then pull the drawer out completely.
  3. Remove one of the non problem print cartridges from its slot.
  4. Install the problem print cartridge into the empty slot.
  5. Install the other print cartridge into the slot of the problem print cartridge.
  6. Close the print cartridge drawer completely.
  7. Close the front access door completely.
  • If the error message persists , replace the problem cartridge with new one(problem is in cartridge)
  • If the error message is gone , contact HP to troubleshoot a faulty slot.
regards,
cseian
Dec 16, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
Error1102
  6. If the error:
Dec 18, 2009 | Lexmark C533DN InkJet Printer
Cartridge Error 50C consult user guide. I
Cartridge Error
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Can't find "cartridge error 50C" in my Dell owner's manual
Cartridge Error 50C
Cartridge Error
Aug 13, 2009 | Dell A940 All-In-One InkJet Printer
Error 50 c
  1. Power off your printer.
  3. Turn the printer on. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Hope this helps.
Jul 29, 2009 | Lexmark X6170 All-In-One InkJet Printer
Have put in a new colour cartridge but the note on the printer comes up error 50C
Cartridge Error 50C
Cartridge Error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
Error 50
Is that an error code "Cartridge Error 50C" ? If so, see below....
Cartridge Error 50C: Your print cartridge has shorted.
Error: Black Cartridge Missing - The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing - The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error: Complete the following instructions:
Nov 22, 2008 | Lexmark X5150 All-In-One InkJet Printer
My Lexmark is X6100 Series - Cartridge Error 50C consult user guide
Cartridge Error 50C
Cartridge Error
Jan 14, 2008 | Lexmark X6170 All-In-One InkJet Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
