Question about Acer Aspire 5600 Series 5630-6951 Laptop
Connecting my linux machine to a windows xp based wifi network.
I would like to connect my machine to my friend machine.
my friend is using windows xp and i am using fedora 8.
my friend has created a wifi-Adhoc network from his machine.
from my machine i did the following to connect to the network.
wlan0 - wireless interface on my machine.
1. ifconfig wlan0 up - activated my wireless card.
2. iwlist wlan0 scan - to list the wireless networks that are detected by my wifi card. This shows the network created by my friend.
Could someone let me know as to how i could connect to the network shown by iwlist.
my wireless ip - 192.168.0.3
my friends wireless ip - 192.168.0.1
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
If im not mistaken u have to set up a network connection and save the settings and load them into the next computer u want to be linked. windows network wizard should explain it quite easily.
Posted on Nov 16, 2008
Not working wifi on my lenovo g360 laptop, all drivers are working properly. And switch is already on. if u guys know about that, help me pls
Make sure Wi-Fi is turned on your device
Make sure flight mode is turned off
Make sure your selecting the correct wireless name in range and using the correct network password to connect, Wireless networks with low signals will show connected but you will not be able to browse the internet
Check your router and modern, Make sure the lights are as mentioned in the user guide of your service provider
First figure out if the problem is with your Lenovo Device or the Wi-Fi network:
Device/Machine problems: Try connecting to the Wi-Fi network with another device, like a laptop computer or friend's phone. If any other devices can connect to and use the wireless network, the problem is most likely specific to your device.
Network/Router problems: Check to see if your device can connect to a Wi-Fi network at another location, like a friend's house or a public network. If it can, the problem is most likely specific to the Wi-Fi network.
Then try the troubleshooting steps below based on whether the problem is with your device or the network.
Sep 05, 2016 | SNWG Lenovo G360 Notebook / Laptop PC...
Tip
Belkin F5D7234-4 v1 (important thing)
In Belkin f5d7234-4 v1(only version 1) router, do not disable "WiFi protected setup" learn more about wps
  • If you do so, then the router will no longer work in 90% of cases.
  • The WiFi protected setup is enabled by default in this model.
  • The computers using XP,vista,win7 may not connect to the wireless network. 96cff88.jpg
Solution:
In that case you can add the wireless network manually in the computer.Still if it says error message as "windows cannot connect",then follow these steps according to your operating system.
WINDOWS XP:
Start>
Control Panel>Network and Internet Connections(Network connections)>Right Click Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS VISTA:
Start>
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side click on Manage Network connections>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS 7:
Start >
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side Click on Change Adapter Settings>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
  • Now try to access wireless network.
  • If it still says windows cannot connect then no other go.
  • You need to disable WiFi protected setup.This will fix the issue for sure...
Click here to know how to disable wifi protected setup...
To learn more about WiFi protected setup, please click here...
on Apr 19, 2010 | Computers & Internet
Unable to establish wifi for windows 8 to draytek 2390vn
I have the exact same problem. I end up with limited connection. Same machine on Linux connects to the same network without any problem.
Feb 11, 2013 | Draytek Vigor 2930Vn Wireless N Router...
Unable to Connect to the internet by Wifi in Xp Sp3. But its working properly in Linux Mint. MSI U100Plus.
You need to update the driver for wifi adapter. The driver for the wifi connection you are using in linux is compatible to it but this driver can not get support to your xp sp3 to get compatible.
Jan 11, 2011 | Computers & Internet
I bought 2 netbooks and cant get to work when i go to conect it said page not found
If you are using a Linux based OS, there are a load of problems associated with the drivers not working. Suggest you look here for more specific help
http://gosforums.org/viewtopic.php?f=21&t=549
Dec 28, 2010 | Sylvania G-Netbook
I have recently configured a 2wire 2701HG-B router connecting my home LAN to the internet (ATT-DSL). One of my machines is a linux box running SUSE 11.0 . Two other machines run microsoft XP. Although...
I use ATT as well, but I am running ubuntu. for some reason in order to connect to the internet I have to restart networking after boot. I just use networking helper scripts, otherwise, for some reason it does not key-in WPA through the manual config properly.
Aug 14, 2010 | 2wire 2700HG-B Router (2700HGB)
Unable to connect to the internet in Redhat Enterprise Linux 5
Get the drivers for your WiFi card for the correct edition of your RedHat. Wireless card may be incompatable with red hat.
Apr 11, 2009 | Red Hat Enterprise Linux ES Basic Edition
HOW TO CONFIGURE WIFI WITH Compaq Model C765TU in XP
Click Start, then select Control Panel.
Click Network and Internet Connections. The Network and Internet Connections window opens.
Click Network Connections. The Network Connections window opens.
Right-click Wireless Network Connection.
Select Enable to turn on wireless Ethernet or Disable to turn off wireless Ethernet.
May 29, 2008 | Compaq Presario 700 470024-192 Notebook
Can't connect to internet by using LINKSYS Wireless-G card
I am assuming you have a dual boot machine meaning it runs either linux or windows and not both at the same time. Linux on the other hand may not configure the card automatically and as you should consider changes to the laptop in terms of configuration and devices are actually changes to two computers the windows computer and the linux computer. You probably did some configuration for windows to enable the wireless card (if there was no encryption windows may have done it for you). Linux on the other hand may not recognose and configure the card automatically and as you should consider changes to the laptop in terms of configuration and devices are actually changes to two computers the windows computer and the linux computer. The many flavors of linux also have almost as many means to configure devices. In order to assist you I will need to know which distribution and version of linux you are using. I will also need to know the manufacturer and model (possibly number and not description) of the wireless adapter to be configured. Warning this may be easy and in other cases it may not be and I have access to few linux distributions to experiment with.
Dec 09, 2007 | Linksys WPC54G Wireless-G Notebook Adapter...
Acer Aspire 5600 Series 5630-6951 Laptop Logo
125 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
