Question about Bush DVD142RC 14 in. TV/DVD Combo
BUSH TV/DVD combi
After a few years of great service my tv/dvd combi is playing up. We can watch tv fine but can not change to dvd or av either by using the remote or on the front of the unit. It just wont do it. Please help!
Connection between tv and dvd might be wrong or need to be checked
Posted on Dec 03, 2007
Bush tv combi led24265dvdcntdfvpxy dvd will not play.
Have you tried DVD lens cleaner, More than one shop bought DVD disc and 1. Menu 2. Scroll down to installation press ok 3. Scroll down to first time installation 4. Scroll left for yes press ok then once reset follow on screen instructions to set this back up.
If this failed follow link below:
https://www.argos-support.co.uk/6693954-bush-24-inch-hd-ready-smart-tv-with-dvd-player-black
Jul 14, 2018 | Bush Televison & Video
Bush tv / dvd combi modle .. led24127fhddvdp as started to play in black and white how cam I change it back
Make sure you have the correct country chosen in the initial setup. If the TV is setup for an NTSC country and you're in a PAL country or vice versa, the picture will be in Black and white.
Feb 08, 2017 | Bush Televison & Video
My daughters 24 inch bush led/ dvd combi has started to play dvds in black and white. the normal tv picture is fine
Most Big box stores have a DVD cleaner disk, located in the electronics section, which is fairly inexpensive. I would try that first.
May 20, 2014 | Bush DVD142RC 14 in. TV/DVD Combo
Blaupunkt tv dvd combi saying wrong region
NTSC/PAL/SECAM Color System
Europe used PAL/SECAM format, check settings on tv
Dec 06, 2013 | Bush Televison & Video
My daughters 24 inch bush led/ dvd combi has started to play dvds in black and white. the normal tv picture is fine. does any clever person out there know how to fix this problem? would be very grateful
Laser pickup unit fault. It should be replaced. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 14, 2012 | Bush DVD142RC 14 in. TV/DVD Combo
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
Recording problem between dvd vcr recorder combi and hd lcd tv
Aparently its the wire!!! as your sawpping the scart so yeah change the wire and you be a happy person!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 17, 2009 | Grundig GU19WDT 19 in. LCD TV
Tv/dvd combi - dvd read problems
No it is not worthy, you will spend around $100, but brand new combo 13'' cost $80 and DVD starts from $22. You can use an external one.
Dec 02, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
Bush tv/dvd combi
your daughter has done nothing wrong, certain dvd,s have region codes for different countries.you can program the player with your remote, but you will need the hack number.i,m looking for it myself, so if you find it,pass it on!
Oct 17, 2008 | Televison & Video
Connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
if there is a scart connection on your bush tv then
you can use your panasonic dvd player on it, trust me
just look all over the remote carefully for an AV button, or failing that press channel up or down whilst the DVD is powered up and playing a disc and you will have solved it
hope this helps mate
Nov 05, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
Bush DVD142RC 14 in. TV/DVD Combo Logo
859 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Raj Patel
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
