Question about Nakamichi AV-7 Receiver
Rotel PReamp, Can I directly Connect my powered speakers to the output
I bought a Rotel stero control amp from an old dusty stereo store, I want to connect my Stanton Turntable to it.
I have the table plugged into the phono port and I have my powered speaker system plugged into the output and I can barely hear anything, cranking it way up produces almost inaudible noise but its def the record I have playing.
Do I need a receiver to plug into the output or what? Pls help
    Brigadier General:
  • 6,966 Answers
Based on your post, the pre-amp is doing its job. What might be the mismatch would be the powered speaker system plugged into the output of the Rotel. Depending on what the "powered speaker system" is, it might be that it is a low impedance such as those used in computers whereas the Rotel requires high impedance to be connected to its output. What could be tried is to connect a regular amp or receiver to the Rotel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 05, 2008
How do I connect my RX-4109 to a Crown power Amp?
If your Sherwood has preamp outputs, you can connect directly to the power amp inputs.
Sep 13, 2014 | Sherwood RX-4109 Stereo Receiver Black
Rotel processor bypass for Audio Research SP10
If I understand you, the 'sound' of the AR preamp is what you're trying to preserve. Presumably you're just running a phono through it as nothing else needs a preamp these days.
The multichannel inputs bypass all of the Rotel's processing except the volume. Use the Front L and R.
Mar 12, 2010 | Audio Players & Recorders
Connect stereo amplifier to powered sub
You can y out from the main out to the sub.This output is post volume control. set level on sub to desired balance of lows feq to highs
Nov 20, 2009 | Yamaha YST-SW015 Subwoofer
I have an old integrated amplifier and an old BSR EQ-3000 stereo frequency equalizer. i just bought a used bose 901 speaker set. how do i hook-up the bose 901 equalizer in this system?
Hook the signal source to the equalizer input and the equalizer output signal to one of the signal inputs on your amp. This is one way, but this way only one signal source will go through the equalizer (unless it has several signal inputs and a source selector switch).
The other way (inserting the equalizer between the preamp and the main amp) is:
If your amp has RCA connectors on the back named "preamp out" (or similar) and "power amp in" (or similar) that have slugs connecting them, remove the slugs, hook the "preamp out" signals from the amplifier unit to the signal inputs on the equalizer and outputs from the equalizer to the "power amp in" inputs on the amplifier.
Basically, what you do is that you insert the equalizer between the preamplifier section and the power amp section of the integrated amplifier so that you can still select the signal source without having to switch any signal cables (however, i can't say if your amp has got this type of "slug" connection feature between the preamp and the power amp on the rear panel, so i'm not sure which way you'll have to hook it up).
Hope you can make it work the way you want.
Sep 30, 2009 | Bose 901 VI Main / Stereo Speaker
Can I hook up my steroe speakers to the TV? I have an older model
If your older model TV has red and white plugs on the back of it that say something like "Audio Out" or "Output" then YES.
Simply connect a pair of RCA Cables (available any electronics store) from the Audio Out jacks on your tv to the "AUX" input on your stereo.
You cannot power speakers without some kind of stereo/receiver.
If you do have a receiver then you can connect to your "TV INPUT" on the back of your receiver and control the tv volume with your receiver remote.
If your tv does not have those red and white output jacks then there is no practical way for you to connect your speakers.
Aug 15, 2009 | Durabrand Televison & Video
Rotel power amp
some amps have a switch to bridge them rather than wiring a bridge meaning output is mono check to see if yours has this switch if you do simply put back to stereo
May 20, 2009 | Rotel RMB-1095 Power Amplifier
Connecting NAD 314 Receiver\ preamp to Carver M-500t to speakers
Dear Tim,
Yes, you can connect your NAD as a preamp to the Carver power Amp.
Connect the NAD's pre-out to the input of the Carver Power Amp. You can then connect the Klipsch speaker to the Carver. Set the gain control on the NAD.
Now you should be able to control all the input and the main volume control from the NAD.
Mar 12, 2009 | Onkyo TX-SR803 Receiver
Car speakers pop when on/off new stereo preamp out to Bose amp
Hi mate
this maybe caused by a positive and negitive wire touching somewere down the line!
just follow up your wires and check
Feb 16, 2009 | Bose Car Audio & Video
How do I connect a Polkaudio powered subwoofer (psw 125)
Connect a set of stereo RCA cables from the 'Output 2' on the Hafler to the line imputs on the Sub.Turn on the '1+2' output switch on the Hafler and rock out!
Dec 16, 2008 | Marantz PM7200 2-Channel Amplifier
Free booklet/part #149393
Jan 10, 2008 | Bose 901 VI Main / Stereo Speaker
Nakamichi AV-7 Receiver Logo
705 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
