Question about Whirlpool Refrigerators
Whirlpool side x side fridge will not cool. All fans working and compresser is working. No frost.
  • 958 Answers
Is the fan at the condenser side is included in the fans that you checked?.
if it is running and compressor is running, no frost at the evaporator, i believe you either had a leak ( no refrigerant) or the capillary tube clogged ( this second option is least likely to happen but it could happen.
both solution would require qualified tech to service the refrigerator.
tnx 4 using fixya,
drcool
Posted on Nov 05, 2008
I have Whirlpool fridge FF450 Elite. Though the fridge cooling is normal, after the night working find in the early morning all magic light flickering though the fridge compressor is working. The freezing...
seems to me by the frost that the inside fan is not blowing air across the cooling radiator (evaporator), due to ice build up impeding air flow or the fan motor stalls or not working a t all. Defrost timer should also be checked if the air flows thru inside the fridge.
Jan 06, 2015 | Whirlpool Refrigerators
Whirlpool side by side not cooling
The round object is the compressor. Is it running continuously, or is it clicking on and off every 2 or 3 minutes? There also should be a fan beside compressor. Is it running? Also check Fan in freezer to see if it is running. Is there any frost build up on inside back freezer wall? If fans are working and compressor is running continuously and there is no frost buildup in freezer, then you most likely have a sealed system problem meaning its low on freon or there is a blockage in system.
Oct 31, 2017 | Whirlpool Refrigerators
I have a Whirlpool Refrig. model GX5FHDXVY04. The freezer is working properly but the refrigerator is not cooling. I noticed frost on the inside back panel of the freezer. I turned the temp down in the...
Many of frost-free fridges use fans to move a controlled amount of air into the upper or side cooling chamber, check for non-working fan or a stuck or malfunctioning damper control. Keith L.
Mar 02, 2012 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
MY WHIRLPOOL ED5VHGXMB11 DOES NOT DEFROST.
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Sep 26, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
FREEZER HAS TOO MUCH FROST AND COOLING, MIDDLE AND LOWER SIDE HAS LESS COOLING WHIRLPOOL 175 MODEL
More freezing on the freezer means there is frosting Now you have observed that the fridge after working for about 24 hours does not cool , check if the fridge cuts off. If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
Aug 24, 2011 | Refrigerators
The fridge side is not cooling,in the top left side there is a vent no air is coming thru,until freezer door is opened.fan is working acts like it is starving for air but i dont where it gets its air from...
can be that the frost has blocked the intake and choking the fan from blowing to the vent.
You must look into the fan vent section and see if the assembly can be taken out to probe into . Usually this is a latch on that can come but may be tight due to frost. So switch off the fridge and allow it to cool off maybe 8 hours so that all frost comes off.Now restart and check if the cooling returns to the fridge. If so open and check or look below the fridge at the bottom for the auto defrost timer to be a suspect.
Sep 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer not cooling, fan blowing, fridge also not
If there is no frost , on the inside rear freezer wall ,
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
If there is frost , reply back with complete model number .
Nov 08, 2009 | GE PSS25MGN Side by Side Refrigerator
Fridge doesnt work but the freezer working as last week i switched of & its working good after but again the same problem fridge cool & temp 5
1. make sure frzr fan motor is running.
2.if so, the check air flow coming out of vent in freshfood side.
3.check for heavy frost built up on frzr rear wall panel.
4.make sure compressor and fan motor are both running.
also remove toe grill and clean condenser coil under refrig.
Jul 14, 2009 | Whirlpool ED2FHSS Side by Side...
MY FREEZER FREEZING AND FRIDGE IS NOT COLD ON MY BLACK SIDE BY SIDE WHIRLPOOL
hi thanks for the question i would check to see if the fan in your freezer is working that could be the problem make sure the back of the fridge is clean where the compressor is located also make sure no frost has built up in freezer thanks the appliance doc
Sep 22, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge and freezer not cold enough since we moved
remove the panel at the reaar of the freezer. you should have a full frost pattern on your evaporator (frosted not snow packed) and the fan should be running. if you do not have a full frost pattern then you have a sealed system leak. covered under the first five years of your warranty
Feb 17, 2008 | Whirlpool ED5SHAXM Side by Side...
Refrigerators Logo
52 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
