Question about E-Machines 19" Widescreen Flat Panel TFT LCD HD Monitor
Emachine 19" Widescreen Flat-Panel TFT-LCD Monitor
When you turn on computer monitor comes on stays on for about a min,Then screen goes off but power still on.Cut monitor power off and then back onit comes on again for about a min. goes off everytime like that!
  • gbelyea Dec 03, 2008
    I just bought an emachines E19T6W and it does the same thing. I have connected it to my desktop as well as my laptop. Is this a monitor defect?
  • Anonymous Dec 16, 2008
    Same issue with E19T6W monitor; recently purchased as "refurbished." My guess this is why the particular monitor (manufactured May 2008) was sent back to be "refurbished."
    Contacted EMACHINES, they had no knowledge of this issue. Sent them this site's (FIXYA) link regarding this issue.
    Novelist:
  • 159 Answers
Your power/inverter board is in need of an overhaul.
The capacitors are failing and possibly a transistor.
If the screen showed any redness or pink whebn it was working, Then there is a slight chance that one or more of the 4 lightbulbs in the screen was going bad and finally went.
If you take it apart and send me a picture, I may be able to tell by looking at it.
I repair these boards on ebay
bammbammfran
Posted on Nov 06, 2008
Theft dasable menu stays on screen--do not know how toremove
If you have never installed the EZTune software then try this:
unplug the monitor power at the back.
Wait 1 minute.
Hold down the power button and plug back in the power at the back.
Keep the power button pressed for 15 seconds.
Feb 07, 2010 | Gateway 19" Widescreen Flat Panel TFT LCD...
I have a E machines 19" widescreen flat panel computer monitor that is only 6 months old. For the last few days when I power up my computer, the monitor comes on for 1 or 2 seconds then flickers and goes...
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
Jan 04, 2010 | E-Machines 19" Widescreen Flat Panel TFT...
Need to hook my emachine monitor to my hp computer what do i need?
you need a cable that matches your video card. standard is svga cable. newer or better is dvi. any computer store will have these in stock.
Dec 26, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
Monitor boots ok, then "Analog" appears/monitor shuts off
Does it have a digital port being used? If you are using the DVI port, it is probably digital. Try using the menu to selct the port. If it doesn't work, not sure from here. What is the model number?
Aug 01, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
White horizontal stripe on top of screen
it is a repairable fault, you need to consult a technician for repair.
Dec 02, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
Emachine E19T5W Monitor
I have more or less the same problem. Mine only stays on for a second though, but it started out like yours. I took it apart and found that the CCFL bulbs at the top of the screen were so poorly put together that they arced out and in the end melted the end of the back panel bulbs off. The monitor only lasted a year and a half and now it's toast unless I can find new back panal bulbs.
If the screen feels excessivly hot around the corners or if you here a snapping noises (arcing) yours is going the same route as mine. If you want to get rid of yours I'll take it.
Oct 29, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
Emachine monitor with a HP computer
i am trying to hook up a emachine monitor to my compac computer but the monitor will not come on there is another wire coming off the part that hooks in the compac but there is nowhere to hook it can you help me?
Oct 12, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
E-Machines 19" Widescreen Flat Panel TFT LCD HD Monitor Logo
986 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
