Question about HP Office Equipment & Supplies
I had my computer fixed and now i try to use my printer and it will not work. I insert disc when it asks me to and it doesn't seem to read disk. I have hp office jet 5610 all in one printer. Than you for your help.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 188 Answers
Hi Carzales,
Please follow this link directly to HP's download site. Once there, select your operating system, and then select the driver from the list that follows. you can download just the driver, or the driver and all the other software ( very large file, but there if you need it ).
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=441125&lc=en&cc=us&dlc=en&lang=en&cc=us
Please remember to take a moment to rate this solution as "fixya" if this resolves your issue.
Thanks,
Cory
Posted on Nov 05, 2008
How can I get my dvd to copy videos when it reads, No Disk? when there's a disk in the player?
hi, possible problem with the dvd, the lens doesn't read the disc or the spindle motor not rotating that is why can not read a disc. try to clean first with a cd lens cleaner, just insert a cleaner to the player to remove dirt and might the lens get sticky. now if still doesn't work, you will need to remove the cover of the player to access the internal part. check for broken part or any obstacle that can block the rotation of the spindle motor.if the motor doesn't rotate anymore you can check the resistance if still there using an analog tester. if no resistance at the pin terminal of the motor, the coil was worn out then you will need to replace the motor.
Jun 08, 2012 | Compaq Computers & Internet
Hi! I inserted a burned dvd r into my Mac but it's not reading it. The message You've inserted a blank CD pops out. I tried using a PC but it can't open it either, it says there's an error...
there are a few reasons why
1.) the formatting of the disk may be formatter for a PC and NOT a MAC
2.) after burning, this dvd was never "closed"
3.) You burned a coaster
good luck
Jun 06, 2011 | Computers & Internet
I have a HP DVD 1040 that won't read a map disc from National Geo
Try transfer from DVD to Flash disk, insert flash into the PC and run from that. should work. It is a work around.
Jan 26, 2010 | Philips Dvd Video Player
Computer does not seem to recognise disc. I keep
Hello !
Either your disk or disk drive is problematic.
Try your disk in another PC to test. If the disk works, your CD drive is faulty. Try another disk in your computer's drive. If the disk doesn't work, you have confirmed that the drive is faulty.
If the drive is a problem, I would suggest to purchase a disk head cleaner, first. Then, if the drive is still a problem, it would need replacing.
Hope this helps.
Sep 10, 2009 | Lexmark Office Equipment & Supplies
Cannot install HP 6310 Officejet 'run as'
Hook up the printer.  Turn it and the computer on.  Let Windows find the printer. Windows will ask you if you have the disk. Insert the disk then. If you need aditional help look at the web link for the HP printer that you have.  See Link Below:
http://h10025.www1.hp.com/ewfrf/wc/product?product=1119598&lc=en&cc=us&dlc=en&submit.y=2&submit.x=8〈=en&cc=us
Feb 26, 2009 | HP Officejet 6310 All-In-One InkJet...
After I insert a dvd disc in the dvd drive, it still asks me to isert a disc in the drive. It seems that it is not able to read the disc. We currently subscribe to netflix. Certain dvd"s whhen inserted...
If it is a hardware fault, a fault in your drive, it occurs on every disk
if it is a disk fault it occurs only when faulty disks are used.
Probably Netflix discs are bad, wrong region code, or scratched, or badly copied
Jul 18, 2008 | Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
15 people viewed this question
Seeker5211
Seeker5211
